Re: vand diverse componente de sisteme, boxe, difuzoare, subwoofer si tweetere
Player auto Mp3 & USB Alpine UTE-80B
RECEPTOR MEDIA DIGITAL / USB
Intrare USB si AUX frontala
Iluminare butoane: albastru
( Fara RDS si fara PreOut )
Caracteristici tehnice:
Radio
Memory Presets: Preset Stations (FM:18, MW:6, LW:6)
Memory: Auto Memory
Seek Mode: Local/DX Selection
USB
USB Connection: Front USB Connection with 1000mA charging support and Phone charging
Music Playback: MP3
USB Class: Mass Storage Class
File/Folder Name Search
Percentage Search
Folder Up/Down
M.I.X. Random Play: Files in a folder, All
Repeat
Reglare sunet
BassEngine SQ
Default Equalizer setup
Equalizer: Flat, Pops, Rock, News, Jazz, Electrical Dance, Hip Hop, Easy Listening, Country, Classic
3-band Parametric Equalizer
Factory EQ: 10 types
Tone control: Bass/Mid/Treble
Loudness
Source Tone Memory
General
Power Output: 4 x 50W High Power Amplifier
Display LCD: 13 Segments White LCD Display 1Line
Control Type: Rotary Encoder Knob
Blue Illumination Buttons
AUX-In: Front AUX Input (3.5mm mini jack)
Menu Language: English, German, French, Italian, Spanish, Dutch, Russian
Detachable Face Plate
Detachable DIN Trim Plate
Dimmer
Power Antenna Lead Output
Face Color: Black
Putere maxima
Max Power Output: 4 x 50W
FM Tuner
Tuning Range: 87.5 - 108.0 MHz
Mono Usable Sensitivity: 9.3 dBf (0.8 μV / 75 ohms)
Alternate Channel Selectivity: 80 dB
Signal-to-Noise Ratio: 65 dB
Stereo Separation: 35 dB
Capture Ratio: 2 dB
MW Tuner
Tuning Range: 531 - 1,602 kHz
Usable Sensitivity (IEC Standard): 22.5μV / 27.0dB
USB
USB Requirements: USB 1.1/2.0
Max. Power Consumption: 1,000 mA
File System: FAT 12/16/32
MP3 Decoding: MPEG Audio Layer-3
Number of Channels: 2-Channel (Stereo)
Frequency Response: 5 - 20k Hz (±1 dB) *May differ depending on the encoding software and bit rate.
Total Harmonic Distortion (at 1kHz): 0.008 %
Dynamic Range (at 1kHz): 95 dB
Signal-to-Noise Ratio: 105 dB
Channel Separation (at 1kHz): 85 dB
Reglare sunet
Bass Level Control Range: -14 to +14 dB
Bass Center Frequency: 60/80/100/120 Hz
Bass Bandwidth Adjustment (Q): 4 Choices (0.5=wide, 1.0=medium, 1.5=medium, 2.0=narrow)
Mid Level Control Range: -14 to +14 dB
Mid Center Frequency: 500/1k/1.5k/2.5k Hz
Mid Bandwidth Adjustment (Q): 4 Choices (0.75=wide, 1.0=medium, 1.25=medium, 1.5=narrow)
Treble Level Control Range: -14 to +14 dB
Treble Center Frequency: 7.5k/10k/12.5k/15k Hz
Treble Bandwidth Adjustment (Q): 2 Choices (0.75=wide, 1.25=narrow)
Loudness: 100 Hz 10 dB
Bass Engine SQ: Level 0 – 6
General
Power Requirement: 14.4 V.DC (11-16V allowable)
Aux In: 1.4V / 10k ohms
Maximum Mounting Angle: 35° from Horizontal
Weight: 0.9 kg
Dimensiuni
Din Size: 1 DIN
Chassis Size (W x H x D) mm: 178 x 50 x 160,5 mm
Nose Piece Size (W x H x D) mm: 170 x 46 x 25 mm
Manuale:
om_ute-80b_en.pdf
Vand difuzoare auto
Infinity REF6500CX
boxe auto sistem
diametru mid-bas : 16.5 cm
putere RMS : 90 W
putere max : 270 W
raspuns in frecventa : 53Hz–21kHz
sensibilitate : 93dB
impedanta : 3 ohmi (pot fi conectate direct la player)
Vand material insonorizant auto
Ground Zero GZDM 3700-AB
- nu are nevoie să fie încălzit, temperatura camerei este suficientă
- amortizare buna
- nu absoarbe apa, nu trebuie să fie protejat separat
- dimensiune foaie de 230 × 400 mm
- pachetul contine 40 de folii
- acopera o suprafata de 3,7 m2
- grosime de 17 mm
Vand boxe dedicate Volkswagen
Match MS 62C-VW.1
Acest model de difuzoare este unul dedicat Volkswagen fiind plug & play.
Se monteaza in locul difuzoarelor originale pe aceleasi prinderi!
