Go Back   Forum 4Tuning > AUTO COMERCIAL > Bazar CAR AUDIO > HU - CD Playere / MP3
HU - CD Playere / MP3 Head Unit, HU, CD Playere MP3, MP3 Player Auto, Casetofoane Auto, Radio CD Player, audio
Old 10-02-10, 09:14   #1
loryubitamea
loryubitamea's Avatar
Default Kenwood KDC-W7537U USB
Key Features
Flip-Down Full Detachable Faceplate
50w x 4, Max Output Power
Mini-jack AUX input, 2 RCA preouts
USB interface port
WAV/MP3/WMA/AAC Decoder Built-in
iPod Direct & Bluetooth Ready
Monocolour, Full DOT Display
General Features
DIN Size 1 DIN
Detachable Faceplate Yes
Protection Case For Faceplate Yes, Soft Case
Faceplate Mechanism Flip-down Detachable Faceplate
Angle Adjustment No
Disabled System Indicator (DSI) Yes
Security Code Function Yes
Rotary Encoder & Control Knob Yes
Operation mode 4-Directions + Push + Rotary
Multi control wheel Yes
Installer Memory Yes
Back-up Memory Yes
Attenuator with Smooth Volume Return Yes
Touch Sensor Tone Yes
Optional IR remote controller Yes
Digital Clock (24H) Yes
All-off Select (20/40/60 minutes) Yes
Built-in Connector Molex 16 pin
ISO connector Yes, Molex to ISO cable
Display Features
Display Type 8 Tone Monocolour FL Display
Display Layout Full Dot (128x29dot)
Dimmer Control 2 steps - Automatic
Display Blackout Yes
Display Off Mode Yes
Demo Mode Yes
Special Character Display No
Cosmetics features
Front/edge Piano black
Dress plate Tin Cobalt Plated
Volume & operation knob or wheel Chrome Plated
Preset key finish Piano Black (Laser Cut)
Escutcheon finish Piano Black
Triangle Illumination Red
Volume & operation knob illumination Blue
Key illumination Red or Green (selectable)
Tuner Features
RDS (PI, PS, AF, TI, Clock) Yes
Radio Text (RDS) Yes
Program Type Function (PTY) Yes
Enhanced Other Networks Function (EON) Yes
K3I - Clean Reception Tuner Yes
FM Reception Yes
AM (MW/LW) Reception Yes
Presets 24 Presets (18FM / 3LW / 3MW)
Automatic Memory Entry (AME) Yes
Up/Down Seek Tuning Yes
Tuning mode (Auto1 / Auto2 / Manual) Yes
FM Stereo / Mono Selector Yes
CD Features
CD-R/RW Compatible Yes
MP3 Playback with ID3 Tag Display Yes
WMA (Windows Media Audio) Playback Yes
AAC (Advanced Audio Coding) Playback Yes
WAV (Waveform Audio Format) Playback Yes
Kenwood Music Editor Software included Yes
CD Text Support Yes
CD Text with special Character Support No
Supreme Yes
D.A.C. processing 24 bit (Wolfson)
0 bit Mute Yes
Random Function (Track/Disc) Yes
Repeat Function (Track/Disc) Yes
Scan Function (Track/Disc) Yes
USB Features
USB terminal Yes, Rear
USB Type USB1.1 / USB 2.0
USB extension cable supplied no
MP3 playback with ID3 Tag Display Yes
WMA (Windows Media File) playback Yes
AAC (Advanced Audio Codec) playback Yes
WAV (Waveform Audio Format) playback Yes
iPod Features
USB Direct control (2 wire) with optional cable KCA-iP200
Music playback Yes
Music library search Yes
Works with iPod Classic *
Works with iPod Video * 5th/6th generation
Works with iPod Nano * 1st/2nd/3rd/4th Gen
Works with iPod Touch * 1st/2nd Gen
Battery charge + power control Yes
* Always update to latest Apple firmware
External Media Control Features
