Go Back   Forum 4Tuning > AUTO COMERCIAL > Bazar CAR AUDIO > DVD / TV Auto / Navigatii
DVD / TV Auto / Navigatii DVD, TV Auto, DVD Auto Player, TV Masina, LCD, Tv Tuner, TFT, Monitoare, Multimedia, ICE, Parasolar, Monitor Plafon , Navigatii, audio
Old 06-03-10, 10:12   #1
maximus25
Default Dvd Auto Jvc Avx 1 Impecabil
AV Systems
DVD Player KD-AVX1
Video Format NTSC
Shock Proof Memory Yes
Video DAC 10-bit/54MHz DAC
DTS/Dolby Digital/MPEG Audio Yes
Dual-Zone Function Yes
Pause/Step/Slow Yes (with remote control)
Zoom Yes (with remote control)
Direct Chapter Access Yes (with remote control)
Frequency Response 16 - 22,000Hz (DVD fs=48/96kHz), 16 - 20,000Hz (CD)
Dynamic Range 93dB (fs=48kHz)
Signal-to-Noise Ratio 95dB (fs=48kHz)
Channel Separation 85dB (at 1kHz, fs=48kHz)
Wow & Flutter Less than measurable limit
VCD Player KD-AVX1
Video Format NTSC
Video CD Playback Control Yes
Direct Track Access Yes (with remote control)
Pause Yes (with remote control)
Step Yes (with remote control)
CD Player KD-AVX1
MP3/WMA Compatible with ID3 Tag/WMA Tag Yes
CD-R/RW Compatible Yes
CD Text Yes
Disc Name Registration Yes
Random/Repeat Play Yes
Intro Scan Yes
CD Changer Control KD-AVX1
MP3 Control Yes (with CH-X1500)
CD Text Yes (with CH-X1500)
Intro Scan Yes
Radio Tuner KD-AVX1
SIRIUS Ready Yes
Tuner Type
HS-IIIi Yes
Preset Stations 18 FM, 6 AM
SSM (for FM) Yes
AFNS/PNC Yes
Seek (Up/Down) Yes
Stereo/Mono Switch (for FM) Yes
TV Tuner Option Yes
Auto Antenna Yes
European Switchable Tuner Yes
FM
Frequency Range 87.5 - 107.9MHz
Usable Sensitivity 11.3dBf (1.0uV/75 ohms)
50dB Quieting Sensitivity 16.3dBf (1.8uV/75 ohms)
Stereo Separation 35dB
Capture Ratio 1.5dB
AM
Frequency Range 530 - 1,710kHz
Sensitivity 20uV
Selectivity 35dB
Amplifier KD-AVX1
Maximum Power Output 50W x 4
Continuous Power Output (RMS) 20W RMS x 4 Channels at 4 ohms and no more than 1.0% total harmonic distortion + N
MOS-FET Amplifier Yes
Audio DAC 96kHz/24-bit DAC
Source-Specific Volume Control Yes
Volume Attenuator Yes
Balance/Fader Control Yes
Equalizer
7-Band iEQ Yes
Max. Amp Gain Switcher Yes
Amp Defeat Switch Yes
AV Input Terminals (Video + L/R) Yes (Gold-plated)
Line Output Terminals (pair) 2 Pairs (Gold-plated)
Second Audio Output Terminals Yes (Gold-plated)
Subwoofer Output with Level/Frequency Control Yes (Gold-plated)
Optical Digital Output Yes
Frequency Response 40 - 20,000Hz
Load Impedance 4 ohms (4 - 8 ohms allowable)
Pre-output level/impedance 2.0V/1k ohms
Video Output Level/Impedance 1.0Vp-p/75 ohms
Audio Output Level/Impedance 2.0Vrms/1k ohms
Video Input Level/Impedance 1.0Vp-p/75 ohms
Audio Input Level/Impedance 1.5Vrms/20k ohms
Monitor KD-AVX1
Screen Size 3 Inch
Angle Adjustment Yes
Screen Resolution 186 x 220 x 3
LCD Type TFT Active Matrix LCD with Wide Viewing Angle
Color System NTSC
Display KD-AVX1
Switchable Dimmer Yes
Power Switch Standby Illumination Yes
General KD-AVX1
Face Type
Motorized Slide-Out Face Yes
Detachable Face Plate with Carrying Case Yes
Steering Remote Control Ready Yes
Wireless Remote Control Type
Multi-Function Wireless Remote Control Yes
Beep Tone Support Yes
COMPU PLAY Yes
Tel. Muting Yes
Power-Off Mode Eject Yes
Dimensions (W x H x D)
Installation Size 182 x 52 x 160mm (7-3/16" x 2-1/16" x 6-5/16")
Panel Size 188 x 58 x 18mm (7-7/16" x 2-5/16" x 3/4")
Detachable Face Plate Size 169 x 58 x 24mm (6-11/16" x 2-5/16" x 1")
PRET 580 RON
TEL 0723 583 411
maximus25 is offline   Reply With Quote
- Copyright 2025 4Tuning -
