Go Back   Forum 4Tuning > AUTO COMERCIAL > Bazar CAR AUDIO > Pachete Audio: Statie+Sub, HU+difuzoare, etc
Pachete Audio: Statie+Sub, HU+difuzoare, etc Pachete Audio: Statie+Sub, HU+difuzoare, etc
Old 09-01-13, 19:29   #1
p_vio46
p_vio46's Avatar
Default pachet audio statie BlaupunktGTA480,woofer magnat 300w rms boxe hertz DSK 170.3
vand pachet statie:Blaupunkt GTA 480, cu următoarele specificații, Max. power 4 x 160 / 2 x 425W into 4 ohms
Max. power 4 x 210 W into 2 ohms
RMS power 4 x 75 / 2 x 210W into 4 ohms
RMS power 4 x 105W into 2 ohms
Direct aux-input feature (front / rear stereo channels with 3.5mm stereo jack plug connectors) allows MP3 Walkman or navigation system to be plugged directly into to amplifier and mixed with other signal sources. Volume levels of each source can be independently set
Frequency response 10 Hz - 35 kHz
Signal to noise ratio > 95dB/A
THD at rated power < 0.03%
Input impedance > 10 kOhms
2 ohm stability (4 ohm bridged)
Input signal 0.3 - 8.0V
Front and rear channel low pass filter: 50 - 250Hz variable
Front and rear channel high pass filter: 50 - 250Hz variable
Front and rear channel bass boost 0 - 12dB at 45Hz
Front and rear channel crossover selector
subwoofer Magnat 300w rms incinta seald ocupa putin spatiu
boxe hertz DSK 170.3 set componente in garantie achizitionate in mai 2012
diametru midbass - 170 mm
crossovere pasive tip "pe fir"
magnet din ferita
con din hartie presata
putere nominala - 80W RMS
putere maxima - 160W
raspuns in frecventa - 50-23kHz
sensibilitate - 93dB
impedanta - 4ohmi
Bonus set cabluri montaj
Pret pachet 600 lei Pe componente statie 200 lei, subwoofer 220 lei, boxe 250 lei
Contact 0765325903
p_vio46 is offline   Reply With Quote
Old 10-01-13, 01:28   #2
Ruffy RUF
Ruffy RUF's Avatar
Default Re: pachet audio statie BlaupunktGTA480,woofer magnat 300w rms boxe hertz DSK 170.3
Ceva poze se poate?
Ruffy RUF is offline   Reply With Quote
Old 10-01-13, 18:53   #3
p_vio46
p_vio46's Avatar
la cerere am postat si poze
ID:	2656087   Click image for larger version
ID:	2656088   Click image for larger version
ID:	2656090   Click image for larger version
ID:	2656091   Click image for larger version
Old 16-01-13, 18:03   #4
p_vio46
p_vio46's Avatar
up..... pachetul sta degeaba stare foarte buna, boxele sunt in garantie achizitionate de la be l o u d
Old 20-01-13, 22:32   #5
p_vio46
p_vio46's Avatar
up..... pachetul sta degeaba stare foarte buna, boxele sunt in garantie. Pentru pachet complet pret 530 lei pe componente ramane lafel
Old 27-01-13, 15:57   #6
p_vio46
p_vio46's Avatar
up..... stare foarte buna, boxele sunt in garantie. Pentru pachet complet pret 530 lei pe componente ramane lafel
Old 04-02-13, 18:06   #7
B123HAI
Salut. Schimbi cu 2 tv auto pt tetiere cu dvd player usb slot de card SD tv tuner si telecomenzi?
B123HAI is offline   Reply With Quote
Old 04-02-13, 20:54   #8
p_vio46
p_vio46's Avatar
nu, multumesc.
Old 09-02-13, 17:37   #9
p_vio46
p_vio46's Avatar
up...up..... stare foarte buna, boxele sunt in garantie. Pentru pachet complet pret 530 lei pe componente ramane lafel
Old 13-02-13, 00:04   #10
fuzzy
Dacia Driver
fuzzy's Avatar
Statia s-a dat. Yuhuuuuu!!!!!
fuzzy is offline   Reply With Quote
Old 13-02-13, 16:05   #11
sitak
ultim pret la boxe >?
sitak is offline   Reply With Quote
Old 13-02-13, 20:28   #12
p_vio46
p_vio46's Avatar
Să o stapānești sănătos și la cāt mai mulți decibeli și reglaje fine. Ramān la vanzare subwoofer ul și boxele. In aceste condiții preț pachet subwoofer plus boxe 400 lei. stare impecabila.
Old 16-02-13, 12:54   #13
p_vio46
p_vio46's Avatar
up:::::::::::::::::::::::::::::::::::::::::::::::: :::::::::::::::::
magnet din ferita
impedanta - 4ohmi
Old 05-03-13, 19:12   #14
p_vio46
p_vio46's Avatar
magnet din ferita
impedanta - 4ohmi
Old 14-03-13, 21:59   #15
p_vio46
p_vio46's Avatar
up---------------
