Alpine SXE-1750s vs Alpine SPX-17PRO
Salut ..Asa cum spune si numele topicului m-ar interesa si pe mine niste sfaturi in legatura cu achizitionarea unor difuzoare auto pentru un VW Passat B5.5...Tin sa precizez ca nu prea stiu eu cu ce se mananca difuzoarele si tot ceea ce tine de ele..Nu doresc sa particip la vreo competitie ceva ci vreau doar sa le schimb ptr ca cele originale au inceput sa se auda foooarte prost..Astep sincere pareri...
Alpine SXE-1750S http://130.com.ua/published/publicda...-SXE-1750s.jpg Difuzoare Auto Componente Diametru woofer 16,5 cm Tweeter 25mm Putere Maxima 280 W Putere Nominala (RMS) 45 W Impedanta 4 ohmi Raspuns Frecventa 60Hz-20kHz Sensibilitate 90 dB Adancime instalare 61 mm Magnet 62 mm ___________________________________ Alpine SPX-17PRO http://www.onlinecarstereo.com/CarAu..._SPX-17PRO.jpg Speaker Features •Neodymium Woofer Magnet •Shorting Sleeve Heatsink (patented) •Thermal Management System (patented) •Cross-Rib Glass Fiber Cone •Ring Radiator TW Design w/ 25mm VC •Multi-roll Surround •Cast Aluminum Frame & Network Box •Multiple Crossover Tuning Options with minimum phase shift Crossover Features •Thermally Coupled Cast Aluminum Chassis •TO-220 Power Resistors with AL Heatsinks •Heavy Gauge Air Core Inductors •Metalized Poly Capacitors •Phase Linkage Setting module •4-level TW adjustment •Bi-amp capability •TW protection •Gold Plated Insert Terminals w/tab Specifications •300 Watt Peak Power •100 Watt RMS •Frequency response: 35Hz – 60kHz •Sensitivity: 89,5dB/W (1m) •Insatallation Diameter: 134 mm •Depth: 63 mm ___________________________________________ |
Re: Alpine SXE-1750s vs Alpine SPX-17PRO
Buget?
cred ca ti-ai raspuns singur, avand in vedere ca optiunea nr.2 din 'grila ta' costa ~1700 RON ...
e foarte important daca le pui pe HU stock, daca le amplifici, daca ai masina insonorizata. sincer, in bugetul 0 - 300 RON orice ai alege e cam acelasi lucru daca nu le amplifici. Difurile stock sunt Blaupunkt si sunt niste trompete(clar, niste trompete masurate si adaptate de producator pentru incinta care se creeaza). Passatul este o masina foarte bine 'inchegata', personal detin si stiu ce zic. E o alegere perfecta pentru SQ dar evident, bugetul e intotdeauna o problema:twisted: Stima. |
La 100 euro exista niste japane care suna foarte "eschiu" (sq), dar depasesc.
As pune un set doar pe fata, asta in conditiile in care planuiai sa iei doua seturi de 200ron:). |
| All times are GMT +2. The time now is 23:55. |
