De vanzare un pachet format din :
-Subwoofer DLS Classic series W312b, cu incinta sealed trapezoidala(made in sweden)
-Amplificator subwoofer DLS CA31.
-Cablaj alfatec, nu e intr-o stare prea buna dar isi face treaba (trebuiesc refacute sertizarile si carcasa de la siguranta e putin crapata) , oricum il dau bonus, nu l-am luat in calcul
Se afla in stare impecabila si subwooferul si amplificatorul, eu le vand ca nu mai am masina. Pentru buzau ofer si montajul gratuit.
Subwooferul
•diametru 12" (30 cm)
•putere: 150W RMS, 250W max
•sensibilitate: 91 db
•raspuns in frecventa: 20-2000 Hz
•impedanta: 4 ohm
•recomandat pentru incinte bass reflex sau bandpass
•parametrii Theile-Small: ◦Fs: 29,7 Hz
◦Re: 3,42
◦Qes: 0,34
◦Qms: 2,47
◦Qts: 0,30
◦BL: 12,14
◦Vas: 106 l
Amplificatorul
Specifications
Number of channels 3
Amplifier class AB
Output power in 2 ohm 2 x 90 W RMS
Output power in 4 ohm 2 x 65 W RMS
Mono sub channel 2 ohm 280 W
Mono sub channel 4 ohm 170 W RMS
Damping factor >100
S/N ratio, A-weighted >100 dB
Frequency range 10 Hz - 35 kHz
Input sensitivity 0,25 - 5 V
Input impedance >10 kohm
Input impedance, high level 100 ohm
Filters channel A & B HP: 50-150 Hz
Remote bass level control No
Filter sub channel Lowpass: 50 - 120 Hz + subsonic 25 Hz
Low level output No
Remote phase shift control No
Phase control for subwoofers 0-180 degrees cont. variable
High level input with auto start Yes
Power consumption (idle) 1A
Power consumption (max) 60A
Rec. power cable Minimum 4AWG / 21 mm2
Fuses 2 x 30 A
Dimension (W x D x H) 70 x 357 x 268 mm (2,92 x 14,06 x 10,55 inch)
Weight 4 kg ( 8,8 lb)
0765425347
PRET 800 ron
