Dupa cum spune si titlul, la sfirsitul lunii august imi vine citeva scule audio
care cred ca e pacat sa le scapati.
am posibilitatea sa aduc urmatoarele scule audio ( si nu numai):
1.--condensator
1f marca
Toxic 60euro
2.--condensator
5f/ 12f/ 20f marca
Impulse PCA-20000
Pret:150/200/250e
3. Statie
Auto SPL 6canale,
Mosfet 1400w( With the AV035.1 receive you very much sound and 6 channels for your money. 2 front, 2 Rear, 1 center as well as a Subwoofer exit is available. The amplifier is equipped with a MOSFET power pack and with it short-circuit and overloading surely. Technical data: Bass Boost 90 cycles per second·4 ohms stably·Infinitely variable by 0-12 railways·
Subwooferfrequenz adjustable by 30 - 180 cycles per second.)
Pret:135e
4.--
Kit RAVELAND POWER PACKAGE XAB 1200. contine statie, 2boxe 6/9 si subw.descrierea
A set of the superlative with capability characteristics, which might be singular in this preisklasse. The set consists 4 channel high speed output stage, a lit Subwoofer and a pair of 6 x 9? Oval loudspeakers. The set is co-ordinated acoustically one on the other and produces a strong and magnifying glass-pure klangbild. Supereffect: The Woofer is illuminated by a light emitting diode and the Logo on the cap of the covering grid plate likewise. This light effect will catapult you in the Car HiFi scene to the Insider.
Technical data: Output stage XAB 1200: Achievement 1200 W max (max/RMS 4 x 300/120 W)·Frequency range 5 - 50,000 cycles per second·2? stably·Adjustably of 2 to 3 channel enterprise·Abm. (B x H x T): 250 x 59 x 345 mm. Subwoofer XS 1200: With lit 12?
Woofer and Logo cap·Maximum stress max/RMS 700/350 W·Frequency range 20 - 160 cycles per second·Impedance 4?·Anthrazit/blau farbene felt surface·12 V connection terminals·Abm. (B x H x T): (295 x 445) x 375 x 440 mm.
Speaker XL 1200: 6 x 9? Oval loudspeaker·3 ways system·Maximum stress max/RMS 300/150 W·Frequency range 45 - 20,000 cycles per second - impedance 4?·Removable lattices·Abm.(B x H x T): 260 x 120 x 175 mm. )
Pret:195e
5.--
Statie Sony Xm4060Gtx, 4kanale: ( Perfektes Soundstaging mit der brandneuen XM-GTX Endstufe. Der 3/4 Kanal-Amp macht den Sound im Car zum Konzerterlebnis. Kräftige Ausgangsleistung und die unverwechselbare Musikalität sind die Merkmale der Sony XM-GTX Serie. Ausstattung: 4 x 100/4 x 50 W (Max.Sin) · Variabler Hoch- und Tiefpassfilter (50 - 300 Hz) · Frequenzgang 5 - 50 000 Hz · Signal-Rauschabstand > 100 dB, Sep. Spannungsversorgung für Treiber- und Endstufen · Bass-Boost: 40 Hz, 0 - 10 dB · Vergoldete Anschlüsse · 2 Ω tauglich · Eingangsempfindlichkeit: 0,3 - 6 V · Abm. ( B x H x T): 400 x 55 x 276 mm.)
Pret: 210E
6.--
Statie JBL CS 50.4. descrierea(Bezeichnung CS 50.4,Prinzip 4-Kanal
Sinus Ausgangsleistung 4 x 50 W,Musik Ausgangsleistung 600 W,Sinus Leistung gebrückt 2 x 150 w,Impedanz stabil bis 2 Ω,Frequenzbereich 10 - 30 000 Hz,Abm. (B x H x T) 384 x 313 x 60 mm,Gewicht 4,96 kg)
Pret:130e
7.--
Statie Magnat Hot Rod 2500Modell RH 2500
Prinzip 2-Kanal,Musik-Ausgangsleistung 1 x 1200,Impedanz stabil bis 2 Ohm,Frequenzbereich 40 - 400 Hz,Abm. (BxHxT) 395x60x294,Gewicht 5,20 kg)
Pret:210e
