Ofer spre vanzare la pachet sau separat :
1. Subwoofer auto Rockford FosgateT215D2 1200 lei
2. Amplificator Db master sra 4800d 1300 lei
tel 0760171453
Stiind ca numai un nebun cu muzica ar putea sa-si achizitioneze asa ceva, am cautat pe net si am strans cateva linkuri cu review-uri, pareri, forumuri, preturi pe care le postez la sfarsitul fiecarei descrieri a produsului.
1. Specificatii Subwoofer auto Rockford FosgateT215D2 :
(Subwoofer auto Rockford Fosgate T215D2, 38 cm (15'') 1000W RMS)
Marcă Rockford Fosgate
Model T215D2
Diametru Subwoofer 15 inch / 38 cm
Numar de Bobine Dual ( 2 bobine)
Impedanta Difuzor / Bobina 2 Ohmi
Putere MAX. 2000 W
Putere RMS 1000 W
Sensibilitate 87 dB
Raspuns in Frecventa 24 -250 Hz
Compozitie Material Woofer Aluminiu parabolic
Free Air Nu
Dimensiune Bobina 101.6 mm
Vas 88.4 L
Xmax 19 mm
Adancime 250.8 mm
Diametru de Taiere 350.8 mm
An Model 2004
Greutate 28.1 Kg
Ce conține pachetul 1 Difuzor bass (subwoofer), Accesorii fixare
Surse :
http://www.***********/produse/Subwo...osgate/T215D2/ pret
https://www.youtube.com/watch?v=-dAOuc8izoc vibreaza geamurile
https://forum.4tuning.ro/384-sistemul...d-fosgate.html
http://carsystems.ro/subwoofer-auto-...1000w-rms.html
https://www.pieseauto.ro/subwoofer-au...609715990.html
2. Specificatii Amplificator Db master sra 4800 :
Sigma-delta Platform
Through Hole Technology
Double sided Epoxy Military Standard PCB
Center Path Technology(Patent Pending )
regulated Power Supply
"Full Mosfet" Power Supply&Output Stages
Dual 0 Gage Power Inputs
Dual 0 Gage Ground Inputs
0.5 Ohm Stable
14.4V Input Voltage
Output Power: Class-D Technology(Mono)
1 x 800 Watts Rms @ 4 Ohms
(Currunt Draw 60A)
1 x 1500 Watts Rms @ 2 Ohms
(Currunt Draw 130A)
1 x 2800 Watts Rms @ 1 Ohms
(Currunt Draw 240A)
sra4800.dlinked into 4Ohm x 1Channel
Delivers a Blistering 3200(RMS) Watts
sra4800.dlinked into 2Ohm x 1Channel
Delivers a Blistering 6400(RMS) Watts and
Some change!
Frequency Response: 20Hz-330Hz
Singnal to Noise Ratio(S/N): >90dB
Total Harmonic Distortion(THD): <0>700
Minimum Load Stability
For all Channels: 0.5Ohms
Surse :
http://www.bmssound.com/popup_image....oothfdr4l52e90
https://forum.4tuning.ro/554-amplific...ra-4800-a.html
http://quezoncity.olx.com.ph/for-spl...k-iid-40154850
