Go Back   Forum 4Tuning > AUTO COMERCIAL > Bazar CAR AUDIO > Subwoofere auto
Subwoofere auto Subwoofere auto, difuzoare bass, woofer, tub, bas, audio
Old 02-01-14, 20:14   #1
Spliff
Spliff's Avatar
Default [Vānd] Subwoofer Sundown Audio SA-12 + incinta
Specificatii:
600-watts RMS Power Handling
19.0mm X-Max by 70% BL method one-way (38.0mm peak to peak)
Thick black anodized aluminum voice coil formers for maximum strength and heat dissipation
4-layer copper high temperature voice coil windings with 45mm winding length
Double layer permanently bonded high strength Nomex spider pack for maximum longevity and durability
Thick flat tinsel lead wires tied down to the spider to prevent lead noise and breakage
Custom tooled triple joint support ring
Custom tooled frame spacer / ventilation ring
High efficiency air-flow management integrated into the motor for maximum voice coil cooling
Dual Aluminum Faraday rings for reduced inductance and inductive distortion (pole cap and magnet ID)
Two-Year Warranty against defects in materials and workmanship (full warranty text on our web-site)
Achizitionat (nou) prin august-septembrie 2012. Functioneaza fara probleme.
Pretul este 1000 lei si include difuzorul, incinta din imagine(55L 35Hz) + stikerul Sundown Audio.
ID:	2917738   Click image for larger version
ID:	2917739   Click image for larger version
ID:	2917741   Click image for larger version
ID:	2917742   Click image for larger version
Somebody stop me, I`m outta control, please
Before I do autopsies on these MC`s.
Spliff is offline   Reply With Quote
Old 13-02-14, 19:04   #2
Spliff
Spliff's Avatar
Default Re: [Vānd] Subwoofer Sundown Audio SA-12 + incinta
Mai incercam, nu e graba.
Old 16-02-14, 13:21   #3
Spliff
Spliff's Avatar
Nu mai raspund la anunturi gen ultimul pret.
Se vinde in conditiile si la pretul afisat.
Nu tin neaparat sa-l dau.
Old 02-03-14, 17:49   #4
Spliff
Spliff's Avatar
Eventual schimb tot cu ceva de 12" plus diferenta.
Old 07-03-14, 09:18   #5
suvi_xxx
suvi_xxx's Avatar
de ce il vinzi?
Old 07-03-14, 12:21   #6
Spliff
Spliff's Avatar
Old 28-06-14, 15:40   #7
Spliff
Spliff's Avatar
La pachetul actual se mai adauga inca 3 incinte, cele de aici : forum.4tuning.ro/553-subwoofere-auto/406774-vand-3-incinte.html plus inca una bandpass. Revin cu detalii despre incinta bandpass. In momentul de fata oferta suna cam asa, un sa12 + 4 incinte la pretul de 1000 lei. Am si eu o oferta la randul meu si daca se poate materializa ok, da nu raman la sundown. Nu raspund la intrebari gen ultimul pret sau ofertelor sub pretul afisat.
Old 28-06-14, 20:37   #8
Spliff
Spliff's Avatar
Dimensiuni incinta bandpass:
68cmX45cmX40cm
Partea inchisa are 35.6L, cea bas reflex 56.3L utili final cu porturi luate in calcul. Acordaj 38.7 hz, porturile au 12.5cm diamentru cu 16cm lungime.
ID:	3002065   Click image for larger version
ID:	3002066   Click image for larger version
ID:	3002068   Click image for larger version
ID:	3002069   Click image for larger version
