Go Back   Forum 4Tuning > AUTO COMERCIAL > Bazar CAR AUDIO > Pachete Audio: Statie+Sub, HU+difuzoare, etc
Pachete Audio: Statie+Sub, HU+difuzoare, etc Pachete Audio: Statie+Sub, HU+difuzoare, etc
Old 13-08-12, 14:39   #1
p_vio46
p_vio46's Avatar
Default vand statie sony xm 280gtx si subwoofer mac audio 240 w rms
cum spune si titlul vand amplificator sony xm 280gtx , estetic nu arata foarte bine, prezinta zgarieturi, dar este perfect functională.
Specificații:
80 watts RMS x 2 at 4 ohms
100 watts x 2 at 2 ohms
200 watts x 1 bridged output at 4 ohms
stereo or bridged mono output
4-ohm stable in bridged mode
Tri-way capable (Tri-Way crossover required)
requires 10-gauge power and ground leads — wiring and hardware not included with amplifier
MOSFET power supply and output stages
50-300 Hz low-pass filter, 12 dB/octave
preamp- and speaker-level inputs
gold-plated connectors
variable bass boost (0-10 dB) centered at 40 Hz
11-1/4"W x 2-1/4"H x 7-3/4"D
subwoofer mac audio 240 w rms in incinta tub,Producator: Mac Audio
Putere maxima 480W
Putere reala RMS 240W
Impedanta 4 ohm
Raspuns in frecventa 20-200 Hz
SPL 91 dB
revin cu poze mai pe seara, pachetul este in stare perfecta de functionare , accept test, se poate testa la cerere si pe masina mea. Am facut upgrade si nu mai am ce face cu ele. Pret 260 ron Accept schimb cu subwoofer de 300w rms sau boxe de16,5 minim 80w rms, coaxiale sau sistem , contact 0765325903, sau pm.
p_vio46 is offline   Reply With Quote
Old 17-08-12, 16:07   #2
p_vio46
p_vio46's Avatar
Default Re: vand statie sony xm 280gtx si subwoofer mac audio 240 w rms
up--------------------
Old 21-08-12, 16:09   #3
p_vio46
p_vio46's Avatar
UP.... NEGOCIABIL....
Old 24-08-12, 19:27   #4
p_vio46
p_vio46's Avatar
up>>>>>>>>>>>>>>
Old 28-08-12, 09:45   #5
p_vio46
p_vio46's Avatar
up...............negociabil....
Old 01-09-12, 07:04   #6
p_vio46
p_vio46's Avatar
up>>>>>>>>>>>>>>
Old 05-09-12, 18:11   #7
p_vio46
p_vio46's Avatar
up>>>>>>>>>>>>>>
Old 10-09-12, 00:01   #8
p_vio46
p_vio46's Avatar
up.........
Old 10-09-12, 21:53   #9
Rey91
Rey91's Avatar
poze ?
Rey91 is offline   Reply With Quote
Old 10-09-12, 22:30   #10
p_vio46
p_vio46's Avatar
Originally Posted by Rey91 View Post
poze ?
Sper să nu se considere up, raspund doar la intrebare,maine revin cu poze(trec pe la prânz), dacă vrei să-l vezi /testezi (văd că ești din bucuresti) se poate testa fie pe mașina mea fie pe cea a potențialului client in orice zi după ora 16:30 L-V sau la orice oră S-D. Subwoofer ul este in incintă tip tub , mochetată complet negru. Sistemul acesta nu mai este montat pe masină si de aceea nu am făcut poze deoare imi este cam pe dos, sistemul avandul lasat la alt apartament pe unde trec decât in week end uri.
Old 11-09-12, 15:55   #11
p_vio46
p_vio46's Avatar
Pozele cerute.
ID:	2549540   Click image for larger version
ID:	2549541   Click image for larger version
ID:	2549543   Click image for larger version
ID:	2549544   Click image for larger version
Old 15-09-12, 15:49   #12
p_vio46
p_vio46's Avatar
up>>>>>>>>>>>>>>
Old 23-09-12, 18:22   #13
p_vio46
p_vio46's Avatar
up>>>>>>>>>>
Old 28-09-12, 16:47   #14
p_vio46
p_vio46's Avatar
up>>>>>>>>>>
Old 29-09-12, 22:45   #15
romiraz
cat vrei pe sub?
romiraz is offline   Reply With Quote
