Motor cu aburi in miniatura functionabil fabricat de Wilesco ,Made in West Germany,o piesa de mare finete si calitate facuta manual.Motorul nu a fost pornit niciodata ,este absolut impecabil,are rezerva de ulei,pastilele de combustibil(esbit) carticelele si cutia originala (aceasta este cu aspect invechit avand in vedere perioada in care a fost fabricata).
Detalii de pe siteul oficial:
A fully working live steam engine from the range of WILESCO Hobby Technic
This technically perfect model has been painted in matching colours
A chemically black painted brass boiler, diameter 45 mm, length 185 mm, boiler volume 230 cm³ with water gauge glass
Powerful, double action reversible cylinder
Flywheel with a diameter of 80 mm
The showman's engine can be run in forward or reverse depending on the movement of the flywheel
Spring loaded safety valve, steam regulator, steam whistle, steam jet oiler and footbridge, traditional chain steering
A clutch engaged gear wheel permits the use of the engine and the operation of the dynamo either stationary or driving
The dynamo illuminates the eight diodes mounted around the canopy of the engine
The condensed water of this engine is collected below the smoke stack
Operating time about 15 minutes per fuel charge
All single parts are manufactured from finely painted metal. At the beginning of the twentieth century, this so called Showman's Engine could be found at every funfair
It was used to drive the showman's roundabouts and to provide illumination for the fairground. The oldtimers were decorated with bright colours and fitted with a dynamo so that they could generate their own electricity.
Pret:1000 RON
