08-07-08, 10:31
#31
Renault Driver
Member of: [RENAULT] [PEUGEOT] [PARTICIPANT CURSE]
Re: VAND orice fel de turbina, livrare 10-14 zile
un T25 sau un hibrid T2/T25 sau T25/T3 ?
08-07-08, 11:02
#32
garrett t25 new - 1700 ron
t25 td04h (hibrid) new - 1100 ron
livrare 10-14 zile
avans 50%
09-07-08, 06:12
#33
sal este tot kitul complec sau doar turbina fami si mie un pret la un kit complect pt un motor de golf 3 2.0 16V ms mult
09-07-08, 08:15
#34
1200 euro kit complet (galerii, turbina, intercooler, tevi, bov, regulator de presiune, garnituri, etc)
11-07-08, 05:44
#35
sal o poza se poate cu kitul complect ms mult
11-07-08, 11:19
#36
pictures...
JDM'S T3/T4 Turbocharger with 3" Filter!!
Turbine Turbocharger
Oil cooled only
6 blade propeler
Compressor Specs :
3" Compressor Inlet
3.000" or 76.2mm inducer
1.990"" or 50.55mm Major
Compressor .50 A.R.
Compressor 57 Trim
M24 / T4 Compressor Housing
Turbine Specs :
T3 Type Turbine
11 Blade Type
2.25" Exducer
Turbine .64 A.R.
Turbine 76 Trim
2.567 " or 65.2mm Major
2.207 " or 56.06mm Minor
Exhaust Outlet Flange with 5 bolt design
Can modified to use external or internal wastegate.
JDM'S T3/T4 Turbo Oil Feed Line !!
Made Out of High Quality Aluminum
Improves Engine Oil Cooling for all Engine types
Length : 36"
1/8" Adapter NPT Male Fitting for the Block
Comes with all accessories needed.
JDM'S T3/T4 Turbo Oil Return Line !!
Oil Return Line made for turbo
Helps circulate oil from the turbo to the oil pan
All components are included for fitment
Fits on all turbos
Only works on metal oil pans only!
JDM'S Manual Turbo Boost Controller !!
In order avoid replacing wastegate springs, which only give a fixed increase, which is not adjustable, a boost controller will be the most cost effective solution
Allows adjustable boost psi settings, light weight design to be mount under the hood. Hardware is included
Universal fitment and great for all Turbo applications
Easy to adjust from 1-30PSI
Professional Installation required
SSQV Blow Off Valve with Adapter Pipe!!
Direct Bolt-On For All Turbo Application With Flange
Universal Fitting Kit
This Blow Off Valves Are Easily Adjustable To Prevent Both Premature Boost Leakage And Compressor Surge
Both Premature Boost Leakage And Compressor Surge.
It Can Hold Up To 1200HP Or 25 PSI Of Boost Pressure
Professional Install Suggested
Comes with 2.5" Adapter pipe made for SSQV bovs
JDM'S 2" Turbo Boost Gauge & Air/Fuel Gauge
52mm diameter = 2inch universal fitments
Luxury Chrome trims framing
Dark Tinted face for stealth JDM looks.
LED lightings allow great visibility during day and night
12v gauge, light weight abs plastic finish
Features White numbering and Red needles
JDM'S Universal Starter Turbo Piping Kit
Intercooler Piping are CNC Machine Mandrel Bent (Jp Design)
Made From High Quality 6061 Aluminum Material with chrome finish
Extra Thick Piping and Increased Air Flow
Light weight design. Made from Aluminum.(Increase 10-20 HP).
PSi Drop under 0.2. Other Intercooler usually drop 10Psi Some are More
Comes with Turbo Pipes, T Bolt clamps and Couplers
JDM'S 28 "x7"x2.5" Turbo Intercooler
Tube & Fin Design
Light weight designed. Made of Aluminum.(Increase 10-20 HP).
All TIG Welded 6061 Aluminum
Max PSi is 30 Up to 400HP
Core Size: 21"x7"x2.5"
JDM'S T3/T4 Turbo Downpipe Flange
Made out of High quality of Aluminium Material
Made from 100% SUS T-304 Stainless Steel
Used to fit with any pipe to make a custom downpipe to fit your car.
JDM'S 38mm Turbo Wastegate with Flex Pipe
All Stainless Steel hardware
Mating weld flanges are 304L.
17-7 PH Stainless Steel actuator spring gives consistent pressure at high temperature, resist "relaxing" at temperature to 900F (483C).
High temperature silicone reinforced actuator diaphragm.
High temp alloy is used for valve and 347SS valve housing will offer longer product life compared to competing designs.
External wastegates are commonly used for regulating boost levels more precisely than internal wastegates in high power applications, where high boost levels can be achieved.
Comes with a spring around 7psi
SPA TURBO MANIFOLD (turnata)
14-07-08, 18:03
#37
Member of: [PARTICIPANT CURSE] [RENAULT] [Pole Position Racers]
Un kitt turbo pt clio 1 1,8 16 v se gaseste?
14-07-08, 18:05
#38
nu ,din pacate nu...
doar sa iti aduc un kit turbo fara galerii (cm e cel de sus) pe care sa le faci singur
ar fi 1000 euro kitul
14-07-08, 22:59
#39
Honda Driver
Member of: [Honda]
salut un kit complet pt o honda civic 1400 cmc din 96 cam cat ar ajunge si pt un ford focus 1,8 16v zetec tot la fel tot kitul. cam cat ar costa pt una si pt alta si in cat timp ajung
v-tec power
14-07-08, 23:05
#40
pt ford 1150 euro
livrare 10-14 zile
pt honda trebuie sa imi dai tipul motorului
14-07-08, 23:25
#41
Honda Driver
Member of: [Honda]
Originally Posted by elspa
pt ford 1150 euro
livrare 10-14 zile
am cautat si nu am gasit daca poti tu cauta e motoru de 1.4 90 hp 16v este din seria D masina e honda civic din 1996.astept un rsp salut
15-07-08, 06:02
#42
nu am idee, oricum tot kitul ar fi 1100-1150 euro in functie de motor....
22-07-08, 19:20
#43
Ptr skoda octi 2 1.9 tdi 77kw(105 cp) .... se gaseste un upgrade turbo kit??? Nu vreau hibrid
Multumesc
22-07-08, 19:57
#44
nu, srry
24-07-08, 13:19
#45
la o honda civic '84 1488cm 12v OHC 86 cp motor tip EW2
pret turbina
pret turbina+kit montare
