LEGENDARA TOYOTA Corolla AE86
6 Attachment(s)
Cred ca multi dintre voi ati auzit de legendara Toyota Corolla AE86....
Eu ma numar printre putinii detinatori ai acestei minunate masini...... cred ca ar fi frumos sa impartasesc experienta mea cu aceasta masina la toata lumea.Mai jos sunt specificatiile tehnice ale masinii...sunt in engleza(in romana nu am reusit sa le gasesc)dar cine are de inteles intelege 1983-1987 Toyota Corolla Trueno/Levin AE86 specifications: BODYWORK Code: AE86 Type: 2+2 (coupe/hatchback) Number of doors: 2 (coupe), 3 (hatchback) DIMENSIONS & WEIGHT Wheelbase: 2400 mm Track width: front_ 1355 mm, rear_ 1345 mm Length: 4285 mm Width: 1625 mm Height: 1335 mm Kerb weight: 950 kg (coupe), 970 kg (hatchback) Weight distribution: 53:47 (%) front:rear Fuel capacity: 50 litres AERODYNAMICS Drag coefficient: 0.35 ENGINE Code: 4A-GE(U/C/L) Type: Inline 4, wet sumped, DOHC, 16 valves (4/cylinder), fuel injected, normally aspired, water cooled, T-VIS large-port Bore x stroke: 81.00 x 77.00 mm Bore / stroke ratio: 1.05 Displacement: 1587 ccm Unitary displacement: 396.75 ccm/cylinder Compression ratio: 9.4:1 or 10.2:1 Max power: 91 kW (124 hp) @ 6600 rpm Max torque: 145 Nm @ 5200 rpm Max engine speed: 7700 rpm Specific output: 78 hp/litre Specific torque: 91 Nm/litre CHASSIS Engine location: front Engine alignment: longitudinal Steering: rack & pinion Suspension: FRONT_ MacPhaerson strut & coil spring & sway bar, REAR_ multilink & coil spring & sway bar (solid axle) Wheels: 5.5x13" or 5.5x14" or 6x14" Tyres: 185/70 HR13 or 185/60 HR14 Brakes: front_ vented discs 234 mm, rear_ discs 231 mm (servo asisted) TRANSMISSION Code: T50 Type: 5-speed manual GEAR RATIOS: 1st: 3.587 2nd: 2.022 3rd: 1.384 4th: 1.00 5th: 0.861 Reverse: 3.48 Final Drive: 4:30:1 Clutch-Type LSD PERFORMANCE 0-100 km/h: 8.5 s 1/4 mile: 16 s Top speed: 200 km/h Power to weight ratio: 130 hp/tone Cam astea ar fi specificatii tehnice..... Fostul proprietar a participat cu masina la 3 raliuri;momentan este masina de day-by-day dar o mai pun si eu la incercare cateodata.... Ce as mai putea sa zic este o masina fantastica,motorul foarte reusit a fost refacut acum 3 ani la cota R1,am schimbat pe ea pompa de frana si acum ma chinui cu alternatorul ceva bucse,amortizoare si arcuri sport Koni,franele sunt pe disc fata si spate,discurile fata ventilate,ambreiaj hidraulic,injectie,computer de bord....tot tacamul totul este electronic la ea.... |
Re: legendara Toyota Corolla AE86
8 Attachment(s)
numarul de inmatriculare din fata e cam sifonat un pic (a mai mers nevata-mea cu masina :lol:) motiv pentru care l-am schimbat
6 Attachment(s)
..........interior..............
proud 100% drift car:)
foarte tare masinica ... imi place cum arata si ca ai grija de ea ...
spor la treaba si sa ai parte de ea cat vrei tu ... |
in "vremurile de demult" masina asta avea si roll cage. Am admirat-o de multe ori pe strada.
Felicitari si ai grija de ea, pentru ca e masina la care visam acu vreo cativa ani :D |
si mai ai rollcage-ul? poate reusesc sa il adaptez la trotineta mea...
s-o stapanesti sanatos. excelenta masina. cunoscuta si sub numele de toyota cellica twincam, celebra pt particparile in grupa B de raliuri intre '84-'86...parca a castigat si safari-ul sau kenya o data, in fata quttro-ului si-al lui 205t16.
ai grija de ea, e-o bucata de istorie pe roti... |
Re: Legendara Toyota Corolla AE86
salut am si eu o intrebare ce tip de injectie ai pe ea
| All times are GMT +2. The time now is 08:33. |
