Key Features
Fully Motorized Slide-Down Mechanism with Detachable Faceplate
Multicolour(64colours) 3D Dot FL Display (8 Tone)
50W x 4; 3RCA Pre-outs, 1 RCA Aux-in
USB2.0 support - iPod & Bluetooth Ready
AAC, MP3 & WMA Decoder, 24-Bit Digital Audio Converter
General Features
DIN Size 1 DIN
Detachable Faceplate Yes
Protection Case For Faceplate Yes
Faceplate Mechanism Fully Motorized Slide-Down
Angle Adjustment 3 steps
Security Code Function Yes
Key Illumination Selectable: Red or Green
Rotary Encoder & Control Knob Yes
Installer Memory Yes
Back-up Memory Yes
Attenuator with Smooth Volume Return Yes
Touch Sensor Tone Yes
Optional IR remote controller Yes
Digital Clock (24H) Yes
All-off Select (20/40/60 minutes) Yes
ISO connector Yes
Display Features
Display Type 8 Tone Multicolour(64)3D Full Dot FL Display
Display Layout Full Dot (128x23dot)
Display Illumination Fluoricent Display
Dimmer Control 2 steps - Automatic
Display Blackout Yes
Display Off Mode Yes
Demo Mode Yes
Special Character Display No
Tuner Features
Radio Data System Yes
Radio Text Yes
Program Type Function (PTY) Yes
Enhanced Other Networks Function (EON) Yes
K3I - Clean Reception Tuner Yes
FM Reception Yes
AM (MW/LW) Reception Yes
Presets 24 Presets (18FM / 3LW / 3MW)
Automatic Memory Entry (AME) Yes
Up/Down Seek Tuning Yes
Tuning mode (Auto1 / Auto2 / Manual) Yes
FM Stereo / Mono Selector Yes
CD Features
CD-R/RW Compatible Yes
MP3 Playback with ID3 Tag Display Yes
WMA (Windows Media Audio) Playback Yes
AAC (Advanced Audio Coding) Playback Yes
ACDrive, PC Application Software included Yes
Voice Index Yes
CD Text Support Yes
D.A.C. processing 24 bit (Wolfson)
0 bit Mute L/R Independent
Random Function (Track/Disc) Yes
Repeat Function (Track/Disc) Yes
Scan Function (Track/Disc) Yes
USB Features
USB terminal Yes, rear side
USB Type USB1.1 / USB 2.0
USB extension cable supplied no
ACDrive compatible Yes
MP3 playback with ID3 Tag Display Yes
WMA (Windows Media File) playback Yes
AAC (Advanced Audio Codec) playback Yes
iPod Features
Made for iPod Yes
iPod control by 5L bus Yes, with optional KCA-iP500
Music playback Yes
Battery charge + power control Yes
External Media Control Features
Dual Changer Control (CH1, CH2 & AUX) Yes
CD Text Ready with Compatible KENWOOD Units Yes
Disc & Track Repeat Yes
Disc & Track Scan Yes
Disc & Track Random Play Yes
Direct Access Yes
Disc Name Preset Play (DNPS) Yes
Audio Features
Maximum Output Power 50W x 4
MOSFET Power IC Yes
Auxiliary input 1 RCA
Pre-out 3 RCA
Pre-out Output Level 2.5V
Subwoofer Reference Level Adj. Yes
Built-In Amplifier Cut-Off Yes
Dual-Zone Source & Volume Control Yes
Dual-Zone (FRONT / REAR Switchable) Yes
Source Tone Control & Memory Bass / Mid / Treble
Balance/Fader/Loudness Control Yes
Att.(-20dB) with smooth Volume Return Yes
System Q_EX (Preset & Manual Sound Control) Yes
System E's+ (Built-in HPF & LPF) Yes
Connectivity
Changer Control (5L-Bus) Yes
External Option Control (5L-Bus) Yes
iPod I/F Control (5L-Bus) Yes
Bluetooth Control (5L-Bus) Yes
PS Amplifier Control System (5L-Bus) PS Amplifiers ('02 - '06)
B.M.S.Control ('99-'03 Amps) Yes
Advanced B.M.S. Control ('02 Amps) Yes
OEM Wired Remote Control Yes
OEM Display Control Yes
2-way (Tel/Navi) mute wire Yes
Dimmer control wire Yes
Tuner Specifications
FM Frequency Range 87.5MHz ~ 108MHz
FM Frequency Step 50kHz
FM Usable Sensitivity 0.7μV/75ohm (S/N 26dB)
FM Quieting Sensitivity 1.6μV/75ohm (S/N 46dB)
FM Frequency Response 30Hz ~ 15kHz (± 3dB)
FM Selectivity(DIN) over 80dB (±400kHz)
FM Stereo Separation (1kHz) 35dB
MW Frequency Range 531kHz ~ 1611kHz
MW Frequency step 9kHz
MW Usable Sensitivity 25μV (S/N 20dB)
LW Frequency Range 153kHz ~ 281kHz
LW Usable Sensitivity 45μV (S/N 20dB)
CD Specifications
Laser Diode GaAIAs
Digital Filter(D/A) 8 Times Over Sampling
Digital/Analogue Converter 1 Bit
Spindle Speed 1000 ~ 400rpm (CLV: 2 times)
Wow & Flutter Below Measurable Limit
Frequency Response 10Hz ~ 20kHz (±1dB)
Total Harmonic Distortion 0.008% (1kHz)
Signal to Noise Ratio 110dB (1kHz)
Dynamic Range 93dB
MP3 Decoder Compliant with MPEG-1/2 Audio Layer-3
WMA Decoder Compliant with Windows Media Audio
AAC Decoder AAC-LC ".m4a" files
USB Specifications
USB Version compatibility 1.1 / 2.0
File System FAT 16/32
Maximum Supply current 500mA
MP3 Decode Compliant with MPEG-1/2 Audio Layer-3
WMA Decode Compliant with Windows Media Audio
AAC Decode AAC-LC ".m4a" files
Audio Specifications
Maximum Power 50W x 4
Output Power (DIN45324,+B=14.4v) 30W x 4
Preout Level 2500mV / 10kOhm,
Preout Impedance ≤ 600Ohm
Speaker Impedance 4Ohm ~ 8Ohm
AUX Frequency Response 20Hz ~ 20kHz (±1dB)
AUX Maximum Input Voltage 1200mV
AUX Input Impedance 100kOhm
Bass Tone Control 100Hz ±8dB
Middle Tone Control 1kHz ±8dB
Treble Tone Control 10kHz ±8dB
pret 450 ron
tel 0723 583 411
