Old 17-01-10, 20:51   #1
naka66vio
naka66vio's Avatar
Default E36 - STOK
salutare.as dori sa va prezint un bmw e36 din primele modele.an fabricatie 1991,motor 2.0 24v fara vanos,euro1,123 000km reali!!carte service,vopsea fara pic de zgarietura sau atinsatura,ca dotari as enumera:geamuri fata electrice,aer conditionat am impresia dublu,proiectoare,servodirectie,cass original si cam atat.masina a fost f intretinuta apartinand unui batranel are telescoape,baterie si cauciucuri 205 55 15 noi.eu am skimbat la ea un furtun de la radiator care crapase uleiul filtrele etc in rest totul este complet functional si pare nou inclusiv articulatia directia etc.ca planuri ar fi in curand cam asa:-suspensie
-semnale albe si stopuri m3
-nasul negru
-buza alpina fata(deja o am)
-vopsite pragurile si barile fata spate in culoarea caroseriei
-jante alpina
ID:	1268558   Click image for larger version
ID:	1268559   Click image for larger version
ID:	1268561   Click image for larger version
ID:	1268562   Click image for larger version
ID:	1268564   Click image for larger version
ID:	1268565   Click image for larger version
REVO ST3,APR RSC exhaust,ITG intake,Sachs Perfomance Clutch with SMF,QUAIFFE lsd,update breather kit,FORGE dv&bov,NEUSPEED dog bone,NEUSPEED rear sway bar link,H&R sway bars,EIBACH pro kit springs,BILSTEIN B8 shock absorber,VDO TURBO boost gauge,OZ ULTRALLEGERA 18"rims with MICHELIN PS2,AUTOTECH HPFP,S3 brakes pads DS2500,S3 intercooler,FORGE twincooler,IE rods,KO4 turbo,S3 injectors,S3 camshafts,RS4 FPR VALVE,Wot box,Boost controler,MOTUL fluids,CARBON LOOK.etc
naka66vio is offline   Reply With Quote
Old 17-01-10, 20:53   #2
naka66vio
naka66vio's Avatar
Default Re: BMW e36 STOK
inca cateva poze le am facut in seara asta pe inserat dar o sa fac si pe zi
ID:	1268573   Click image for larger version
ID:	1268574   Click image for larger version
ID:	1268576   Click image for larger version
Old 17-01-10, 20:58   #3
krocodilu
krocodilu's Avatar
ups...masinuta noastra..mica bestie..intr-adevar masina e foarte intretinuta si trage foarte bine,pentru un motor de 2.0
krocodilu is offline   Reply With Quote
Old 17-01-10, 22:24   #4
Madalin_e36
Madalin_e36's Avatar
Default Re: E36 - STOK
asa am auzit si io ca este tipla si asa este pare ingrijita
dar nu imi place culoare deloc
daca ii pui jante suspensie sport nu ii pui macar arcuri???
ca o sa arate aiurea
bft la modificari si cat mai multe:>:>
Madalin_e36 is offline   Reply With Quote
Old 17-01-10, 22:24   #5
Gyo*TDS
Gyo*TDS's Avatar
frumoasa pisica, se vede k a fost ingrijita si tinuta in garaj,am inteles k are si carte de service.Spor la treaba !
Gyo*TDS is offline   Reply With Quote
Old 18-01-10, 14:16   #6
AlexLst
AlexLst's Avatar
Frumoasa. S-o stapanesti sanatos , catii mai multi kim fara incidente.
AlexLst is offline   Reply With Quote
Old 18-01-10, 16:25   #7
turb0
turb0's Avatar
urmeaza un motor mai mare si ... turbo ?!
turb0 is offline   Reply With Quote
Old 18-01-10, 18:57   #8
Gyo*TDS
Gyo*TDS's Avatar
zici k e a lu EOS la exterior directore
Old 21-01-10, 23:51   #9
naka66vio
naka66vio's Avatar
azi iam vopsit nasul negru si montat semnalizarile albe.as dori sa intreb pe cineva daca stie cat este de greu de demontat si montat alt plafon.mersi
Old 22-01-10, 18:43   #10
Gyo*TDS
Gyo*TDS's Avatar
f bine ,te misti repede
cred ca sunt cateva ore de munca la plafon...
Old 22-01-10, 18:52   #11
Madalin_e36
hai cu o poza sa vedem cum ii sta cu nasul negru.
Old 23-01-10, 13:41   #12
Gycone
Gycone's Avatar
Sunt si eu interesat cam cat te duce taxa de inmatriculare. Sa ai parte de ea, a fost intretinuta.
Gycone is offline   Reply With Quote
Old 23-01-10, 18:03   #13
naka66vio
naka66vio's Avatar
pe mine unu nu ma intereseaza taxa de inmatriculare.dupa cum vezi masina este cu numere de spania.eu avand acte e pe numele meu si nare nici un rost sa o inmatriculez.)oricum taxa cred ca e destul de mare masina fiind euro1
Old 23-01-10, 20:13   #14
cEaska
renunti la skoda ?
cEaska is offline   Reply With Quote
Old 23-01-10, 20:21   #15
catageo
catageo's Avatar
Man ai devenit fan bmw? Cu E46-le ce se mai aude? Sa le stapanesti sanatos.
catageo is offline   Reply With Quote
