Vand urmatoarele:
1.Boxe spate Focal access 690 ca1
-2-way 6x9"coaxial speakers
-Voice Coil: 32mm
-Magnet: 90mm
-Orientable, aluminium inverted dome Tweeter
-Max. power handling: 150W
-Nom. power handling : 75W
-Sensitivity (2,83 V/1m): 92dB
-Frequency response: 50Hz-20KHz
-Grilles supplied
www.focal-fr.com
2.Boxe spate jbl cs396e
-JBL CS396e - Loa Full-range 6x9 inch, 3 210W
-General
-Size 6" x 9"
-Type Triax
-Power Handling, Peak 210W
-Power Handling, RMS 70W
-Impedance 4 ohms
-Sensitivity (2.83V/1m) 91dB
-Frequency Response 50Hz - 20kHz
-Mounting Depth 77mm
-Cutout Diameter 223 x 151mm.
3.jbl subwoofer
-15" GT-series subwoofer
-Power Handling, RMS: 250 Watts
-Power Handling, Peak: 1000 Watts
-Frequency Response (±3dB): 20Hz - 400Hz
-sensitivity: 91dB
-Mounting Depth: 6-3/4"
-Cut-Out Diameter: 14-1/4"
-Impedance: 4 Ohms.
4.Panasonic CQ C7301N
- Putere mare de iesire: 4 x 50W
- Etaj final MOSFET
- SQ 7
- Crossover
- Mute/Atenuator
- SBC-SW
- Reglaje separate: Bass, Treble, Balance, Fader
- Iesire dubla pentru preamplificator 2.5V/60 ohmi
- Iesire de 5V pentru subwoofer
- Posturi presetate: 18FM, 6MW/LW
- Sensibilitate AF selectabila
- Ajustare automata a sunetului pentru TA
- Acord prin cautare cu DX/Comutare locala
- Redare CD-R/RW, MP3 si WMA
- ID3 Tag
- Afisare nume fisiere
- Afisare CD text
- "Hologram Pick-up" cu trei fascicole
- Control CD Changer
- Control DVD Changer
- Panou frontal motorizat
- Afisaj in 9200 de culori variabile
- Afisaj HD 3DDM cu posibilitate de personalizare
- Diminuare luminozitate afisaj
- Culoarea tastelor: rosu
- Analizor de spectru
- Intrare AUX
- Compatibilitate AUX/Changer Control
- Intrare pentru comanda de la distanta
- Design Full-Face
- Culoare fata detasabila: argintiu/negru
- Panou frontal detasabil
- Telecomanda
- Conector ISO
http://www.comunicatedepresa.ro/Noul...mobil~NjcxNA==
5.PANASONIC CQ C1315N
-PANASONIC CQ C1315N
-WMA Playback: Yes
-RMS Power Output: 4x20 Watts
-MP3 playback: Yes
-Maximum Power: 4x40 Watts
-DIN: 1
-Detachable Face: Yes
-CD-R/CD-RW Compatible: Yes
-CD Text: Yes.
6.Amplifier BLAUPUNKT GTA480
4/2 CHANNEL POWER 440 Watt
7.DVD Portabil Grundig DVD-P 8600
-20,3 cm Active Matrix LCD-TFT Bildschirm im 16:9 Format
-Anti Schock System
-USB-Anschluss, Kartenleser (SD)
-Wiedergabe von DivX-codierten Dateien
-Lieferumfang: Stereo-Kopfhörer, Fernbedienung, AV-Kabel, Akku, Adapter und Universal Adapter. Farbe: silber.
1-250 RON
2-230 RON
3-270 RON
4-250 RON (Functioneaza impecabil dar are displaiul spart in urma unui accident)
5-200 RON
6-250 RON
7-550 RON
O plasa cu cabluri pt statie si toate cele fibra optica si mai ce or fi ele ca am dat o groaza de bani pe ele - 150 RON.
PRETURI USOR NEGOCIABILE.
CONTACT:0767582092 NUMAI BUCURESTI.
