Re: Fiat Punto HGT
frumos foc!!! poate data viitoare il vad live ce pot sa faca cei 130 de calutzi...
Re: Fiat Punto HGT
razvan felicitari pt locul obtinut!imi cer scuze pt ca nu te-am mai sunat,vb zilele urmatoare.
Re: Fiat Punto HGT
Baieti se vinde HGT-ul!Nu e ieftin dar e fantastic!Daca trebuie cuiva vorbim pe pm!Mersi si bafta si An nou fericit!
Re: Fiat Punto HGT
salut ... tocmai am intrat si eu in posesia unui HGT galben ... trage bine ... si sistemul de sunet standard e super :)
Re: Fiat Punto HGT
sa ai parte de el !!! are vreun tuning mai special ???
Re: Fiat Punto HGT
Re: Fiat Punto HGT
Re: Fiat Punto HGT
sal
am si eu un punto din 2001 si vreau niste recomandari de tunning |
Re: Fiat Punto HGT
Re: Fiat Punto HGT
[quote=brautomobile;681015]Baieti se vinde HGT-ul!Nu e ieftin dar e fantastic!
Anuntul e inca valabil! |
Re: Fiat Punto HGT
Baieti se vinde HGT-ul!Nu e ieftin dar e fantastic!Daca trebuie cuiva vorbim pe pm!Mersi si bafta si An nou fericit![/quote]
Re: Fiat Punto HGT
10 Attachment(s)
FIAT PUNTO HGT
Engine Position: 4 cylinders in line, fitted transversally Bore: 82,0 mm Stroke: 82,7 mm Compression ratio: 10.3:1 Capacity: 1747 cc Max power: 96 kW/130 HP at 6,300 rpm Torque: 164 Nm (16.7 kgm) at 4,300 rpm Two head camshafts distribution (DOHC) Variable phase variator on inlet camshaft 4 valves per cylinder air inlet variable geometry MPI electronic phased injection returnless electronic ignition integrated with injection Trasmission Front wheel drive Hydraulic clutch guide Gear ratios: 1st gear 3.909 2nd gear 2.238 3rd gear 1.520 4th gear 1.156 5th gear 0.872 Reverse: 3.909 Final ratio: 3,867 (58/15) Tyres 185/55 R15 195/45 R15 (alternative) Consumption Urban: 11.5 k/100 km Mixed: 8.3 l/100 km Extraurban: 6.4 k/100 km At 120 km/h: 8.3 l/100 km Performance Max speed: 205 km/h Acceleration 0-100 km/h: 8.6 seconds Acceleration 0-1000m: 30.0 seconds E de vanzare si ni se compara la performante cu nici un alt punto!Masina asta e un cart.Si e de vanzare! |
Re: Fiat Punto HGT
hei guys!nu mai posteaza nimeni p 2007?
Re: Fiat Punto HGT
Re: Fiat Punto HGT
| All times are GMT +2. The time now is 00:17. |
