Old 29-08-12, 20:26   #1
71-LEX
71-LEX's Avatar
Default Alpine SXE-1750s vs Alpine SPX-17PRO
Salut ..Asa cum spune si numele topicului m-ar interesa si pe mine niste sfaturi in legatura cu achizitionarea unor difuzoare auto pentru un VW Passat B5.5...Tin sa precizez ca nu prea stiu eu cu ce se mananca difuzoarele si tot ceea ce tine de ele..Nu doresc sa particip la vreo competitie ceva ci vreau doar sa le schimb ptr ca cele originale au inceput sa se auda foooarte prost..Astep sincere pareri...
Alpine SXE-1750S
Difuzoare Auto Componente
Diametru woofer 16,5 cm
Tweeter 25mm
Putere Maxima 280 W
Putere Nominala (RMS) 45 W
Impedanta 4 ohmi
Raspuns Frecventa 60Hz-20kHz
Sensibilitate 90 dB
Adancime instalare 61 mm
Magnet 62 mm
___________________________________
Alpine SPX-17PRO
Speaker Features
•Neodymium Woofer Magnet
•Shorting Sleeve Heatsink (patented)
•Thermal Management System (patented)
•Cross-Rib Glass Fiber Cone
•Ring Radiator TW Design w/ 25mm VC
•Multi-roll Surround
•Cast Aluminum Frame & Network Box
•Multiple Crossover Tuning Options with minimum phase shift
Crossover Features
•Thermally Coupled Cast Aluminum Chassis
•TO-220 Power Resistors with AL Heatsinks
•Heavy Gauge Air Core Inductors
•Metalized Poly Capacitors
•Phase Linkage Setting module
•4-level TW adjustment
•Bi-amp capability
•TW protection
•Gold Plated Insert Terminals w/tab
Specifications
•300 Watt Peak Power
•100 Watt RMS
•Frequency response: 35Hz – 60kHz
•Sensitivity: 89,5dB/W (1m)
•Insatallation Diameter: 134 mm
•Depth: 63 mm
___________________________________________
Save the planet, Kill Yourself !!
_______________
71-LEX is offline   Reply With Quote
Old 06-09-12, 02:11   #2
Bogdan OCC
Kamikaze Racing Team Member
Bogdan OCC's Avatar
[Kamikaze Racing Team]
Default Re: Alpine SXE-1750s vs Alpine SPX-17PRO
Buget?
Bogdan OCC is offline   Reply With Quote
Old 09-09-12, 17:07   #3
71-LEX
71-LEX's Avatar
Originally Posted by Bogdan OCC View Post
Buget?
Hmmmm....buget...sa zicem 200ron pe set....vreo recomandare ceva???
Old 09-09-12, 20:39   #4
marius86AMI
marius86AMI's Avatar
cred ca ti-ai raspuns singur, avand in vedere ca optiunea nr.2 din 'grila ta' costa ~1700 RON ...
e foarte important daca le pui pe HU stock, daca le amplifici, daca ai masina insonorizata.
sincer, in bugetul 0 - 300 RON orice ai alege e cam acelasi lucru daca nu le amplifici. Difurile stock sunt Blaupunkt si sunt niste trompete(clar, niste trompete masurate si adaptate de producator pentru incinta care se creeaza).
Passatul este o masina foarte bine 'inchegata', personal detin si stiu ce zic. E o alegere perfecta pentru SQ dar evident, bugetul e intotdeauna o problema
Stima.
marius86AMI is offline   Reply With Quote
Old 09-09-12, 23:59   #5
Bogdan OCC
Bogdan OCC's Avatar
La 100 euro exista niste japane care suna foarte "eschiu" (sq), dar depasesc.
As pune un set doar pe fata, asta in conditiile in care planuiai sa iei doua seturi de 200ron.
Instalări sisteme audio#Custom #SoundQuality #SPL #OEM+integration #Japan #Deutschland echipa-Zoom.com
