POWER TO POUND WITH HIGH QUALITY BASS
Thunder 4500 High-performance Sub woofers Series pick-up where other brand’s so called top-of-the-line woofers leave off. Packed with features, these subs are the easy choice for rock solid bass, sound quality and reliability.
Thunder 4500 subs feature the same ALDS (Asymmetrical Linear Drive System), found in Thunder Super Woofers (the flat progressive spider, combined with the extended pole piece). We've added some other touches to make sure these sub-woofer speakers perform way, way, past your expectations . . . . . . .
- Precision Stamped Basket for greater structural integrity
- 125 - 250 Watts rms Power Handling
- Up to more than 1/2" Xmax for big Volume Displacement
- FEA optimized roll geometry to maximize excursion without sacrificing cone surface area
- Expanded Poly Cone Dust Cap is injection molded, carbon filled, expanded polypropylene with aluminium deposition for dramatically increased stiffness/weight ratio
- ALDS Asymmetrical Linear Drive System with a flat progressive spider and extended pole piece for smooth, linear, piston like drive
- 1.5" Voice Coils for high power handling and serious excursion
- Apical voice coil former for high power handling.
- Industry leading thermal power handling using 428˚ F High Temperature Voice Coil Wire
- Strontium ferrite magnet yields a highly efficient speaker
- Industry leading Spider Plateau Venting cooling system cools at the voice coil
- Long Integral Tinsel Leads are woven into the spider for better bass extension with greater durability.
- Machined Plates that add impact to the driver's style
- Industry Standard Cut Out Pattern
- Sealed Box volume as low as .5 cubic feet
- Vented Box volume as low as 1.0 cubic feet
Pret 350 ron
Tel 0761692306
Id mes asonedany
