pachet audio statie BlaupunktGTA480,woofer magnat 300w rms boxe hertz DSK 170.3
vand pachet statie:Blaupunkt GTA 480, cu următoarele specificații, Max. power 4 x 160 / 2 x 425W into 4 ohms
Max. power 4 x 210 W into 2 ohms RMS power 4 x 75 / 2 x 210W into 4 ohms RMS power 4 x 105W into 2 ohms Direct aux-input feature (front / rear stereo channels with 3.5mm stereo jack plug connectors) allows MP3 Walkman or navigation system to be plugged directly into to amplifier and mixed with other signal sources. Volume levels of each source can be independently set Frequency response 10 Hz - 35 kHz Signal to noise ratio > 95dB/A THD at rated power < 0.03% Input impedance > 10 kOhms 2 ohm stability (4 ohm bridged) Input signal 0.3 - 8.0V Front and rear channel low pass filter: 50 - 250Hz variable Front and rear channel high pass filter: 50 - 250Hz variable Front and rear channel bass boost 0 - 12dB at 45Hz Front and rear channel crossover selector subwoofer Magnat 300w rms incinta seald ocupa putin spatiu boxe hertz DSK 170.3 set componente in garantie achizitionate in mai 2012 diametru midbass - 170 mm crossovere pasive tip "pe fir" magnet din ferita con din hartie presata putere nominala - 80W RMS putere maxima - 160W raspuns in frecventa - 50-23kHz sensibilitate - 93dB impedanta - 4ohmi Bonus set cabluri montaj Pret pachet 600 lei Pe componente statie 200 lei, subwoofer 220 lei, boxe 250 lei Contact 0765325903 |
Re: pachet audio statie BlaupunktGTA480,woofer magnat 300w rms boxe hertz DSK 170.3
Ceva poze se poate?
7 Attachment(s)
la cerere am postat si poze
up..... pachetul sta degeaba stare foarte buna, boxele sunt in garantie achizitionate de la be l o u d
up..... pachetul sta degeaba stare foarte buna, boxele sunt in garantie. Pentru pachet complet pret 530 lei pe componente ramane lafel
up..... stare foarte buna, boxele sunt in garantie. Pentru pachet complet pret 530 lei pe componente ramane lafel
Salut. Schimbi cu 2 tv auto pt tetiere cu dvd player usb slot de card SD tv tuner si telecomenzi?
nu, multumesc.
up...up..... stare foarte buna, boxele sunt in garantie. Pentru pachet complet pret 530 lei pe componente ramane lafel
Statia s-a dat. Yuhuuuuu!!!!! :D
ultim pret la boxe >?
up:::::::::::::::::::::::::::::::::::::::::::::::: :::::::::::::::::
subwoofer Magnat 300w rms incinta seald ocupa putin spatiu boxe hertz DSK 170.3 set componente in garantie achizitionate in mai 2012 diametru midbass - 170 mm crossovere pasive tip "pe fir" magnet din ferita con din hartie presata putere nominala - 80W RMS putere maxima - 160W raspuns in frecventa - 50-23kHz sensibilitate - 93dB impedanta - 4ohmi |
up---------------
