Go Back   Forum 4Tuning > AUTO COMERCIAL > Bazar CAR AUDIO > DVD / TV Auto / Navigatii
DVD / TV Auto / Navigatii DVD, TV Auto, DVD Auto Player, TV Masina, LCD, Tv Tuner, TFT, Monitoare, Multimedia, ICE, Parasolar, Monitor Plafon , Navigatii, audio
Old 03-02-10, 15:02   #1
maximus25
Default Dvd Auto Kenwood Ddx6029 Impecabil
DIN Size 2 DIN
Detachable Faceplate No
Disabled System Indicator (DSI) Yes
Security Code Function (Fixed) Yes
On Screen Display (OSD) Operation Yes
Selectable GUI Background Wallpaper Yes
Key Illumination Blue
Installer Memory Yes
Back-up Memory Yes
Attenuator with Smooth Volume Return Yes
Touch Sensor Tone Yes
IR Remote Control included RC-DV430
Digital Clock (24H) Yes
ISO connector Yes
Made for iPod Yes
Monitor Features
In-Dash/On-Dash In-Dash
Screen Type TFT 6.95" Wide
Display Mode 4 Mode (Full/Just/Zoom/Normal)
Screen Adjustments Brigtness/Tint/Color/Contrast/Black Level
Dimmer function Manual
Visual Source Mode DVD/Video/Navigation/(TV)
Touch Panel Yes
Mechanism type Auto Slide
Mechanism Angle Adjustment 6 steps
Reverse Tilt Yes
Slide Adjustment No
NTSC/PAL judge Auto
Multimedia GUI Features
OSDC Type Character
Colour Pallet 32
Base Colour Class 512
Menu character font English
Menu text in selectable language English
Background Customize Yes
Tuner Features
RDS (PI, PS, AF, TI, Clock) Yes
Radio Text (RDS) Yes
Program Type Function (PTY) Yes
Enhanced Other Networks Function (EON) Yes
K3I - Clean Reception Tuner Yes
FM Reception Yes
AM (MW/LW) Reception Yes
Presets 24 Presets (18FM / 3LW / 3MW)
Automatic Memory Entry (AME) Yes
Up/Down Seek Tuning Yes
Tuning mode (Auto1 / Auto2 / Manual) Yes
FM Stereo / Mono Selector Yes
DVD-Features
Mechanism DVS-7600
Disc Capacity 1 Disc(s)
DVD±R/RW Compatible Yes
DVD Region Code 2
VCD Compatible Yes
CD-R/RW Compatible Yes
CD Text Yes
MP3 Yes
ID3 Tag Yes
WMA Yes
WMA Tag Yes
Digital/Analog Converter 24 bit
Shock Proof Yes
2nd Disc Prevention Mechanism Yes
MPEG1/2 Video File (.mpg) Compatible Yes
JPEG File (.jpg) Compatible Yes
CD-DA Repeat/Scan/Random play Yes
CD-DA Disc Name Preset (10 disc's) Yes
Direct Search Yes
Time Code Display Yes
dts Digital Output Optical
Resume Play Yes
Zoom Control (DVD/VCD) Yes
Disc Menu Direct Touch Yes
External Media Control Features
Dual Changer Control (CH1, CH2 & AUX) Yes
CD Text Ready with Compatible KENWOOD Units Yes
Disc & Track Repeat Yes
Disc & Track Scan Yes
Disc & Track Random Play Yes
Direct Access Yes
Disc Name Preset Play (DNPS) Yes
Audio features
Max. Output Power (MOSFET Power IC) 4 x 50W
Pre-out 3RCA: Front/Rear/Subwoofer
Pre-out Output Level 2V
Auxiliary Input No
Subwoofer Reference Level Adj. Yes
Dual Zone Source & Volume Control Yes
Dual Zone (FRONT / REAR Switchable) Yes
Source Tone Control & Memory Bass/Treble/Midrange
Balance/Fader Control Yes
Att.(-20dB) with smooth Volume Return Yes
System QEX (Preset & Manual Sound Control) Yes
System E's+ (Built-in HPF & LPF) Yes
Beep On/Off Yes
Video Features
Audio/Video Output 1 RCA
Audio/Video Input 1 RCA
Video-In for Rear-view Camera
Mirror-mode on Rear-view Image Yes
Detection Mode Rear View Camera By Video Signal
RGB Input For Navigation System Yes
DVD Menu Direct Touch Operation Yes
Dolby Digital Decoder Yes
dts Decoder Yes
Linear PCM Decoder Yes