What a pity that Volkswagen combines excellent speaker locations in stable, sealed front doors with cheap woofer and tweeter equipment in their cars. What a luck that we offer the right solution to eliminate this weak point. The MS 62C-VW comes with high power handling woofers and brilliant 25mm silk dome tweeters, perfectly adapted by car-specific crossovers. This speaker set is definitely a must if you want to install amplifiers with more than 35 WRMS power per channel.
2-way component system with car-specific upgrade speakers for Volkswagen
Approved compatibility with Golf VI / VII, Polo V (6R) and Scirocco III
Easiest installation due to c ar-specific baskets and wires with original harness connectors
6,5” woofer and 1” tw eeter with mounting adaptors for the original mounting positions
High-end crossover with reference curve setup
Power handling RMS / Max 80 / 160 Watts
Frequency response 40 Hz - 25.000 Hz
Sensitivity 90 dB 1 W / 1 m
Impedance 4 Ohms
Diameter subwoofer / midrange / tweeter 165 mm / 25 mm;
6,5" / 1"
Crossover separate, 6 dB / 12 dB slope
Model series / year of manufacture
Polo - Polo V (Typ 6R) 2009 -
Golf - Golf VI (Typ 1K) (2008 - 2012)
- Golf VII (Typ AU) 2012 -
Vand boxe dedicate BMW
Match MS 83-BMW.1
Acest model de difuzoare este unul dedicat BMW fiind plug & play.
3-way component system with car-specific upgrade speakers for BMW
• approved compatibility with 1-series (E81/82/87/8, 3-series (E90/91/92/93), 5-series (E60/61) and X1 (E84)
• easiest installation due to car-specific baskets and ready-for-use wires
• 8” subwoofer, 4” midrange and 1” tweeter for the original mounting positions
• high-end crossover with reference curve setup
Power handling RMS / Max 100 / 200 Watts
Frequency response 30 Hz - 25.000 Hz
Impedance 4 Ohms
Diameter subwoofer / midrange / tweeter 200 mm / 100 mm / 25 mm;
8" / 4" / 1"
Crossover separate, 6 dB / 12 dB slope with bandstop filter
1er / 1-series E81, E82, E87, E88 (2004 - 2013)
3er / 3-series E90, E91, E92, E93 (2005 - 2013)
5er / 5-series E60, E61 (2003 - 2010)
X1 E84 2009 -
X3 E83 2003 - 2010
X5 E70 2006 - 2013
X6 E71 2008 -
Boxe auto:
Dimensiuni: 10 cm
Tip difuzoare: Sisteme
Subwoofere auto:
Tip subwoofer: Fara incinta
Diametru: 8 inch(20 cm)
Subwoofer activ: Nu
Match MS 42C-BMW.1
2-way component system with car-specific upgrade speakers for BMW
Approved compatibility with 1-series (E81/82/87/8, 3-series (E90/91/92/93), 5-series (E60/61) and X1 (E84)
Easiest installation due to c ar-specific baskets and ready-for-use wires
4” midrange and 1” tw eeter for the original mounting positions
X1 E84 2009 -
X3 E83 (2003 - 2010)
X5 E70 (2006 - 2013)
X6 E71 2008 -
Power handling RMS / Max 60 / 120 Watts
Frequency response 100 Hz - 25.000 Hz
Impedance 4 Ohms
Diameter subwoofer / midrange / tweeter 100 mm / 25 mm;
4" / 1"
Boxe auto:
Dimensiuni: 10 cm
Vand subwoofer auto
Helix B 10W DVC2
difuzor subwoofer
diametru : 250 mm
putere RMS : 250 W
putere max : 500 W
impedanta : 2 x 2 ohmi
con din polipropilena injectata
borne masive placate cu aur
sensibilitate : 89 dB 1W/1m
frecventa de rezonanta : 39 Hz
Qms : 3,47
Qes : 0,52
Qts : 0,45
VAS : 35 litri
excursie liniara con : +/- 6mm
adancime instalare : 120 mm
STP iSilver AntiRust BULK PACK
Cel mai popular produs STP iSilver primeste o imbunatatire,schimbandu-si numele in STP ISilver Antirust ,si este modernizat cu aditivi anti-rugină pentru a se asigura că șasiu nu rugineste
Acesta este un material impermeabil foarte flexibil, care aderă la suprafețe complexe ermetic, oferind cea mai mare amortizare a vibrațiilor pentru materialele de acest gen
Compoziție:
Un material multi-strat de amortizare a vibrațiilor cu suprafața exterioară folie de aluminiu, strat de polimer pe bază de cauciuc butilic și un strat auto-adeziv
Potrivit pentru Uși, acoperiș, capac portbagaj, capac Bonnet, Firewall
Pachetul STP iSilver Antirust Bulk Pack contine 10 coli cu dimensiunea de 75cm x 50cm echivalentul a 3,75 m2
