Pachete Audio: Statie+Sub, HU+difuzoare, etc Pachete Audio: Statie+Sub, HU+difuzoare, etc |
06-09-11, 09:29
Vand amplif 4ch Magnat + 4x difuzoare Pioneer
Magnat Hot Rod 4000: - amplificator cu 4 canale
- putere:
- 4 ohmi, stereo: 4 x 85 W RMS
- 4 ohmi, in punte: 2 x 225 W RMS
- 2 ohmi, stereo: 4 x 110 W RMS
- raspuns in frecventa: 5 Hz - 60 kHz (-3dB)
- impedanta: 2-8 ohmi
- bass boost variabil 0 - 12 dB la 45 Hz
- filtru low pass variabil 40 - 240 Hz (12 dB)
- filtru high pass variabil 40 - 400 Hz (12 dB)
- VU meter cu iluminare albastra
- selector mod de functionare 4/3/2 canale
- circuit de protectie impotriva scurtcircuitelor si a supraincalzirii
2xPioneer TS-A6910 (ovale): - Frequency response 25 - 30.000 Hz
- Sensitivity (1W/1m) 93 dB
- Maximum Power 330 W
- Nominal input power 80 W
- Speaker Size 265 x 185 mm
- Woofer size (cm) 16,3 x 23,7 cm
- Woofer material Crystalline IMPP Cone woofer with Butyl rubber edge
- Midrange size (mm) 66,0 mm
- Midrange material cone mid-range with Ferrite magnet
- Tweeter size (mm) 18,0 mm
2xPioneer TS-A131C (component, 2x tweetere incluse): - Frequency response 40 - 30.000 Hz
- Sensitivity (1W/1m) 91 dB
- Maximum Power 160 W
- Nominal input power 40 W
- Speaker Size 157,0 mm
- Woofer size (cm) 13 cm
- Tweeter size (mm) 28,0 mm
- Tweeter material PEI balanced dome
Perfect functionale!
Pret pentru tot pachetul: 800 RON
Tel: 0731 038 524
06-09-11, 11:42
Re: Vand amplif 4ch Magnat + 4x difuzoare Pioneer
Pret la statie separat? STIMA
06-09-11, 11:45
Statia se vinde separat cu 450 RON
12-09-11, 14:32
up...
14-09-11, 09:13
up...
20-09-11, 18:17
salut.ofer un iphone 36 16g alb nota 9,7 arata foarte bine telefonul . fara probleme. djwave22 sa vorbim.sal
21-09-11, 19:22
prefer banii, merci de oferta.
01-10-11, 12:57
a ramas doar statia - 450 RON negociabil!
06-10-11, 13:41
Revin la vanzare si component system-ul Pioneer TS-A131C
(motivul: prea adanci pentru a fi montate pe e46 cabrio, in spate)
Merg in schimb la fix pe e36, in fata!
10-10-11, 09:30
Pioneer TS-A131C + Magnat Hot Rod 4000 = 600 RON
10-10-11, 14:33
Member of: [SKODA]
Salut, un pret pentru difuzoare? Ai idee daca ar intra pe o skoda fabia 1 in fata?
Multumesc!
10-10-11, 14:36
Multumesc!
Salutare,
Sincer sa fiu, nu am idee... ai in primul post dimensiunile componentelor.
Pret fix pentru Pioneer TS-A131C - 100 RON
17-10-11, 09:26
Pioneer TS-A131C + Magnat Hot Rod 4000 = 500 RON
Pioneer TS-A131C = 100 RON
Magnat Hot Rod 4000 = 450 RON
24-10-11, 16:24
up...
30-10-11, 11:52