Dual Changer Control (CH1, CH2 & AUX) Yes
CD Text Ready with Compatible KENWOOD Units Yes
Disc & Track Repeat Yes
Disc & Track Scan Yes
Disc & Track Random Play Yes
Disc Name Preset Play (DNPS) Yes
Audio Features
Maximum Output Power 50W x 4
MOSFET Power IC Yes
Auxiliary input Yes, Rear
Auxiliary Type Mini-jack
Pre-out 2 RCA
Pre-out Output Level 2.5V
Preout Rear / Subwoofer Switchable Yes
Subwoofer Reference Level Adj. Yes
Built-In Amplifier Cut-Off Yes
Dual-Zone Source & Volume Control Yes
Dual-Zone (FRONT / REAR Switchable) Yes
Source Tone Control & Memory Bass / Mid / Treble
Balance/Fader/Loudness Control Yes
Att.(-20dB) with smooth Volume Return Yes
System Q_SP/M (Preset & Manual Sound Control) Yes
System E's+ (Built-in HPF & LPF) Yes
Connectivity
Changer Control (5L-Bus) Yes
AUX input (5L-Bus) Yes
iPod I/F Control (5L-Bus) Yes
Bluetooth Control (5L-Bus) Yes
PS Amplifier Control System (5L-Bus) Ps Amplifiers ('02 - '06)
iPod Direct Control (2 wire) Yes
B.M.S.Control ('99-'03 Amps) Yes
Advanced B.M.S. Control ('02 Amps) Yes
OEM Wired Remote Control Yes
OEM Display Control Yes
2-way (Tel/Navi) mute wire Yes
Dimmer control wire Yes
Tuner Specifications
FM Frequency Range 87.5MHz ~ 108MHz
FM Frequency Step 50kHz
FM Usable Sensitivity 0.7μV/75ohm (S/N 26dB)
FM Quieting Sensitivity 1.6μV/75ohm (S/N 46dB)
FM Frequency Response 30Hz ~ 15kHz (± 3dB)
FM Selectivity(DIN) over 80dB (±400kHz)
FM Stereo Separation (1kHz) 35dB
MW Frequency Range 531kHz ~ 1611kHz
MW Frequency step 9kHz
MW Usable Sensitivity 25μV (S/N 20dB)
LW Frequency Range 153kHz ~ 281kHz
LW Usable Sensitivity 45μV (S/N 20dB)
CD Specifications
Laser Diode GaAIAs
Digital Filter(D/A) 8 Times Over Sampling
Digital/Analogue Converter 1 Bit
Spindle Speed 500 ~ 200rpm (CLV: 1 times)
Wow & Flutter Below Measurable Limit
Frequency Response 10Hz ~ 20kHz (±1dB)
Total Harmonic Distortion 0.008% (1kHz)
Signal to Noise Ratio 110dB (1kHz)
Dynamic Range 93dB
MP3 Decoder Compliant with MPEG-1/2 Audio Layer-3
WMA Decoder Compliant with Windows Media Audio
AAC Decoder AAC-LC".m4a" Files
WAV Decode Linear - PCM Files
USB Specifications
USB Version compatibility 1.1 / 2.0
File System FAT 16/32
Maximum Supply current 500mA
MP3 Decode Compliant with MPEG-1/2 Audio Layer-3
WMA Decode Compliant with Windows Media Audio
AAC Decode AAC-LC "m4a" Files
Audio Specifications
Maximum Power 50W x 4
Output Power (DIN45324,+B=14.4v) 30W x 4
Preout Level 2500mV / 10kOhm,
Preout Impedance ≤ 600Ohm
Speaker Impedance 4Ohm ~ 8Ohm
AUX Frequency Response 20Hz ~ 20kHz (±1dB)
AUX Maximum Input Voltage 1200mV
AUX Input Impedance 100kOhm
Bass Tone Control 100Hz ±8dB
Middle Tone Control 1kHz ±8dB
Treble Tone Control 10kHz ±8dB
General Specifications
Operating voltage 14.4V (11 ~ 16V Allowable)
Maximum Current Consumption 10A
Dimensions (WxHxD) 182 x 53 x 155mm
Weight 1400gr
Nr tel - 074789102
Pret - 450
loryubitamea is offline
Old 12-02-10, 09:23   #2
loryubitamea
Default Re: Kenwood KDC-W7537U USB
valabil... schimb doar cu apine cu iesiri pe 4v
Old 15-02-10, 21:12   #3
loryubitamea
valabil...
- Copyright 2025 4Tuning -
