Vand Amplificator ALPINE
Statie auto Alpine V12 MRD-M605 / Mono / Class-D / MOSFET .........
Alpine's MRD-M605 is a monster mono machine, ready to deliver the big watts to your subs. This powerful Class-D member of Alpine's V12 amplifier series delivers 600 watts of bass-bumping power to a 2-ohm load (400 watts at 4 ohms) — an outstanding way to get the shake on with a sub or two! It runs ice cold even in summertime for extended periods of time. Provides plenty of power. The MRD-M605 features computerized digital controls that are second to none. Top-mounted Bass Engine digital controls allow a high level of fine-tuning, including a subsonic filter to remove inaudible, power-wasting ultra-low frequencies and Bass EQ, adjustable from 0-16 dB at 45 Hz. Specificatii * AccuClass-D amplifier * RMS Power at 2 Ohms 600 W x 1 channel * RMS Power at 4 Ohms 400 W x 1 channel * Peak Power Output 900 W x 1 channel * Minimum Impedance Unbridged 2 ohm * THD at Rated RMS Power 0.8% * Internal, variable-speed cooling fan * MOSFET power supply and output stages * STAR Topology for cleaner sound * Bass Engine® features: - Low-pass digital filter, 30-200 Hz, with a selectable 12 or 24 dB/octave slope - Selectable subsonic filter (off, 15Hz, or 30 Hz) - Parametric EQ variable from 30-160 Hz, ±12 dB - Bass Compensator enhances low-end definition * Top-mounted digital control center with cover * CEA-2006 Compliant * Preamp outputs * Time correction 0-10 milliseconds in 0.1ms steps * Phase adjustment 0-180 * Turn-on delay * Requires 4-gauge power and ground leads * Extra-large terminals * Fuse rating: 30A x 2 pret 600ron .....neg sau schimb.....diverse |
Re: Vand Amplificator ALPINE
Salut,
Iti ofer la schimb o unitate Car PC fara alimentare: https://forum.4tuning.ro/555-hu-cd-pl...incomplet.html Daca te intereseaza in principiu, iti dau detalii suplimentare prin mesaj privat. Daca nu, spor la vanzare! |
nu ms....astept oferte
Salut!
schimbi cu un subwoofer Pioneer TS-W3001D4 nou?eu nu am amplificator pentru el si il tin degeaba,vreau sa imi iau ceva mai mic. |
ms de oferta dar am un subwoofer
nu vrea nimeni un amplif de putere?
valabil
valabil.....astept oferte
valabil
sall!! te intereseaza un schimb cu un nokia 6500 un amplificator auto sony xmz704+ o diferenta de bani?? app pune si u un nr de tel si niste date de contact
Un amplificator tot monobloc Alpine MRP-450 400x1@2ohm, si o diferenta de banuti care astept sa mi`o spui tu...sau un amplificator in 4 canale 4x100@4ohm JBL GTO-75.4, ambele sunt in stare perfecta, nu le mai folosesc de un an si jumatate.
Sa ai o zi buna si discutam daca doresti. |
cati bani vrei pt amplificatorul JBL? accepti si schimburi?? pauncosmin21 este id-u meu bagal si vb mai mult acolo
Schimi cu alta statie 2x320 rms..Stima
scz ca nu am raspuns dar am fost plecat din tara.....anuntul mai e valabil astept ofertele voastre
| All times are GMT +2. The time now is 11:26. |
