statie alpine mrp-m450
* CEA-2006 Power Rating (40hm@14.4V = 1%THD+N), S/N 65dBA (Ref. 1W into 4Ohm): 220W x 1
* RMS Power (at 14.4V THD+N, 20Hz-20kHz):
o Per channel into 4 ohms: 220W x 1 (1% THD)
o Per channel into 2 ohms: 400W x 1
o Bridged 4 ohms: 600W x 1
* Bass Engine Sound Tuning:
o Crossover Frequency : 50Hz-200Hz,-24dB-oct (LP)
o Subsonic Filter (Fixed): 15Hz
o Bass EQ Frequency (Fixed): 50Hz 0 to +20dB
* Frequency Response: 20Hz - 200Hz (+3/-3dB)
* Signal to Noise (S/N): 90dBA (Reference to Rated Power)
* Input Sensitivity (For Rated Power): 0.2V to 4.0V (1.0 at Center Detent)
* Input Impedance: 10k Ohm
* Power Requirements: 14.4V DC (11V to 16V)
* Fuse Type: 20A x 2
* Dimensions (W x H x D): 9-11/16" x 2-23/64" x 9-31/64" (245.6mm x 60mm x 241mm)
* Weight: 2.8 kg.
subwoofer alpine sbe-1243br
# Acrylic window with blue illumination
# 12" Type-E Subwoofer
# Peak Power: 800W
# RMS Power: 250W
statie este fixata pe subwoofer, de aceea le vand doar impreuna
sunt relativ noi, le-am folosit cam 3 luni. achizitionate in ianuarie 2008. nu mai am cutiile, manualul de la statie cred ca il am daca este necesar
pret 6.5 mil negociabil
tel : 0728904222 ( traian )
id mess : aproapeom
oras : bucuresti
se pot proba, daca aveti deja instalatia facuta. ( le pot pune si la mine pe masina, dar sunetul difera de la masina la masina si nu cred ca e relevant ; poate doar sa vedeti ca functioneaza )
