Amplificatoare auto & stuff Amplificatoare Auto, Statii, Cabluri, Condensatoare, Baterii Deep Cycle, audio |
20-05-08, 12:05
#16
Audi Driver
Member of: [AUDI]
Re: → → → Urgent Cumpar Player Amplificator Boxe Auto ← ← ←
!!!uuuuuuuuuuuuuuuuuuuuuuuup!!!
22-05-08, 18:36
#17
Audi Driver
Member of: [AUDI]
22-05-08, 18:53
#18
Infinity REF475a
este impecabila folosita in functionare vreo 10 ore ,
---impecabila , o am de vreo 2 luni ,
---exceptionala,
-----450 ron discutabil-------
Power Output 75 watts RMS x 4 channel at 4 ohms and mai mic sau egal cu 1% THD + N 180 watts RMS x 2 channel at 4 ohms, 14. 4V supply and mai mic sau egal cu 1% THD + N
Signal-to-Noise Ratio 85dBA (reference 1 watt into 4 ohms)
Dynamic Power 117 watts at 2 ohms
Effective Damping Factor 6. 315 at 4 ohms
Frequency Response (-3dB) 10Hz to 100kHz (-3dB)
Maximum Input Signal 6V
Maximum Sensitivity 100mV
muzica tare=vecini invidiosi
23-05-08, 01:23
#19
Am Un Alpine Cda-9812rr Care Se Aprinde Pe Rosu Impecabil 3 Iesiri Pt Statie Pe 4v Control Subwoofer La 550 Ron
Si O Statie Rockford Fosgate Model Mai Vechi De 4x100w Rms Sau 2x400w Rms Este Facuta In Usa 150 De Euro
29-05-08, 13:32
#20
Member of: [SKODA]
am un amplif de putere contacteazama pe msg roby200487@yahoo.com sa itzi dau detalii
02-06-08, 17:27
#21
Audi Driver
Member of: [AUDI]
!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! up
03-06-08, 00:36
#22
iti fac oferta... cele 2 pomenite cu 1100 ron...
15-06-08, 00:44
#23
Audi Driver
Member of: [AUDI]
up up up up up - nimeni boxe valabile pe 13 ? sisteme ...
15-06-08, 01:00
#24
Member of: [Crazy Drivers] [PARTICIPANT CURSE] [LANCIA]
Originally Posted by semecristian
Din ce va, iti trebuie difuzoare ( set cu tweeter) pe 13cm.
Am ceva care te-ar putea satisface, nu sunt marca pe care o vrei insa pot fi la fel de bune.
EMPHASER Coax 2-Way 5.25"/130mm
-120 W RMS
The ultimate requirement: best sound quality combined with flat frequency response and ease of installation. EMPHASERs coaxials do meet these criteria with ease. The ECX-S4 coaxial systems resemble the component systems in more than just the visual aspects. The powerful 2-way coaxials have taken over many of the power-oriented features of the compos:
Euro-DIN baskets with acoustically optimized rib-design
¦ heavy duty strontium ferrite ceramic magnets for excellent efficiency
¦ metallized injection-cast polypropylene cones, half-roll butyl rubber surrounds
¦ extended center pole
| 19 mm neodymium tweeter
The cone suspension deploying progressive black Nomex spiders, puts emphasis on the coaxial systems claim to high performance and high quality. Polyimide voice coil formers with copper-clad aluminum wire wound in two layers are another sign that, EMPHASER not just stands for power, but for SQ as well. All coaxial models feature a 19 mm neodymium tweeter with aluminum dome a design variation that yields high efficiency and wide dispersion the mid/high frequency range.
PRET 370 RON setul.
Mai bine de atat nu pot sa iti ofer. Am gresit poza , am pus de la cele de 8.5cm...
Link cu detalii la ECX130S4:
http://www.emphaser.com/data/speaker/coaxuk.pdf
Poza reala e asta:
Pe stoc. Livrare imediata & gratuita.
Date de contact:
Telefon : 0742306018
Email : dn_bradu@yahoo.com
Judet: Suceava
`93 Lancia Thema 2.0i 16V TURBO LX 148kw
Objects in the mirror no longer matter.
15-06-08, 01:31
#25
Da, mai am 2 variante, compo systems, care vine indata pe stoc:
1.ECP25XT4 / EMPHASER XT4-Series Compo 2-Way 13cm
ALTE DETALII PE SITEUL PRODUCATORULUI:
http://www.emphaser.com/data/speaker/composuk.pdf
Technical Specifications ECP25XT4
Peak Power Handling 175 W
Continuous Power Handling 150 W RMS
Crossover Slopes (MW/TW) 6/12 dB/oct.
Crossover Frequency 3300 Hz
Nominal Impedance 4 Ohms
Sensitivity 87 dB
Frequency Response (- 3dB) 65 Hz 25 kHz
Mounting Depth 72 mm
Mounting Diameter 122 mm
NEODYMIUM TWEETER
Overall Diameter 46 mm Mounting Height (flat surface) 22 mm
PRET 980 RON ( TVA inclus)
Livrare gratuita, incepand de saptamana viitoare.
2. RA13.2 / RADICAL 13cm Compo-System Series II
Technical DataRA13.2
Type 2-Way Set
Nominal Dimension 13 cm Euro-DIN
Continuous Input Power 120 Watts
Sensitivity 85.2 dB
Nominal Impedance 4 ohms
Resonance Frequency 3000 Hz
Frequency Response (-3 dB) 60 Hz - 23 kHz
Voice Coil Diameter 36 mm
http://www.radical-audio.com/print_ra13_2uk.html
SAU AICI LA PRODUCTS / AUDIOPHILE SYSTEMS / COMPOS / RA13.2 :
http://www.radical-audio.com/radicaluk.html
PRET 1020 RON (TVA inclus)
15-06-08, 12:30
#26
Member of: [DAEWOO]
31-07-08, 01:21
#27
Audi Driver
Member of: [AUDI]
uuuuuuuuuuuup!
31-07-08, 11:28
#28
De unde e asa de urgent? ai 2 luni de cand tot intrebi, ti se ofera, si tot intrebi si iar ti se ofera, si vad ca intrebi in continuare....
31-07-08, 11:54
#29
am eu amplificator MacAudio mp 4000 folosit foarte putin este k nou fara urme am si cutia la el si manualul de utilizare..... amplificator pe 4 canale ...este impecabil atasezi si o poza......pretz 260 ron negociabil ....bafta
putere RMS (4 ohm)
stereo: 4 x 75 W
in punte: 2 x 200 W
putere maxima: 4 x 200 W (2 x 500 W)
stabil in 2 ohmi (4 x 100 W RMS)
raspuns in frecventa 5 - 50000 Hz (-3 dB)
filtru trece-jos variabil 50 - 250Hz (12dB)
filtru trece-sus variabil 40 - 500 Hz (12dB)
bass boost variabil 0 ... 12 dB la 45 Hz
selector mod functionare 4/3/2 canale
circuit de protectie la scurtcircuit
LED verde / rosu de avertizare
dimensiuni: 319 x 59 x 226 mm.......
