Pachetul contine :
Statie Hifonics NX750D
# Peak Power Output (approximates):
* 1500 watts x 1 chan (1 ohm)
* 750 watts x 1 chan. (2 ohms)
* 350 watts x 1 chan. (4 ohms)
# RMS Power Output:
* 750 watts x 1 chan (1 ohm)
* 375 watts x 1 chan. (2 ohms)
* 170 watts x 1 chan. (4 ohms)
# New Hifonics Twentieth Anniversary Heat Sink Design
# Ultra-Fi Mosfet
# SPC - Simpatico Coil Design
# HSMD - Hifonics Surface Mount Design
# Fully Adjustable Accu-Cross Crossovers
# PWM Mosfet Power Supply
# Line Output for Amplifier Daisy Chaining
# Variable Bass Equalization
# Sub-Sonic Filter
# 4 Gauge Power Connectors
# Additional High Speed Mosfet Output Devices
# Class D Operation
# 60A Maxi-Fuse
Subwoofer, doua la numar, cu tot cu cutie de bass reflex , Model HZ12
Product MPN
MPN HZ12
Key Features
Car Speaker Type What is "Car Speaker Type"? Component
Elements What is "Elements"? 1-Way
Car Speaker Function What is "Car Speaker Function"? Subwoofer
Size 12"
Nominal Power Handling What is "Nominal Power Handling"? 450 Watt RMS
Powered What is "Powered"? Non-Powered
Technical Features
Peak Power Handling 800 Watt
Sensitivity 89.90 dB
Impedance 4 ohm (Dual Coil)
Components
Woofer Material What is "Woofer Material"? Metal
Surround Material What is "Surround Material"? Rubber
Mounting
Enclosure What is "Enclosure"? Non-Enclosed
Top Mounting Depth 6.00 In.
Mounting Diameter / Length 2.00 In.
Pret Pachet 1400ROn
