Old 22-10-11, 15:23   #1
Spot
Spot's Avatar
Default Vand sursa Recom Power Engine 550 Plus
Prezentare:
- sursa ATX12V v2.0 & EPS 12V
- Power Factor Correction
- protectii multiple: OVP, OPP, SCP
- ventilator 140 mm optimizat pentru operare silentioasa si flux de aer maxim
- ajustare automata a vitezei ventilatorului prin intermediul unui senzor
- conector ATX 20+4 pini, 1 conector PCI Express (6+2 pini) si 4 conectori SATA
- carcasa black coated pentru un look deosebit
Specificatii tehnice:
Cod producator: Power Engine 550 Plus
General
Tip ATX 2.0
Putere 550 W
Numar ventilatoare 1x 140mm
Voltaj/Amperaj +3.3V 25A
+5V 25A
+12V1 22A
+12V2 22A
-12Vsb 0.5A
+5Vsb 2A
Conectori ATX 20+4 pini
4 conectori SATA
PRET :120 RON
SURSA ESTE NOUA
0755.902.301
Spot is offline   Reply With Quote
Old 25-10-11, 08:22   #2
Spot
Spot's Avatar
Default Re: Vand sursa Recom Power Engine 550 Plus
vanduta! topic closed...
