Go Back   Forum 4Tuning > AUTO COMERCIAL > Bazar CAR AUDIO > DVD / TV Auto / Navigatii
DVD / TV Auto / Navigatii DVD, TV Auto, DVD Auto Player, TV Masina, LCD, Tv Tuner, TFT, Monitoare, Multimedia, ICE, Parasolar, Monitor Plafon , Navigatii, audio
Old 04-04-12, 22:50   #1
maximus25
Default Dvd Kenwood Dnx 5260bt Cu Navi Divx Usb Si Bt
6.1 inch Wide VGA colour TFT
Multi language GUI & text
Variable key illumination (Hard keys & GUI colour)
1 AV-In (Front), 1 AV-Out, 1 Video In for optional rear view camera
iPod, iPhone USB direct control (Requires KCA-iP301V)
Bluetooth built-in (handsfree profile/SMS)
Built in Garmin Navigation system (new platform), with V12 map included
TMC(pro) decoder built-in)
Front micro SD slot for navigation update
DivX, MPEG 1/2 Video File & JPEG File, AAC, WMA, MP3 playback
General Features
DIN Size 2 DIN
Disabled System Indicator (DSI) Yes
Security Code Function ( user set) Yes
On Screen Display (OSD) Operation Yes
Smooth GUI Yes
Key Illumination Variable color
Rotary Encoder & Control Knob Yes
Installer Memory Yes
Back-up Memory Yes
Attenuator with Smooth Volume Return Yes
Touch Sensor Tone Yes
Optional IR remote controller Yes, KNA-RCDV331
Digital Clock (24H) Yes
ISO connector Yes
Bluetooth unit built-in (powerd by Parrot) Yes
Navigation unit built-in Yes
Navigation Features
Touch-screen controllable Yes
IR Remote controllable Yes, Remote optional (KCA-RCDV331)
Easy-to-use Graphical Interface Yes
Built-in Map Data (West-Europe) V12
Map Upgrade via micro SD Card
Monitor Features
Screen Type TFT 6,1" Wide
Display Mode 4 Mode (Full/Just/Zoom/Normal)
High Resolution VGA Display Yes
Screen Adjustments Brightness/Tint/Color/Contrast/Black Level/Dimmer
Dimmer function ON/OFF/Sync/Navi-Sync
Visual Source Mode DVD/Video/Navigation/(TV)/USB/iPod
Touch Panel Yes
Mechanism Angle Adjustment none (fixed faceplate)
NTSC/PAL judge Auto
Multimedia GUI Features
OSDC Type Full Graphics
GUI colour coordinate Yes
Menu text English
Skin Change Yes, 3D, Fire & Metal
Colour Pallet 29790
Background Customize Yes
Tuner Features
Radio Data System Yes
Radio Text Plus Yes
Program Type Function (PTY) Yes
Enhanced Other Networks Function (EON) Yes
K3I - Clean Reception Tuner Yes
FM Reception Yes
AM (MW/LW) Reception Yes
Presets 24 Presets (18FM / 3LW / 3MW)
Station Select List
Automatic Memory Entry (AME) Yes
Up/Down Seek Tuning Yes
Tuning mode (Auto1 / Auto2 / Manual) Yes
FM Stereo / Mono Selector Yes
DVD-Features
Mechanism DVS-8500
Disc Capacity 1 Disc(s)
DVDąR/RW Compatible Yes
DVD Region Code 2
VCD Compatible Yes
CD-R/RW Compatible Yes
CD Text Yes
MP3 Yes
ID3 Tag Yes
WMA Yes
WMA Tag Yes
AAC Yes
AAC Tag Yes
WAV Yes
Digital/Analog Converter 24 bit
Shock Proof Yes
MPEG1/2 Video File (.mpg) Compatible Yes
JPEG File (.jpg) Compatible Yes
DivX (Certified) Yes
CD-DA Repeat/Scan/Random play Yes
Direct Search Yes
Time Code Display Yes
Resume Play Yes
Zoom Control (DVD/VCD) Yes
Disc Menu Direct Touch Yes
Picture Control (JPEG) Yes
USB Features
