Old 25-07-05, 21:14   #1
SHOGUN-A8
SHOGUN-A8's Avatar
Default Honda S2000 vs. Audi TT
Audi TT:
Turbo compressor
- 1,781 cc 1.8 liters in-line 4 front engine with 81 mm bore, 86.4 mm stroke, 9.5 compression ratio, double overhead cam and five valves per cylinder
- Premium unleaded fuel
- Fuel economy EPA highway (mpg): 29 and EPA city (mpg): 21
- Multi-point injection fuel system
- 14.5 gallon main premium unleaded fuel tank
- Power: 134 kW , 180 HP SAE @ 5,500 rpm; 173 ft lb , 235 Nm @ 1,950 rpm
Honda S2000:
ENGINE 16-Valve DOHC VTEC Inline-4 (F22C1)
HP 240@7800
Torque (lb.-ft.@rpm) 162@6500
0-60 mph 6.2 s
0-100 mph 14.9 s
1/4 Mile 14.5 s @ 99.2 mph
Top Speed 147 mph
ID:	35131   Click image for larger version
Anyway....Chernobyl....here i come...I love Chernobyl!!!
SHOGUN-A8 is offline   Reply With Quote
Old 26-07-05, 00:36   #2
Rolex_Logan
Rolex_Logan's Avatar
nu stiu de ce mai are sens comparatia S2000 clar mai ales ca din cate stiu eu si sper sa nu vb aiurea daca da sa fiu corectata dar SAE inseamna ca atat are motorul dar la roata ajung mult mai putini cai ... ceea ce face TT-ul si mai slab
Oricat ai evita radarele politiei tot te va prinde unu mai devreme sau mai tarziu. Fii cu ochii in 4!!!
Renault Clio Symbol Expression 1.4 16v
Rolex_Logan is offline   Reply With Quote
Old 26-07-05, 11:16   #3
Razvan P
Razvan P's Avatar
[Insomnia]
daca tot vrei sa faci o comparatie intre cele 2 masini ia varianta de 225 cai de audi tt ( quattro )
Razvan P is offline   Reply With Quote
Old 26-07-05, 17:19   #4
TND--TEAM
TND--TEAM's Avatar
in situati de fata s2000 cred eu
TND--TEAM is offline   Reply With Quote
Old 26-07-05, 17:44   #5
Race
SAE inseamna putere la motor.Toate valorile pe care le dau producatorii sunt puteri la motor nu la roata.Si eu cred ca S2000 trebuie comparata cu 1.8T/225 CP sau 3.2.Si in ambele cazuri as prefera S2000.
Race is offline   Reply With Quote
Old 26-07-05, 17:56   #6
pimp_lex
pimp_lex's Avatar
TT roadster de 3.2(daca exista, daca nu ala de 225c) ar fii cel mai apropiat de S2000, in nici un caz cel de 180 cp.
Personal imi place mult TT-ul exterior si interior, e o masina mai usor de condus normal, ceva mai practica, dar luand strict performantele S2000 e superior. Plus ca iarasi TT pica rau cu pretul, in varianta 3.2 e MULT mai scump ca S2000.
pimp_lex is offline   Reply With Quote
Old 27-07-05, 10:14   #7
andreitentean
andreitentean's Avatar
indiferent de motorul tt-ului honda va invinge.
cu motoare de serie le bat eu cu ctr-ul , ca sa nu vorbin despre ce le face s2000.
andreitentean is offline   Reply With Quote
Old 27-07-05, 12:08   #8
zarathustra
zarathustra's Avatar
trebuia bagat tt-ul de 350 de cai daca tot punem cel mai bun motor
oricum honda scoate la s2000 120cp/l si sunt cei mai buni... in cazul de fata nu vad sensul comparatiei... doar ca audi arata mai bine in interior... e mai comod, mai multe optiuni... who needs all that?
Mazda RX-8, Rosu metalizat - vanduta
BMW 335xi coupe, Negru Metalizat
zarathustra is offline   Reply With Quote
Old 27-07-05, 21:57   #9
lolek
ntz ... nu e buna comparatia ... tt de 180 o fura urat de la ctr ... numai vb de s2000 ...
lolek is offline   Reply With Quote
Old 28-07-05, 07:16   #10
200SX
4 Speed Squad Member
200SX's Avatar
[4 Speed Squad]
S2000, si pentru performate si pentru design
Old 28-07-05, 09:32   #11
Razvan P
Razvan P's Avatar
[Insomnia]
s 2000 nu prea e masina...e asa o jucarie care fuge rau
andrei tu faci tt-ul de 225 cai cu civicul stock ?
iar tt-ul fiind turbo tuningul pe parte de motor e mult mai accesibil si plusul de putere e evident mai mare
au am vrut sa-mi iau tt dar nu incap in roadster (la propriu) iar in coupe vizibilitatea e foarte mica iar s 2000 nu-mi place cum arata...dar asta e o parere subiectiva
www.insomniaracing.org
Old 28-07-05, 19:13   #12
nikkon_kde
nikkon_kde's Avatar
eu aleg honda.motoru ala e o adevarata bijuterie!!!
nikkon_kde is offline   Reply With Quote
Old 28-07-05, 19:36   #13
slater
slater's Avatar
[Crazy Drivers]
S2000 nu'i o masina cu care sa te plimbi in fiecare zi .E o jucarie de weekend cu care sa te racoresti dupa o saptamana agitata .Plus ca e foarte greu de condus la limita .
TT'u in schimb merge pe fiabilitate ,calitate si eleganta in stil german .NU cred ca TT'u si-a propus sa concureze S2000'u cu varianta de 180 CP ci doar sa poate oferi o varianta mai ieftina pentru piata .
Daca as fi sa aleg o masina pentru fun aleg S2000 ,in rest TT'u rupe .
slater is offline   Reply With Quote
Old 30-07-05, 13:10   #14
SHOGUN-A8
SHOGUN-A8's Avatar
bine...recunosc ca am gresit urat de tot.
De acum inainte daca mai postati sa luati tt-ul de 225 de cai in comparatie.
Old 30-07-05, 22:54   #15
Bogdan_16v
Guest
Posts: n/a
Razvan, TT-ul de 225cp si-o fura de la CTR, ambele stock....S2000 nici nu mai discuta cu el...poate cu V6-ele, subliniez poate, dar ma indoiesc....toata ingineria la S2000 este opera de arta, nu mai gasesti nicaieri sasiu si ansamblu motor-transmisie atat de performante in clasa asta....si, tine minte, la masina veche de 6 ani!!! Singura buba la S2000 cu motorul de 2 litri e ca motorul trage cu adevarat de pe la 5-6000, insa duce pana aproape de 9000...au rezolvat asta cu 2.2-ul, trage de la 3000 pana putin peste 8000....
Slater, ai condus cumva S2000 sa stii ca e greu de condus la limita? Pe ce te bazezi cand faci afirmatii de genul asta? Iti cumperi cumva o asemenea masina sa cari sacose cu cartofi? Sa inteleg ca TT-ul e mai incapator sau cum? Ai stat cumva intr-un TT sa vezi in ce hal de inghesiuala e? Sau poate nu stii ca initial, masina asta isi lua zborul efectiv de pe sosea la peste 200 si a fost nevoie de o \"mica\" reproiectare? Asa da tehnologie nemteasca....sa goniti bine...
