Vand dvd auto
Phase Linear 8035uv sigilat in cutie. Vine cu toate accesorile (mufa si cabluri de alimentare, teelcomanda, rama, etc) si cutie. Citeste DVD,CD,MP3,VMA are si slot pt card SD.
http://articulo.mercadolibre.com.mx/...sen-uv8035-_JM
MANUAL:
http://audiovox2.info/docs/jensen/man/UV8035_DOC_OM.PDF
Phase linear 8035uv
Monitor Size : 3.5"
Digital wide TFT Liquid crystal display (LCD) screen
Power rating: 40w x 4
Power Max output: 160 watts
Signal to noise ratio : 70dBA below reference (reference : 1 watt, 4-ohms)
Compatible disc media : DVD + R / RW and CD-R / RW
Compatible media formats : CD-DA, MP3, WMA, DVD,SD
SD card Slot
Multi-Zone control
DVD video
Front Audio video (in & out)
3.5mm Front AUX input
Front, Rear and Subwoofer RCA preout
Signal to noise ratio : >95dBA
Frequency Response : 20Hz, to 20 kHz, -3dB
Channel Separation : 60dB @ 1 kHz
Video format : NTSC / PAL
Video output : 1 Vp-p (75-ohm)
Video input : 1 Vp-p (75-ohm)
FM / AM Tuner
YM:adisloop
Tel:0742981568
Pret: 400ron
