-   -   Tuning extrem - 1.8T in Formula 2 (https://forum.4tuning.ro/23-generalitati-tuning/107304-tuning-extrem-1-8t-formula-2-a.html)
Nautilus 02-02-09 10:37
Williams F1 construieste un model de Formula 2 care va fi propulsat de o versiune modificata a motorului VW/Audi 1.8T.
http://www.formulatwo.com/f2carthef2car.aspx
F2 engine
The F2 car is powered by an Audi 1.8 litre turbo engine with a target 400bhp on standard boost and 450bhp on overboost. The engines on all cars will have identical power within 1.5% of the target. The overboost facility is actuated by a steering wheel button which increases maximum power by 50bhp for a duration as specified on the set-Up sheet, typically six seconds. Overboost may not be used except in the second practice session and in each of the races, when the number of shots will be specified on the set-up sheet but typically eight shots are available for races and four available for tests.
http://www.formulatwo.com/media/70900/engine%20copy.jpg
The engine is a new turbocharged unit based on the Audi 1.8 litre 20 valve block and head, as used in Formula Palmer Audi. Whereas the engine in the FPA car uses standard road car components pretty much throughout, the F2 engine has been developed as a pure race engine. The crankshaft, con rods, pistons, valves and camshafts are all new components designed for high strength and light weight.The dry sump system has been re-designed so the engine sits 35mm lower than in the FPA car.
The turbocharger is an all new Garrett GT35 unit featuring roller bearings for improved response with an external wastegate with high speed closed loop pneumatic valve boost control for absolutely precise automatic boost control.
The engine management system is the latest Pectel ECU, the MQ12, which will provide vastly more capability than the unit in FPA.
Sursa: VW Vortex
The 1.8-litre turbo-charged Audi engine that will power each Formula Two car next season has undergone a successful dyno test at Mountune Racing's headquarters.
A dynamometer or 'dyno' test measures the torque and rotational speed produced by an engine, which generates the power needed to drive the vehicle.
The F2 engine reached its 450bhp overboost power target and tests will now continue to measure its reliability and endurance at this power level and the race power of 400bhp. Overall, the engine will be able to rev up to 8500rpm.
The official Formula Two website will be following the progress of the cars as they are constructed ahead of the scheduled first test later this year. Keep visiting the website for the latest news and videos.
Sursa: VW Vortex
F2: A closer look
~Nautilus
PS BMWistilor le place sa se laude cu motorul M12 din F1 si F2, acum afla ca se mai poate si la altii :D
Nautilus 21-03-09 19:11
Re: Tuning extrem - 1.8T in Formula 2
Noul monopost de Formula 2 a fost lansat oficial
Organizatorii Formulei 2 au dezvaluit oficial monopostul construit de Williams ce va fi utilizat in aceasta competitie.
Formula 2 a fost creata cu scopul de a deveni o alternativa viabila pentru GP2, competitia din care au promovat in ultimii ani mai multi piloti de top spre Formula 1, printre care Lewis Hamilton, Nico Rosberg sau Timo Glock.
Competitia va utiliza un monopost unic creat de Williams, iar noua masina a fost prezentata oficial joi pe circuitul de la Brands Hatch din Marea Britanie. Frank Williams, seful echipei Williams, crede ca noua competitie va rivaliza cu GP2 si spune ca a fost impresionat de costurile foarte mici ale dezvoltarii noii masini.
[img]http://static.**************/img/auto_resized_v2/db/article/018/845/719361l-576x432-h-7fa68919.jpg[/img]
http://www.**************/stiri/noul-...ial-18845.html
~Nautilus
