PACHET 1 :
Subwoofer CS 1204T :
* subwoofer bass reflex, diametru 30 cm
* putere: 250 W RMS (1000W max)
* SPL (2,83V/1 m): 90 dB
* raspuns in frecventa: 35 - 200 Hz
* impedanta: 4 Ohm
* dimensiuni: 346 x 660 mm
Amplificator: Magnat Edition Two Limited : (
in garantie inca 15 luni)
* amplificator stereo, 2 canale
* putere:
o 4 ohmi, stereo: 2 x 75 W RMS
o 4 ohmi, in punte: 1 x 220 W RMS
o 2 ohmi, stereo: 2 x 110 W RMS
* stabila la 2 ohmi
* raspuns in frecventa: 5 Hz - 50 kHz (-3dB)
* bass boost variabil 0 - 12 dB la 45 Hz
* filtru low pass variabil 40 - 300 Hz (12 dB)
* filtru high pass variabil 40 - 300 Hz (12 dB)
* selector mod de functionare 2/1 canale
* circuit de protectie impotriva scurtcircuitelor si a supraincalzirii
Pret 420 lei /pachet !!!!!
PACHET 2:
Subwoofer : 2 x Alpine SWR-1221D
* KevlarŪ-infused pulp cone
* 1" Santoprene rubber surround
* dual 2-ohm 2" voice coils (make sure your amplifier is compatible)
* frequency response 24-1,000 Hz
* RMS power handling: 300 watts
* Peak power handling 1,000 watts
* sensitivity 87 dB
* top-mount depth 6-15/16"
* sealed box volume: 0.7-1.0 cubic feet
* ported box volume: 0.75-1.75 cubic feet
Amplificator : Kenwood KAC-9152D
# Class-D Monoblock Amplifier
# Bass Boost Level and Frequency Remote Included
# Variable Low-Pass Filter: 50 - 200 Hz (24 dB/Oct.)
# Variable Input Sensitivity: 200mV - 5V
# Phase Shift: 0° / 180°
# Variable Infrasonic (Subsonic) Filter: 0/15Hz/25Hz (18 dB/Oct.)
# High- and Low-Level Inputs
# 1 Ohm Stable
# RMS Power Output:
* 500 watts x 1 chan. @ 4 ohms
* 900 watts x 1 chan. @ 2 ohm
# Preamp Outputs: 1 Pair
# Bass Boost: 0 - 18 dB @ 40 - 100 Hz (Variable)
# Dimensions: 15" L x 11-5/16" W x 2-3/8" H
Condensator : MNC 1 Farad
* Capacitate: 1.0 Farad
* Tensiune: 20/24 V CC
* Toleranţa: C ą 10%
* Temp. maximă de lucru: 95°C
* Afişaj roşu, semnalizare albastră sau Afişaj albastru, semnalizare albastră
Cablaj : 35 mm Dietz
PRET : 1500 lei / pachet
Toate componentele se pot proba pe masina mea . Pachetul 2 este montat deja !
SE VAND DOAR LA PACHET !!!! NU DAU NIMIC SEPARAT !!!!
