18-05-08, 23:59
#16
Honda Driver
Member of: [PARTICIPANT CURSE] [Nissan] [Honda]
Re: VAND orice fel de turbina, livrare 10-14 zile
19-05-08, 09:11
#17
garret-ul ala nu i-l gasesc pe nicaieri.
pentru 300zx pot sa iti aduc hibrid T25 TD04-H la 400 euro de la SPA turbo, merge la tine cu modificari minime la downpipe (upgrade pentru maxim 380 cp)
de asemenea pot sa iti aduc pentur el downpipe-uri, evacuari compelte cat back, kituri de ambreiaj stage 1-3, kituri intercooler, etc.
19-05-08, 10:40
#18
Honda Driver
Atunci GT600R macar...t25 ala e prea mic...
Si un FMIC cu tot cu furtune ptr el..
19-05-08, 20:19
#19
Nici pe asta nu o gasesc, srry.
Front mount intercooler, pipework & silicone hoses for the 89-97 Nissan 300ZX Z32 by AUTOBAHN88, all years all models. The intercooler core size is a massive 515mm x 210mm x 70mm and has a pressure drop of only 0.2psi @ 15 psi. The intercooler is polished aluminum with a bar and plate design. The pipework is polished aluminum. ABS and air conditioning do no not need relocated or removed.
STEP-BY-STEP PICTORIAL INSTRUCTION FOR EASY DIY INSTALLATION INCLUDED.
SILICONE HOSE ADAPTER CAN BE CHOOSEN FROM RED OR BLUE COLOURS.
Specification
Fully polished
Tabs on bottom and top for easy installation
Improved 15 big bar design with offset fins to increase efficiency
Supports more than 650HP
Latest unique bar & blate core design to improve air velocity by 15% over the old design
Ultra low pressure drop 0.5-1psi at 23psi (Normal Bar and Plate 2.8- 4 psi at 23 psi)
35 % weight reduction
The kit will not only dress up your engine bay but will also allow for the much better flow of air in and out of your intercooler maximizing cooling on your 300ZX.
pretul ar fi de 1990 ron
livrare 10-14 zile
23-05-08, 17:38
#20
turbina bmw e46 2.0l 2003 un echivalent sau ceva putin mai mare
23-05-08, 17:43
#21
cum adica putin mai mare ?
e cea cu geometrie variabila ?
motorul e cel de 150 cp sau 136 ?
23-05-08, 17:49
#22
150 cp ... nush daca e cu geometrie variabila sau nu ... am luat masina acum 2 sapt si nu am desfacut nici capacul de la motor sa vad macar ce turbina e ... si prefer una new decat sa o repar ....
23-05-08, 18:08
#23
4300 ron
noua, originala, garantie 12 luni, livrare 10-14 zile, avans 50%
BMW 320 d
Motor M47N204D4
110 KW
150 PS
Hubraum 1995 ccm
4 Zylinder
Baujahr ab 09.2001
Diesel
Original BMW Ersatzteilnummern:
11657787626
11657787627
11657787628
11657794144
Schlüsselnummern: zu2: 0005
zu3: 737,720,738
Hersteller: Garrett
23-05-08, 20:27
#24
salut la ce pret ar fi o turbina la un bmw e 39 525d 120kw
mersi
24-05-08, 01:13
#25
3600 ron
livrare 10-14 zile
11-06-08, 09:20
#26
sus cu ele..........
12-06-08, 23:53
#27
Member of: [DACIA]
Salut!
Ma intereseaza si pe mine o turbina pt. Logan 1.5 dCi , 65cp .
Pretul ?
13-06-08, 00:02
#28
nu pot aduce asa ceva...srry
13-06-08, 00:25
#29
Member of: [DACIA]
Ok , merci de raspuns !
Bafta !
18-06-08, 09:33
#30
