Old 24-04-14, 21:36   #751
Bogdani14
Bogdani14's Avatar
Default re: Dacia Berlina 4x4 Turbo Vom
Si eu zic la fel ....tot primele 2
Bogdani14 is offline   Reply With Quote
Old 26-05-14, 14:09   #752
npeti
npeti's Avatar
Track day pt teste Arad. si "coafura" 4x4 rezista "
ID:	2989744   Click image for larger version
ID:	2989745   Click image for larger version
ID:	2989747   Click image for larger version
ID:	2989748   Click image for larger version
ID:	2989750   Click image for larger version
ID:	2989751   Click image for larger version
ID:	2989753   Click image for larger version
ID:	2989754   Click image for larger version
ID:	2989756   Click image for larger version
ID:	2989757   Click image for larger version
npeti is offline   Reply With Quote
Old 27-05-14, 18:54   #753
BOGDAN_UWW
BOGDAN_UWW's Avatar
Frumoasa masina
imi place si interiorul , sunt comode scaunele
BOGDAN_UWW is offline   Reply With Quote
Old 27-05-14, 19:04   #754
npeti
npeti's Avatar
Si niste poze ai profi (concluzia dupa poze) tre sa scurtez telescoapele fata inca.
Name:	02-VSS Et 3-NP.jpg
ID:	2990341   Click image for larger version
Name:	03-VSS Et 3-NP.jpg
ID:	2990342   Click image for larger version
Name:	04-VSS Et 3-NP.jpg
Name:	05-VSS Et 3-NP.jpg
ID:	2990344   Click image for larger version
Name:	06-VSS Et 3-NP.jpg
ID:	2990345   Click image for larger version
Name:	07-VSS Et 3-NP.jpg
Name:	08-VSS Et 3-NP.jpg
ID:	2990347   Click image for larger version
Name:	09-VSS Et 3-NP.jpg
ID:	2990348   Click image for larger version
Name:	10-VSS Et 3-NP.jpg
Name:	11-VSS Et 3-NP.jpg
ID:	2990350   Click image for larger version
Name:	12-VSS Et 3-NP.jpg
ID:	2990351   Click image for larger version
Name:	13-VSS Et 3-NP.jpg
Name:	14-VSS Et 3-NP.jpg
ID:	2990353   Click image for larger version
Name:	15-VSS Et 3-NP.jpg
ID:	2990354   Click image for larger version
Name:	16-VSS Et 3-NP.jpg
Name:	17-VSS Et 3-NP.jpg
ID:	2990356   Click image for larger version
Name:	18-VSS Et 3-NP.jpg
ID:	2990357   Click image for larger version
Name:	19-VSS Et 3-NP.jpg
Name:	20-VSS Et 3-NP.jpg
Old 16-06-14, 21:42   #755
npeti
npeti's Avatar
rog un moderator sa schimbe titlul theradului in "DACIA BERLINA 1978 tr 4x4 1.6 TURBO VOM'u" MERCI.
Old 03-08-14, 10:56   #756
npeti
npeti's Avatar
Masina a primit o turbina t25 ..ceva mai mica de provenienta BMW..avand boost acuma si in turatii mici . Saptamana viitoare primeste o alta evacuate cap coada din inox de 60mm.
Mitsu 3000 GT TWIN TURBO 3000 V6 24 v dohc
Dacia 1300 2.0 turbo tractiune 4x4
VW Transporter T3 2000 2 carb boxer
CLIO 1 1.8 16v RALLY
fiat 600d (in reconditionare ) 1965
RENAULT 5 GTT
laguna 2.2dci grand tour (pt familie) 2002
Old 10-08-14, 22:31   #757
npeti
npeti's Avatar
cate o flansa pe galerie..una pe evacuare... si functioneaza turbina de bmw pe motor de renault. acuma am boost in 1300-1400rpm ...spre 2000 deja incarca bine. la 2500 deia e la 1.2 bari. Mai sa pun filtru de aer....
ID:	3016779   Click image for larger version
ID:	3016780   Click image for larger version
ID:	3016782   Click image for larger version
ID:	3016783   Click image for larger version
Old 10-08-14, 22:38   #758
npeti
npeti's Avatar
intre timp am facut si consola centrala din nou..cel vechi nu mai intra de tunel. E construit a simetric. Pe partea soferului se sprijina pe tunel, asa incat sa nu deranjeze la pedala de acceleratie.. iar spre pasager pare mai adanca..contine si martorul de 4x4. Cand cuplez frumos se aprinde. si contine restul ceasurilor si casetofonul. E din lemn, imbracat in burete subtire si tapitat in piele ecologica. si o poza cu maneta din podea(4x4) langa frana de mana
ID:	3016786   Click image for larger version
ID:	3016787   Click image for larger version
ID:	3016789   Click image for larger version
ID:	3016790   Click image for larger version
Old 10-08-14, 22:56   #759
ovy_geo93
ovy_geo93's Avatar
frumos lucrat,dar daca tot ati facut un facelift,de ce nu puneti si un bord CN4?
ovy_geo93 is offline   Reply With Quote
Old 12-08-14, 20:13   #760
npeti
npeti's Avatar
Nu mai schimb bordul.....botul masini l-am schimbat prin 2001 cand am avut un accident si nu mai gaseai tablarai original dacia decat cn4...asa ca am pus cn4. nu sunt fan zambetul lui iliescu..dar asta e. Ceea ce am sa schimb o sa fie motorul cu unul de renault 21 turbo de 2000cmc...aia o sa fie urmatorul pas
Old 15-08-14, 13:36   #761
lord_wader
lord_wader's Avatar
Felicitari!
pt. 3000gt ai un topic? ca am vazut ceva pe la vanzari si cam atat cred.
Old 18-08-14, 19:11   #762
npeti
npeti's Avatar
nu la mitsu nu i-am facut topic......in proportie de 95 % e stock
Old 18-08-14, 22:03   #763
npeti
npeti's Avatar
pasul urmator....
ID:	3019459   Click image for larger version
Old 18-08-14, 22:14   #764
SOLENZAXJG
SOLENZAXJG's Avatar
Frumos proiectul si spor in continuare sa o duci la bun sfarsit cu motorul cel nou,sa o vedem in actiune cu inima noua.
SOLENZAXJG is offline   Reply With Quote
Old 18-08-14, 22:36   #765
florinvasile
Originally Posted by npeti View Post
pasul urmator....
FELICITARI !!!
Te consider un mester priceput si/sau un roman curajos.
Bineinteles, cu ajutorul pe care, cu siguranta, l-ai primit de la prieteni, rude, cunoscuti.
Cat despre masina, imi place cum arata.
Cred ca ar da bine langa DACIA Break albastra pe care am vazut-o intr-un timp prin Bucuresti, in trafic, daca nu o fi ajuns cumva pe la REMAT...
SUCCES IN CONTINUARE !
florinvasile is offline   Reply With Quote
- Copyright 2025 4Tuning -
