Go Back   Forum 4Tuning > AUTO COMERCIAL > Bazar CAR AUDIO > Difuzoare Auto
Difuzoare Auto Difuzoare Auto, Boxe Auto, Audio
Old 21-09-05, 18:58   #1
costi_GCA
Default Vind:Statii,subw,BOXE: INFINITY, CANTON , REVELAND
Pot aduce urmatoarele Scule audio:
1...Statie : INFINITY 6KANALE MODEL RA 6006 PRET:250e
DESCRIERE(Bass Boost·Variable High /Low passport switches·MOSFET technology innovative technology is the basis for all Infinity of products. No miracle that the name became Infinity the epitome of a Hifi sound on highest level. The RA 5004 and RA 6006 permit you the ideal configuration for your personal sound system. Both models have most modern point technology in Class A/B building method with ultraschneller MOSFET technology. Further equipment characteristics: Fully integrated, active frequency switches·2? Working reliability·Tri mode for each pair of channels·Adjustable bass Boost·Individually bridgable pairs of channels·Extremely durable structure in responding extruded aluminum radiator box arranged)
2...BOXE CANTON 2WAY model RS 2.13 .90w Pret: 130e
descriere( The system was developed particularly for the installation within the tail range. The Tieftoener uses here the trunk as resonance bodies for a full, pressureful bass rendition. The RS-2-Wege-Systeme offers external switches with large edge steepness for the clean separation from high and low clay/tone. For a dynamic, impulse-fast and clean bass rendition the Tieftoener is equipped with a high performance magnet and a carbon fiber diaphragm. The optimized efficiency of R-S series ensures for the fact that the systems at car radio output stages or achievement amplifiers sound always optimal. Impedance 4?.)
3...BOXE CANTON 2WAY -RS 2.160 .120w Pret: 150e
4....BOXE CANTON 3-Way- RS 6-II 180w Pret 240E
5...BOXE INFINITY REF 6500CS 165 mm 2-Way-Compo240/90 Pret:180E
6...BOXE INFINITY REF 5000CS 130 mm 2-Way-Compo225/75 Pret:170E
7...SUBW ACTIV REVELAND--RV 112 L Pret: 99e
( max/RMS 600/160 W · Freq 20 – 150 Hz 95 dB · Impedanz 4 Ω.(B x H x T): 400 x 390 x (326 + 465) mm )
8......SUBW REFLEXION VX-BP 1000 Pret 150e
(10\" Single Bandpass Sinus-/Musik- 200/650 W Freq 20 - 150 Hz SPL 96 dB (H x B xT) 525 x 360 x 335 mm,greutate17 kg )
9......SUBW REFLEXION VX-BP 1200 Pret 160e
12\" Single Bandpass Sinus-/Musik-300/700 W Freq 20 - 150 Hz SPL 98 dB (H x B xT) 525 x 375 x 385 mm Greutate 18,5 kg
Costi 0723.000.350
ID:	42723   Click image for larger version
ID:	42724   Click image for larger version
ID:	42726   Click image for larger version
ID:	42727   Click image for larger version
costi_GCA is offline   Reply With Quote
Old 22-09-05, 12:45   #2
sex99
sex99's Avatar
cat ceri pe primul sub si ce putere are
sex99 is offline   Reply With Quote
Old 22-09-05, 14:15   #3
costi_GCA
100 e
scrie mare poza 7 anutul cu ce vind in ordine cu pozele adica anuntul7
Old 22-09-05, 15:33   #4
mihai.ghetto
mihai.ghetto's Avatar
[Ghetto Cult]
costi, in cat timp poti sa aduci produsele astea? m-ar interesa si pe mine un subwoofer activ de exemplu...
modelul asta poti sa-l aduci?
mihai.ghetto is offline   Reply With Quote
Old 24-09-05, 08:42   #5
costi_GCA
up up
Old 27-09-05, 23:27   #6
costi_GCA
sus, nu vrea nimeni
Old 29-09-05, 22:45   #7
ct02raz
ct02raz's Avatar
Default Re:
Originally Posted by \"costi_GCA\"
sus, nu vrea nimeni
BOXE INFINITY REF 6500CS 165 mm 2-Way-Compo240/90 Pret:180 ......care ar fi ultimu pret pentru ele ca la magazin in constanta sunt 5 milioane asa ca fa o oferta daca vrei sa vinzi ceva,astept un raspuns...ms
ct02raz is offline   Reply With Quote
Old 29-09-05, 22:47   #8
ct02raz
ct02raz's Avatar
Default Re:
sus, nu vrea nimeni
Old 01-10-05, 02:16   #9
costi_GCA
Default Re:
sus, nu vrea nimeni
daca consideri ca pretul meu e mare du-te si ia din c-ta din magazin.........nu oblig pe nimeni sa cumpere de la mine
bafta
Old 01-10-05, 20:53   #10
ct02raz
ct02raz's Avatar
Default Re:
sus, nu vrea nimeni
bafta
stai linistit ca nu bateam eu drumul pana la bucuresti pentru preturile pe care le practici......aviz amatorilor
Old 09-10-05, 23:59   #11
costi_GCA
up