Vand Alpine CDE-181R
RADIO CD/USB/MP3/CONTROL i-Pod ( verde )
Radio
Memory: Auto Memory
RDS
RDS Functions: AF, TA, TP, PTY, EON, Radio Text
Made for iPod® / iPhone®
Compatibility for iPod/iPhone: Made for iPod touch 5th/4th/3rd/2nd/1st Gen., iPod nano 7th/6th/5th/4th/3rd Gen., iPod classic 160GB/120GB/80GB, iPhone 5S, iPhone 5, iPhone 5C, iPhone 4S, iPhone 4, iPhone 3GS, iPhone 3G and iPhone
Connection: KCU-445i (sold separately) Required (for iPods / iPhones with 30-pin connector)
Available Selections: Playlist, Artist, Album, Song, Podcast, Genre, Composer, Audiobook, Genius Mix
Alphabet Search
Percentage Search
App Direct Mode
Direct Up/Down: Playlist, Artist, Album, Genre Up/Down
M.I.X. (Shuffle) Play: Songs, Albums
Repeat
Battery Charging
Redare disc
Disc Type: CD Player
Disc Playback Type: CD, CD-R/RW
Music Playback: CDDA, MP3, WMA, AAC Playback
M.I.X. Random Play: M.I.X. Mode
Repeat
Playback Control: Play/Pause/Forward/Backward
CD Text Display: Disc/ Track display
CD Text Name Search
Percentage Search (MP3/AAC/WMA Only)
Zero data Mute
DAC: Multi Bit DAC
Digital Servo
USB
USB Connection: Front USB Connection with 1000mA charging support and iPhone quick charging
Music Playback: MP3, WMA, AAC Playback
Percentage Search
Folder Up/Down
Repeat
Reglare sunet
BassEngine SQ
Subwoofer Level Adjustment
Subwoofer Phase Select
Subwoofer System Select: Subwoofer Level Control Management
Low Pass Filter
Loudness
Source Tone Memory
Power IC Management System
General
Illumination Buttons: Green (CDE-181R), Amber (CDE-181RM), Red (CDE-181RR)
PreOut: 2 PreOuts (2V, Front + Rear/Subwoofer)
Steering Wheel Remote Control Ready
Dimmer
Remote Turn-On Output
Face Color: Black
Mute: -20dB Mute (Remote control only)
Putere maxima
General
Pre Output Voltage (Before Clipping): 2V / 10k ohms
Weight: 1.24 kg
Dimensiuni
Din Size: 1 DIN
Chassis Size (W x H x D) mm: 178 x 50 x 161,5 mm
Vand Alpine CDE-180RR
RADIO CD/USB ( rosu )
Putere maxima de iesire
Putere maxima: 4 x 50W
Dimensiuni 1 DIN
Dimensiune unitate (W x H x D) mm: 178 x 50 x 161.5 mm
Tuner FM Banda: 87.5 - 108.0 MHz
Sensibilitate: 0.7 μV
Selectare canal alternativ: 80 dB
Raport semnal/zgomot: 65 dB
Separatie stereo: 35 dB
Raport captura: 2 dB
Tuner
Memorie: Posturi memorate (FM:18, MW:6, LW:6)
Memorie: Auto Memorare
Mod de cautare: Local / selectare DX
RDS
Functii RDS: AF, TA, TP, PTY, EON, Text Radio
Redare CD
Tip Disc: CD Player
Compatibil: CD, CD-R/RW
Redare: CDDA, MP3, WMA, Redare AAC
Repetare
Control: Pornire/Pauza/Inainte/Inapoi
Afisare CD text: Disc/ Afisare melodie
Cautare CD Text Name
Cautare procentuala(MP3/AAC/WMA Only)
Zero data Mute
DAC: Multi Bit DAC
Digital Servo
USB
Port USB: Intrare USB frontala de 1000mA, cu suport de incarcare si incarcare rapida la iPhone
Redare: MP3, WMA, AAC Playback
Categorie USB: Mass Storage Class
Cautare dupa nume Fisier/Folder
Cautare procentuala
Folder Sus/Jos
Redare M.I.X.: Fisierele dintr-un folder, Toate
Repetare
Reglare sunet
BassEngine SQ
Low Pass Filter
Loudness
Source Tone Memory
General
Putere de iesire: 4 x 50W High Power Amplifier
Afisaj LCD: 13 Segments White LCD Display 1Line
Tip control: Rotary Encoder Knob
Iluminare butoane: Rosu (CDE-180RR), Verde (CDE-180R), Portocaliu (CDE-180RM),
PreOut: 2 PreOuts (2V, Fata + Spate/Subwoofer)
AUX-In: Intrare AUX frontala (3.5mm mini jack)
Pregatit pentru interfata comenzi volan
Pregatit pentru telecomanda
Meniu in limba: Engleza, Germana, Franceza, Italiana, Spaniola, Olandeza, Rusa
Panou detasabil DIN Trim
Panou frontal detasabil
Dimmer
Cablu alimentare antena
Remote Turn-On
Alimentare: 14.4 V.DC (11-16V admisibil)
Voltaj Pre Output (Before Clipping): 2V / 10k ohmi
Aux In: 1.4V / 10k ohmi
Culoare fata: Negru
Vand adaptor semnal High-low
Helix AAC
-convertor semnal high-low controlat activ, alimentat la 12V
-interval larg de frecventa, 18 Hz - 22 KHz
-ofera o pereche RCA preout si semnal remote on pentru pornirea amplificatorului
-made in Germany
