Vand sistem 1400 W RMS + 4 x 100 W RMS .
PRET 2000 EURO
Din sistem fac parte urmatoarele :
https://www.youtube.com/watch?v=-MdmhPHYgMQ&featur
AW1200V - 2sub x 700W RMS audioBahn + incinta din MDF pe compresie facuta dupa specificatiile wooferelor
# 12" subwoofer with two 4-ohm voice coils
# carbon composite cone with foam surround
# heavy-duty cast-aluminum basket
# power range: 50-700 RMS watts (350 watts per voice coil)
# peak power: 1400 watts
# frequency response: 20-500 Hz
# sensitivity: 94.65 dB
2000 RON wooferele + cutia
SUBWOOFER AMP BOSS BLADE DIGITAL MONOBLOCK
Amplifier Type Mono Channel
Bridgable Not Bridgable
RMS Power at 4 Ohms 1200 W x 1
RMS Power at 2 Ohms 2200 W x 1
RMS Power at 1 Ohms 3000 W x 1
Performance
Frequency Response 15 Hz - 150000 Hz
Signal to Noise Ratio 100 dB
THD at Rated RMS Power 0.01 %
Crossover / Equalizer
Bass Boost With Bass Boost
Low - Pass Frequency 50 Hz - 150 Hz
Other Features
MOSFET Circuitry Yes
1000 RON pentu statia MONOBLOCK
Polk Audio DB6500 - 2x100W Speakers + 2x100W tweeters
Driver Complement
Mid/Woofer 1 - 6-1/2" Diameter (16.51cm)
Polymer/Mica Composite cone with rubber surround
Tweeter 1 - 1" Diameter (2.54cm)
Silk/Polymer composite dome
Electrical
Overall Frequency Response 40Hz-23KHz
Nominal Impedance 4 ohms
Power Handling (continuous) 100 w
Power Handling (peak) 300 w
Efficiency 92 dB
Polk Audio DB6500
Driver Mounting Depth
Top Mount 2" (5.08cm)
Bottom Mount 2-5/16" (5.87cm)
Tweeter Mounting
Flush Mount Depth 1-1/4" (3.17cm)
Surface Mount Height 1-1/8" (2.86cm)
Cut-out
Driver Cut-out Diameter 5" (12.70cm)
Tweeter Cut-out Diameter 2" (5.08cm)
+Infinity Reference 6022i
# 2-way car speakers for 6-1/2" and 6-3/4" locations (pair)
# Plus One+ injection-molded polypropylene (IMPP) woofer cone with hi-roll rubber surround
# 1" rotating UniPivot textile dome tweeter
# Intermount III mounting system for fit in 6-3/4" openings
# 2-ohm impedance for extra power
# power range: 2-60 watts RMS (180 watts peak power)
# frequency response: 53-21,000 Hz
# sensitivity: 93.4 dB
# top-mount depth: 1-7/8"
MTX X Thunder 704X
# 4-channel car amplifier
# 70 watts RMS x 4 at 4 ohms (105 watts x 4 at 2 ohms)
# 210 watts RMS x 2 bridged at 4 ohms
# CEA-2006 compliant
# variable high-pass filter (40-8,000 Hz at 12 dB per octave) and low-pass filter (40-5,000 Hz at 24 dB per octave)
# speaker- and preamp-level inputs
# fuse rating: 30A x 2
# 4-gauge power and ground leads recommended
# 14-15/16"W x 2-1/4"H x 9-5/8"D
CD MP3 PIONEER PREMIER DEH-P780MP
http://www.pioneerelectronics.com/PU...H-P780MP?tab=B
Supertuner Supertuner IIID
24-Station/6-Button (18FM/6AM) Presets Yes
BSM (Best Stations Memory) Yes
Local Station Setting Selectable (4-Step)
Digital Radio Capability
XM Radio Ready Yes (GEX-P920XM Required)
Sirius Radio Ready Yes (SIR-PNR2 Required)
CD Player
1-bit D/A Converter 24-bit Burr Brown
CD-R/CD-RW Compatible Yes
AGC (Automatic Gain Control) Yes
Disc Title Memory Yes
Disc List Yes
Track Title List Yes
CD Text CD Text
MP3 Playback Compatibility
Codec Support MP3, WMA, WAV, iTunes AAC
File System ISO9660-1,-2, Romeo, Joliet
Max Directory 8
Max. Folder # 99
Max File # per Disc 999
Multisession Disc Play Yes
Random Play Folder/Disc
Repeat Play File/Folder
MP3 Bit Rate 8~320kbps or VBR
WMA Format WMA v7, 8, 9, 10
WMA Bit Rate 48~384kbps, VBR
AAC Format iTunes AAC
AAC Bit Rate 16~320kbps
File Name 64 bytes
Folder Name 64 bytes
ID3/WMA Tag ID3 v1.0, 1.1, 2.2, 2.3, 2.4; WMA; iTunes AAC
Tag Length 64 bytes
Tag Data Track, Artist, Album, Comment
List Search File and Folder
iPod Control Capability
iPod Control Capability Adapter (CD-IB100II required)
Additional System Expandability
IP-Bus System Control Yes
Multi-CD Control Yes
DVD Control Yes
Display Output Yes
Built-in Auxiliary Input Built-In (Rear)
Optional (IP-Bus) Auxilary Input CD-RB10 or CD-RB20 required
External Unit Control 2
Display Features
Face Type Flap Face
Motorization Auto Slide Motorized
Display Type Full-Color Organic EL (OEL)
Dot Matrix OEL Size 256 x 64
Customizable Screensavers Update by CD-R
Screensaver Studio website
www.pioneer.co.jp/car/pclink4a/
Screensaver Movies 1
Multi-Language English, French, Spanish
Background Animations 5
Background Pictures 8 + Slideshow
Spectrum Analyzers 1
Level Indicators 1
Button (Key) Illumination All-Blue
Audio Features
Built-in Speaker Power MOSFET 50W x 4
Continuous Power Output 22W x 4
Equalizer 16-Band Graphic
Equalizer Presets 5
User Equalizer Settings 2
Loudness Yes
DSP Yes
Listening Position Selector Yes
BBE Digital Yes
Electronic Balance/Fader Yes
Source Level Adjuster (SLA) Yes
Crossover Network 3-Way Crossover
High-Pass Crossover (HPF) 50/63/80/100/ 125/160/200Hz, 0/-6/-12dB/Oct.
Subwoofer Crossover (LPF) 50/63/80/100/ 125/160/200Hz, -6/-12/-18dB/Oct.
Subwoofer Direct Control Key Yes
RCA Preouts 3 pair (Front, Rear, Sub/Non-Fading)
Preout Voltage & Impedance Hi-Volt (5V), 100 ohm
General Features
Volume Control Rotary Commander
Operation Mode Rotary Commander
Remote Control 10-Key Card
Wired Remote Input Yes
Cellular Mute Yes
Detachable Face Security Yes
Face Case (Included) Yes
1200 RON MP3-ul
Pyle
6 Farad Digital Hybrid Power Capacitor
Features
* 4 Digital Blue Display
* 2 Pcs 4 AWG Chrome Ring Terminals
* 2 Pcs Blue LED Diodes
* Neon Glowing Light Bars
* Custom Stainless Steel Cap
* Dimensions: 6.13''W X 4.75''L X 2.13''H
+ KITUL DE CABLURI
