1 . AMPLIFICATOR MAGNAT THE ROCK 400- principiu: amplificator
- raspuns in frecventa 5 - 50.000 Hz
- SPL -3 dB
- Putere maxima iesire in 4 omi: 1 x 400 watt
- Putere RMS iesire in 4 omi: 1 x 200 watt
- Putere maxima iesire in 2 omi: 2 x 200 watt
- Putere RMS iesire in 2 omi: 2 x 100 watt
- Lungime: 221 mm
- Latime: 253 mm
- Inaltime: 48 mm
PRET : 250 RON
2. AMPLIFICATOR MAGNAT THE ROCK 600- principiu: amplificator
- SPL -3 dB
- Putere maxima iesire in 4 omi: 2 x 300 watt
- Putere RMS iesire in 4 omi: 4 x65 2x170 watt
- Putere maxima iesire in 2 omi: 4 x 150 watt
- Putere RMS iesire in 2 omi: 4 x 85 watt
- Lungime: 386 mm
- Latime: 253 mm
- Inaltime: 48 mm
PRET : 430 RON
3. SUBWOOFER MAGNAT XTC 130 NEO 500 W ( cu leduri albaste )- AM 2 BUCATI.[/COLOR]Diametru difuzor - 12" / 300 mm
Putere reala - 250 Watt
Putere muzicala - 500 Watt
Impedanta difuzor - 4 Ohm
Frecventa minima redata - 18 Hz
Frecventa maxima redata - 500 Hz
Nivel sonor maxim : 92 dB
Special
Bandpass subwoofer with huge plexiglass window and blue LED illumination Huge mirror Flow-optimized bass reflex tube Double terminal 12“ high power driver Aluminium die cast basket Anti-skid carpet
4. NEON ALBASTRU ( care se poate aprinde pe bass sau poate sta aprins tot timpul )
PRET : 80 RON
5. CONDENSATOARE ( am 3 bucati )
a) CONDENSATOR M.N.C 1.5 F ( culoare gri )
Capacitor USB 5483 de 1,5 Farazi
Display digital pentru tensiune
Releu de protectie
Led-uri de culori diferite
Neon Albastru
PRET : 300 RON
b) CONDENSATOR M.N.C 1.2 F ( culoare negru )
Capacitor USB de 1,2 Farazi
Releu de protectie
Neon Albastru
PRET : 280 RON
c) CONDENSATOR AIV 1 F ( culoare gri )
CAPACITOR AIV
Capacitate - 1F
Circuit de protectie
PRET : 300 RON
( INAFARA DE ASTEA MAI AM URMATOARELE ) :
6. AMPLIFICATOR MAGNAT THE ROCK MONO 1000
amplificator monobloc pentru subwoofer
putere:
4 ohmi: 350W RMS (750W max)
2 ohmi: 500W RMS (1250W max)
1 ohm: 700W RMS (1800W max)
impedanta suportata: 1-8 ohmi
raspuns in frecventa: 5 Hz - 50 kHz (-3dB)
THD < 0,05% (1kHz)
intrare de linie 0,25V - 4V
filtru low pass variabil 40-300 Hz (12 dB)
filtru subsonic (high pass) 10-40 Hz (12 dB)
bass boost variabil 12dB la 45 Hz
circuit de protectie la supraincalzire si scurtcircuit
reglare separat pentru volumul statiei ( un fel de telecomanda cu fir ).
PRET : 600 RON
7. SUBWOOFER PIONEER 1000 W RMS - 3000 W MAX
30cm diametru
putere: 1000W RMS, 3000W max
impedanta: 2 x 4Ohm
raspuns in frecventa: 18 - 700Hz
SPL 89dB
frecventa de rezonanta (FS) 26,2 Hz
volum recomandat pt incinta inchisa: 24.1 - 49.5 litrii
PRET : 700 RON
8. TUB MAGNAT 30 CM ( pentru difuzorul pioneer de 1000 w rms ala de mai sus )
PRET : 150 RON
9. AMPLIFICATOR JBL CS60.2
amplificator auto 2 canale MOSFET
putere:
4 ohmi: 2 x 60 W RMS
2 ohmi: 2 x 80 W RMS
4 ohmi, in punte: 1 x 160 W RMS
bass boost variabil 0-6 dB la 45 Hz
filtre low pass si high pass variabile 30 - 320 Hz (12 dB)
raspuns in frecventa 10 Hz - 27 kHz
nivel semnal intrare 100mV - 6 V
dimensiuni: 225 x 260 x 57 mm
PRET : 280 RON
