-   Masina mea Fiat (https://forum.4tuning.ro/118-masina-mea-fiat.html)
-   -   Fiat Punto HGT (https://forum.4tuning.ro/118-masina-mea-fiat/13328-fiat-punto-hgt.html)
brautomobile 01-02-07 20:19
Re: Fiat Punto HGT
Baieti se vinde HGT-ul!Nu e ieftin dar e fantastic!Daca trebuie cuiva vorbim pe pm!Mersi si bafta si An nou fericit![/quote]
brautomobile 05-02-07 19:31
Re: Fiat Punto HGT
10 Attachment(s)
FIAT PUNTO HGT
Engine Position: 4 cylinders in line, fitted transversally
Bore: 82,0 mm
Stroke: 82,7 mm
Compression ratio: 10.3:1
Capacity: 1747 cc
Max power: 96 kW/130 HP at 6,300 rpm
Torque: 164 Nm (16.7 kgm) at 4,300 rpm
Two head camshafts distribution (DOHC)
Variable phase variator on inlet camshaft
4 valves per cylinder
air inlet variable geometry
MPI electronic phased injection
returnless electronic ignition integrated with injection
Trasmission Front wheel drive
Hydraulic clutch guide
Gear ratios:
1st gear 3.909
2nd gear 2.238
3rd gear 1.520
4th gear 1.156
5th gear 0.872
Reverse: 3.909
Final ratio: 3,867 (58/15)
Tyres 185/55 R15
195/45 R15 (alternative)
Consumption Urban: 11.5 k/100 km
Mixed: 8.3 l/100 km
Extraurban: 6.4 k/100 km
At 120 km/h: 8.3 l/100 km
Performance Max speed: 205 km/h
Acceleration 0-100 km/h: 8.6 seconds
Acceleration 0-1000m: 30.0 seconds
E de vanzare si ni se compara la performante cu nici un alt punto!Masina asta e un cart.Si e de vanzare!
axu86 08-03-07 05:25
Re: Fiat Punto HGT
hei guys!nu mai posteaza nimeni p 2007?
brautomobile 27-04-07 20:38
Re: Fiat Punto HGT
Originally Posted by brautomobile (Post 733085)
FIAT PUNTO HGT
Bore: 82,0 mm
Stroke: 82,7 mm
Capacity: 1747 cc
Gear ratios:
1st gear 3.909
2nd gear 2.238
3rd gear 1.520
4th gear 1.156
5th gear 0.872
Reverse: 3.909
Tyres 185/55 R15
Mixed: 8.3 l/100 km
Pret nou 6900 euro.
staticx 28-08-07 22:55
Re: Fiat Punto HGT
Originally Posted by car_manyac (Post 343111)
Fiat Punto e o masinuta super.Cred ca e cea mai reusita din gama fiat ma refer la fiabilitate, calitate, pret.Nu o poti compara cu nici o masina din clasa ei adik corsa sau polo.E f f stabilta iar HGT tin sa spun ca rupe.A fost unu si la raliu si in cate stiu deabia il tineau fetele la raliu pe sosea mergea de rupea.Si eu am un Bravo din 2001 si sunt f multumit.E comfortabila spatioasa materiale de buna calitate stabila trage super si consuma si putin iar intretinerea pana acum nu a fost deloc costisitoare.Ce sa zic singura problema a fiatului e ca are tabla mai moale poate fi bine si poate fi rau depinde cum e ei adik la accidente se strica ea cam toata dar u scapi ca atenueaza mult din impact dar e nasol ca mai sunt dobitoci prin parcari care nu se uita si uite surpriza.In rest rugina nu o sa vezi pe ea pt ca are toata caroseria galvanizata iar fiat ofera chiar garantie la tabla.Ce sa mai zic vb sunt vb eu zic sa te convingi si nu vei regreta.P.S.Fara comentarii Fiat nu mai e ce a fost asa ca nu mai tot comentati aiurea fara sa stiti.
true :)....
denver 30-08-07 19:01
Re: Fiat Punto HGT
fiat punto rugina ? adica nu aveam eu rugina pe fiat 600 din `62 si are punto O.o si inainte sa o cumpar nu era ingrijita deloc rugina e cam certata cu fiaturile in general nu prea se intalnesc decat dak o ia cnv sa care cu ea si sa o ingrijeasca cat mai putin la cum sunt tratate niste masini in romania nici nu ma mira....
george04 12-12-07 23:21
Re: Fiat Punto HGT
sal
am si eu un punto HGT, dar de putin timp (2 luni), si are doar 30 000km asa ca probleme nu am...faza cu marsarierul care nu intra la rece am patit-o si eu de 2 ori, nu stiu despre ce e vb...poate-i vina soferului....:oops:
de tras, trage motorul cu muuult entuziasm, are cuplu mare, iar 130CP la 1050 kg...., iti trebuie minim 200CP la o masina de familie de care se conduce pe la noi (A4, A6) ca sa compari. mi-s amator, si tot m-am tinut dupa BMW-uri usor, chiar depasit. vrei masina f fiabila, uite in japonia, germanii nu mai sint ce-au fost, fiabilitatea e data de marja de eroare acceptata pe linia de productie...., iar nemtii nu mai stau bine la asta, iar cineva spunea ca punto a scos fiatul din c... prin fiabilitate, si e adevarat, chiar daca nu se cheama honda sau toyota. consuma 10l/100km in oras, si nu pustiu, autostrada 120km/h 8l/100km. singura problema pe care-o vad eu, centrul de greutate prea ridicat si-n fata, dar e din clasa mica, n-ai ce-i face...., sau ai, ca eu ma gindesc la arcuri mai scurte si mai tari. ia-ti HGT, are suflet mare masina asta, iar eu nu-s artist de felul meu, ai sa te indragostesti de ea
Dumitrache Valeriu 10-01-17 18:53
Re: Fiat Punto HGT
Salut am si eu un fiat punto hgt,motor 18 tunning si vreau sa l vand deoarece plec din România.Este o mașina deosebită dar nu îmi mai folosește.De aceea m am înscris pe acest site poate dorește cineva sa o cumpere.Dacă este cineva interesat sa o cumpere ma poate contacta la 0737986911 sau pe whatsapp pot trimite poze.
Dumitrache Valeriu 10-01-17 19:22
Re: Fiat Punto HGT
Originally Posted by iosala (Post 315382)
Va salut.
Sunt un fan al italienelor si as vrea sa-mi achizitonez un Fiat Punto HGT si eram curios ce parere aveti despre aceasta masinuta. :roll: :D
Este o mașina deosebită dacă te interesează am de vânzare un punto HGT este un tanc de Masina dacă ai grija de ea dacă te interesează pot trimite niște poze pe whatsapp 0737986911 crede-mă nu ai mai văzut tunning asa frumos