USB terminal Yes
USB Type USB1.1 / USB 2.0
MP3 playback with ID3 Tag Display Yes
WMA (Windows Media File) playback Yes
AAC (Advanced Audio Codec) playback Yes
WAV (Waveform Audio Format) playback Yes
MPEG1 Video decoder Yes
MPEG2 Video Decoder Yes
DivX Video Decoder Yes
JPEG slide show Yes
JPEG picture control Yes
Repeat/Scan/Random search Yes
Category search Yes
Resume play Yes
Time code display Yes
iPod Features
Made for iPod & iPhone * Yes
USB Video & Audio direct control (3 wire) with optional cable KCA-iP301V
Music playback Yes
Video playback Yes
Album art support Yes
Music library search Yes
Alphabet search Yes, up to characters
Works with iPod Classic * 80G & 120G
Works with iPod Video * 5th/6th generation
Works with iPod Touch * 1st/2nd Gen
Works with iPod Nano * 1st/2nd/3rd/4th/5th Gen
Works with iPhone * Yes, iPhone, iPhone 3G & iPhone 3GS
Battery charge + power control Yes
* Always update to latest Apple firmware
Audio features
Max. Output Power (MOSFET Power IC) 4 x 50W
Pre-out 3RCA: Front/Rear/Subwoofer
Pre-out Output Level 2V
Auxiliary Input AV Front Input with optional CA-C3AV
Rear / Subwoofer Switchable Yes
Subwoofer Reference Level Adj. Yes
Dual Zone Source & Volume Control Yes
Dual Zone (FRONT / REAR Switchable) Yes
Source Tone Control & Memory Bass / Mid / Treble
Balance/Fader Control Yes
Loudness Control Yes
Att.(-20dB) with smooth Volume Return Yes
System QEX (Preset & Manual Sound Control) Yes
System E's+ (Built-in HPF & LPF) Yes
Beep On/Off Yes
Video Features
Audio/Video Output 1 RCA
Audio/Video Input Yes, Mini-jack in front panel, need optional CA-C3AV
iPod AV input switchable to additional AV input Yes
Video-In for Rear-view Camera 1 dedicated video input (RCA)
Detection Mode Rear View Camera Reverse sensor wire
DVD Menu Direct Touch Operation Yes
MPEG Decoder Yes
TV ready Yes
Connectivity
OEM Wired Remote Control Yes
Parking sensor wire Yes
Reverse sensor wire Yes
Power Control (P.CON) wire Yes
2-way (Tel/Navi) mute wire Yes
Dimmer control wire Yes
TV Tuner Control Yes
GPS Antenna Input Yes
External microphone input Yes
Bluetooth General Features
Hands free Profile (HPF) Yes
Serial Port Profile (SPP) Yes
Headset Profile (HSP) Yes
Phonebook Access Profile (PBAP) Yes
Phone numbers hold: up to 1000 per registered phone.
Object Push Profile (OPP) Yes
Synchronization Profile (SYNC) Yes
Short Message Service (SMS) Yes
Phone device status display Yes
Signal strength display Yes
Remaining battery display Yes
Bluetooth phones to register 5
High-quality noise canceling microphone Yes, external microphone
Bluetooth firmware upgradeable Yes
* depends on phone model/make
AM LA EL ANTENDA DE GPS MICROFONU PT BT RAMELE SI HARTIILE CU ROMANIA
PRET 1800 RON
TEL 0723 583 411
ID:	2389240   Click image for larger version
maximus25 is offline   Reply With Quote
Old 11-04-12, 14:20   #2
maximus25
Default Re: Dvd Kenwood Dnx 5260bt Cu Navi Divx Usb Si Bt
pret nou 1700 ron am toate accesoriile +harta romaniei
- Copyright 2025 4Tuning -
