vand pachet JL audio amplificator JL audio 500/1 plus subwoofer JL audio 13W6v2 pret 550 E negociabil 0769 55 25 42 fane
Free Air Resonance (Fs): 24.3 Hz
Electrical “Q” (Qes): 0.464
Mechanical “Q” (Qms): 6.700
Total Speaker “Q” (Qts): 0.434
Equivalent Compliance (Vas): 3.94 cu. ft. / 111.6 liters
One-Way, Linear Excursion (Xmax)*: 0.85 in. / 21.6 mm
Reference Efficiency (no): 0.331%
Efficiency (1W/1m)**: 87.4 dB SPL
Effective Piston Area (Sd): 100.4 sq. in. / 0.0648 sq. m.
DC Resistance (Re): 6.50 ohm***
Nominal Impedance (Znom): Dual 4 ohm
Thermal Power Handling (Pt): 750W
Driver Displacement: 0.120 cu. ft. / 3.4 liters
Net Weight: 26.8 lbs. / 12.2 kg
si pentru statie
Rated Power: 500 W RMS @ 1.5 ohm - 4 ohm (11V-14.5V)
THD at Rated Power: <0.05% @ 4 ohm
S/N Ratio: >95dB below rated power (A-weighted, 20 Hz - 20 kHz noise bandwidth)
Frequency Response: 5 Hz - 250 Hz (+0, -1dB)
Damping Factor: >500 @ 4 ohm / 50 Hz
>250 @ 2 ohm / 50 Hz
Input Range: Switchable from 200mV-2V RMS to 800mV-8V RMS
Dimensions (L x W x H): 13.40 in. x 9.25 in. x 2.36 in.
340 mm x 235 mm x 60 mm