TV ready Yes
TV- tuner Features
PAL System Yes
SECAM System Yes
Band TV1/TV2
Preset 12 (6ch x 2 Band)
Tuning Mode Auto1/Auto2/Manual
Auto Memory Entry Yes
Audio Type Normal
Station Name Preset Yes
Connectivity
Changer Control (5L-Bus) Yes
External Option Control (5L-Bus) Yes
AUX input (5L-Bus) Yes
iPod I/F Control (5L-Bus) Yes
Bluetooth Control (5L-Bus) Yes
PS Amplifier Control System (5L-Bus) PS Amplifiers ('02 - '06)
B.M.S.Control ('99-'03 Amps) Yes
Advanced B.M.S. Control ('02 Amps) Yes
OEM Wired Remote Control Yes
Parking sensor wire Yes
Reverse sensor wire Yes
2-way (Tel/Navi) mute wire Yes
Dimmer control wire Yes
TV Tuner Control Yes
Tuner Specifications
FM Frequency Range 87.5MHz ~ 108MHz
FM Frequency Step 50kHz
FM Usable Sensitivity 0.7μV/75ohm (S/N 26dB)
FM Quieting Sensitivity 1.6μV/75ohm (S/N 46dB)
FM Frequency Response 30Hz ~ 15kHz (± 3dB)
FM Selectivity(DIN) over 80dB (±400kHz)
FM Stereo Separation (1kHz) 35dB
MW Frequency Range 531kHz ~ 1611kHz
MW Frequency step 9kHz
MW Usable Sensitivity 25μV (S/N 20dB)
LW Frequency Range 153kHz ~ 281kHz
LW Usable Sensitivity 45μV (S/N 20dB)
DVD Specifications
D/A Converter 24 bit
Video decoder Linear PCM/Dolby Digital/dts/MP3/WMA
Wow & Flutter Below Measurable Limit
Freq. Resp. (96kHz Sampling) 20Hz ~ 44kHz
Freq. Resp. (48kHz Sampling) 20Hz ~ 22kHz
Freq. Resp. (44,1kHz Sampling) 20Hz ~ 20kHz
Total Harmonic Distortion 0.01% (1kHz)
Signal to Noise Ratio 98dB (1kHz)
Dynamic Range 98dB
Disc Format DVD-Video/Video-CD/CD-DA
FM Signal to Noise Ratio 65dB(MONO)
Sample Frequency 44.1kHz/48kHz/96kHz
Quantifying bit number 16/20/24bit
Audio Specifications
Maximum Power 50W x 4
Output Power (DIN45324,+B=14.4v) 30W x 4
Preout Level 2mV / 10kOhm,
Preout Impedance ≤ 600Ohm
Bass Tone Control 100Hz ±10dB
Middle Tone Control 1kHz ±10dB
Treble Tone Control 10kHz ±10dB
Video Specifications
Color System of External Video Input NTSC/PAL
External Video Input Level (RCA) 1Vpp / 75Ohm
External Audio Max. Input Level (RCA) 2V / 25kOhm
Analog RGB Input 0.7Vpp / 75Ohm
Monitor Specifications
Screen size (Diagonal) 6.95 Inches Wide
Screen Size (WxH) 156.2 x 82.4mm
Display system Transparent TN LCD Panel
Drive system TFT Active Matrix System
Number of Pixels 336960pixels (480(H) x 234(V) x RGB)
Effective pixels 99.99%
Pixel arrangement RGB Striped
Back lighting Cold Cathode Fluorescent Tube
General Specifications
Operating voltage 14.4V (11 ~ 16V Allowable)
Maximum Current Consumption 15A
Dimensions (WxHxD) 182 x 112 x 163mm
Weight 2600gr
Operation Temperature Range -10°C ~ 60°C
Storage Temperature Range -20°C ~ 85°C
PRET 870 RON
TEL 0723 583 411
maximus25 is offline   Reply With Quote
Old 07-02-10, 00:09   #2
braien
Default Re: Dvd Auto Kenwood Ddx6029 Impecabil
sal te interesaza telfefonu meu plus diferenta din partea mea http://www.**********/catalog/354342...300-Specs.html
braien is offline   Reply With Quote
Old 09-02-10, 11:14   #3
maximus25
salut nu ma interseaza
Old 15-02-10, 21:54   #4
maximus25
UPPPPPPPPPPP
Old 20-02-10, 21:00   #5
paryzyanu
Salut.Ecranul e rebatabil?Intra perfect in bordul 2DIN de A6 din 2000? Este esit in afara fata de climatronic? ms.
paryzyanu is offline   Reply With Quote
Old 24-02-10, 22:14   #6
maximus25
IMI PARE RAU DAR L-AM VANDUT
