Go Back   Forum 4Tuning > AUTO COMERCIAL > Bazar CAR AUDIO > Pachete Audio: Statie+Sub, HU+difuzoare, etc
Pachete Audio: Statie+Sub, HU+difuzoare, etc Pachete Audio: Statie+Sub, HU+difuzoare, etc
Old 18-09-13, 13:56   #1
catalinionut229
catalinionut229's Avatar
Default Sistem Audio Ground Zero Helix 1600w La Super Pret!
Sistem audio format din:
Amplificator Ground Zero Uranium GZUA 1.1600D
putere RMS:
1 x 500W @ 4 ohm (14.4V),
1 x 800W @ 2 ohm (14.4V),
1 x 1200W @ 1 ohm (14,4V),
1 x 1600W @ 1 ohm (14,4V)
THDL 0.01%
S/N Ratio: >75dB
Damping Factor: >200 (@ 100Hz)
Dimensions: 13" x 9.5" x 2.2" (33cm x 24.2cm x 5.6cm)
Fuse: External 150A
Subwoofer Helix Spxl 12 Competition
diametru 12 inch ( 30 cm)
bobina de 4" (10 cm) platbanda
putere: 1500W RMS, 3000W Max
impedanta: 2 x 2 ohmi
Fs: 31 Hz
Qts: 0,46
VAS: 38,4
adancime instalare: 21 cm
greutate: 21,5 Kg
Kit complet cabluri 35 mm Dietz cu siguranta 150A (foarte groase)
Produsele sunt impecabile... se aud superb!!!
Pret: 1600 Lei
nr tel. 0767273448
ID:	2857225   Click image for larger version
ID:	2857226   Click image for larger version
catalinionut229 is offline   Reply With Quote
Old 24-09-13, 10:51   #2
catalinionut229
Default Re: Sistem Audio Ground Zero Helix 1600w La Super Pret!
video cu ele in actiune ...
https://www.youtube.com/watch?v=sDVlN7mDjUw
Old 26-09-13, 13:21   #3
catalinionut229
Valabil
Old 17-10-13, 12:42   #4
catalinionut229
disponibil ...
Old 19-10-13, 13:29   #5
catalinionut229
sus ... 1500 ron super oferta!!
Old 12-11-13, 11:03   #6
catalinionut229
difuzoru este la cutie!
Name:	2013-11-11 14.25.30.jpg
ID:	2889931   Click image for larger version
Name:	2013-11-11 14.25.15.jpg
Old 13-01-14, 14:21   #7
catalinionut229
in primavara iese din cutie se poate asculta pe masina
Old 27-01-14, 13:54   #8
catalinionut229
inca valabil..
Old 29-01-14, 12:57   #9
nandi
dai si separat amlificatorul?la ce preti?
nandi is offline   Reply With Quote
Old 29-01-14, 14:51   #10
catalinionut229
avand in vedere si fapta ca costa undeva la 18 mil nou .. as zice 750 ultimu pret fara taxe
Old 11-02-14, 10:42   #11
catalinionut229
Valabil
Old 16-02-14, 16:44   #12
catalinionut229
Să dat staţia.. preţ pt subwoofer 750 lei
