https://forum.4tuning.ro/viewtopic.php?t=16654
Am aici un amplif JBL cs50.4 nou nout in cutie are 4 iesiri...
• amplificator pe 4 canale, clasa AB
• putere maxima: 580W
• putere RMS @ 4 Ohm: 4 x 50W
• putere RMS @ 2 Ohm: 4 x 75W
• putere RMS in punte @ 4 ohm: 2 x 150W
• raspuns in frecventa: 10Hz – 30kHz
• THD: 0,10%
• raport semnal/zgomot: >100dBA
• crossover: Flat / LP / HP, variabil 30 – 320Hz (12dB / oct.)
• iesire preamp 2 canale
• dimensiuni (H x W x D): 384x313x60mm
la amplif poti adauga un woofer blaupunkt gtt300 nou si asta ....
Subwoofer- Tube
- Impulsbelastbarkeit 600 Watt
- Nennbelastbarkeit 200 Watt
- Wirkungsgrad 91 dB (2,83 V/m)
- Frequenzgang: 35 - 500 Hz
- Impedanz 4 Ohm
- Durchmesser: 300 mm
- Länge 484 mm
- Einbau- (Durchmesser) 328 mm
ti le dau amandoua la 6 mil......
te intereseaza ?
