vand boxe Infinity Kappa 693.7i , poze reale.
Infinity Kappa speakers incorporate the latest technology to provide you with outstanding sound reproduction. And, thanks to Infinity's innovative low-impedance design, they're built for high efficiency as well.
The Kappa 693.7i 6"x9" speaker features a super-stiff woofer cone to minimize flexing that can cause distortion. The cone's Plus One design offers a larger surface area than other 6"x9" speakers, for improved bass output and efficiency. The woofer's powerful, compact neodymium magnets weigh much less than traditional magnets — a nice feature when you're trying to save weight in your high-performance vehicle.
Infinity uses a M.M.D. midrange that reproduces the music the way it was recorded, with minimal coloration or distortion. A tweeter complements the midrange with stellar projection of the highs.
The computer-optimized outboard crossover employs audiophile-grade components to separate highs and lows so that the woofer and tweeters work together perfectly. A tweeter level control allows you to tailor the tweeters' response for perfect balance.
Important Note: These Infinity speakers use a low impedance design to pull more power safely from your car stereo or amplifier. This design is compatible with all factory and aftermarket stereos.
Details:
3-way 6"x9" speakers (pair)
2-ohm impedance for extra power (compatible with all factory or aftermarket car stereos)
Plus One woven-glass-fiber woofer cone with rubber surround
EMIT tweeter and M.M.D. midrange
computer-optimized outboard crossovers with tweeter level control
power range: 2-110 watts RMS (330 watts peak power)
frequency response: 35-25,000 Hz
sensitivity: 95 dB
top-mount depth: 3-3/16"
warranty: 3 years
Plus One Woven-Glass-Fiber Woofer Cones: The Plus One speakers use cones approximately 30% larger than other speakers of the same size. This is accomplished by using a new basket design and hi-roll surround. The Plus One design offers greater bass output and a significant increase in efficiency. The woven-glass-fiber material is very light and extremely stiff, minimizing cone flex. This results in very low distortion and improved clarity.
Motor Structure: The new Kappas use a Neodymium motor structure with an integrated heat sink. This design provides a massive amount of energy while minimizing mounting depth and magnet diameter. The integrated heat sink cools the motor structure efficiently, thus increasing power handling while reducing distortion.
Emit Tweeter and MMD Dome Midrange: Each speaker has an Emit tweeter and an MMD (Metal Matrix Diaphragm) dome midrange. The benefit is increased power handling and reduced distortion at high output. This technology also allows for better integration with the woofer. The tweeter has an adjustable output level, +0 dB (flat) and +3 dB.
SLI High-Output Design: This high output 2 ohm design extracts every watt from today's high powered receivers and amplifiers, increasing overall system output and efficiency (relative to 4 ohm speakers).
Crossovers: Kappa speakers include computer-optimized, voice-matched crossovers, using audiophile quality air core inductors and polypropylene capacitors.
Crossover Connections: Each crossover has a 12" input lead terminated with bare wire and two 19" output leads, one for the woofer and one for the tweeters, terminated with female quick-slides. The female quick-slides connect to the male quick-slides on the speaker. The positive terminal on the woofer input is 0.248" and the negative is 0.191". The positive terminal on the tweeter input is 0.205" and the negative is 0.111".
Crossover Dimensions: L=4.265", W=2.076", H=1.215"
Bottom Mount: Spacer rings are included to use when bottom mounting the speakers. The rings add about half an inch to the flange height.
atentie: necesita amplificator stabil la 2 ohmi
pret 300 roni
tel: 0751488830
alpine_clarion@yahoo.com
