Deci 3 bucati :
1) Amplificator Magnat Edition Two Limited
SPECIFICATII:
amplificator stereo, 2 canale
putere:
4 ohmi, stereo: 2 x 75 W RMS
4 ohmi, in punte: 1 x 220 W RMS
2 ohmi, stereo: 2 x 110 W RMS
stabila la 2 ohmi
raspuns in frecventa: 5 Hz - 50 kHz (-3dB)
bass boost variabil 0 - 12 dB la 45 Hz
filtru low pass variabil 40 - 300 Hz (12 dB)
filtru high pass variabil 40 - 300 Hz (12 dB)
selector mod de functionare 2/1 canale
circuit de protectie impotriva scurtcircuitelor si a supraincalzirii
CUMPARATA DE 6 saptamani de pe ******* , garantie 2 ani .In perfecta stare de functionare.
2) Subwoofer JBL 1000 w max:
SPECIFICATII :
subwoofer bass reflex, diametru 30 cm
putere: 250 W RMS (1000W max)
SPL (2,83V/1 m): 90 dB
raspuns in frecventa: 35 - 200 Hz
impedanta: 4 Ohm
dimensiuni: 346 x 660 mm
In perfecta stare de functionare . Ca nou .
3) Cd player JVC Kd LH300
SPECIFICATII:
Power Output: 200W Max. (50W x 4)
Variable Color 3D Graphics Display with Contrast Control.
PiCT (Personalized Image Capture Technology)
PiCT Downloads: Click Here To Experience the Power of PiCT
Motorized Slide-out Face
MP3/WMA Compatible
CD-R/CD-RW Compatible
SIRIUS Compatible
CD Changer Control
7-band iEQ
Key-Chain Type Wireless Remote Control
Gold-Plated Line Output Terminals (2 pairs)
Subwoofer Output w/ Level & Frequency Control
4V Line Output Level
Rotary Encoder Multi-Control
Loudness Control
Detachable Control Panel with Carrying Case
24-Bit Resolution Burr-Brown 1-Bit DAC
Preferred Setting Mode
CD Player Intro Scan
CD Random and Repeat Play modes
HS-IIIi Tuner
18 FM & 6 AM Presets
SSM (for FM)
AFNS/PNC
COMPU PLAY
Electronic Volume Control
Preamp Fader Control
1 Year Warranty
Ca nou . nota 10/10 . Perfect functional , sunet impecabil nu ca alte facaturi .
SISTEMUL ESTE MONTAT LA MINE PE MASINA . SE FACE PROBA!!!!!!!!
SE VINDE LA PACHET !!!!!!!!!! NU VAND PE BUCATI !!!!!!!!!!!!
PRET : 200 euro .
