[Vānd] Subwoofer Sundown Audio SA-12 + incinta
6 Attachment(s)
Specificatii:
600-watts RMS Power Handling 19.0mm X-Max by 70% BL method one-way (38.0mm peak to peak) Thick black anodized aluminum voice coil formers for maximum strength and heat dissipation 4-layer copper high temperature voice coil windings with 45mm winding length Double layer permanently bonded high strength Nomex spider pack for maximum longevity and durability Thick flat tinsel lead wires tied down to the spider to prevent lead noise and breakage Custom tooled triple joint support ring Custom tooled frame spacer / ventilation ring High efficiency air-flow management integrated into the motor for maximum voice coil cooling Dual Aluminum Faraday rings for reduced inductance and inductive distortion (pole cap and magnet ID) Two-Year Warranty against defects in materials and workmanship (full warranty text on our web-site) Achizitionat (nou) prin august-septembrie 2012. Functioneaza fara probleme. Pretul este 1000 lei si include difuzorul, incinta din imagine(55L 35Hz) + stikerul Sundown Audio. |
Re: [Vānd] Subwoofer Sundown Audio SA-12 + incinta
Mai incercam, nu e graba.
Nu mai raspund la anunturi gen ultimul pret.
Se vinde in conditiile si la pretul afisat. Nu tin neaparat sa-l dau. |
Eventual schimb tot cu ceva de 12" plus diferenta.
de ce il vinzi?
La pachetul actual se mai adauga inca 3 incinte, cele de aici : forum.4tuning.ro/553-subwoofere-auto/406774-vand-3-incinte.html plus inca una bandpass. Revin cu detalii despre incinta bandpass. In momentul de fata oferta suna cam asa, un sa12 + 4 incinte la pretul de 1000 lei. Am si eu o oferta la randul meu si daca se poate materializa ok, da nu raman la sundown. Nu raspund la intrebari gen ultimul pret sau ofertelor sub pretul afisat.
6 Attachment(s)
Dimensiuni incinta bandpass:
68cmX45cmX40cm Partea inchisa are 35.6L, cea bas reflex 56.3L utili final cu porturi luate in calcul. Acordaj 38.7 hz, porturile au 12.5cm diamentru cu 16cm lungime. |
