Old 03-02-06, 18:18   #1
SHOGUN-A8
SHOGUN-A8's Avatar
Default Jaguar XK vs. Mercedes Cl 500
Jaguar:
-One supercharger compressor
-4,196 cc 4.2 liters V 8 front engine with 86 mm bore, 90.3 mm stroke, 9 compression ratio, double overhead cam and four valves per cylinder AJ-V8
-Premium unleaded fuel 91
-Fuel economy EPA highway (mpg): 23 and EPA city (mpg): 16
-Multi-point injection fuel system
-19.9 gallon main premium unleaded fuel tank
-Power: 291 kW , 390 HP SAE @ 6,000 rpm; 399 ft lb , 541 Nm @ 3,500 rpm
Mercedes:
-4,966 cc 5 liters V 8 front engine with 97 mm bore, 84 mm stroke, 10 compression ratio, overhead cam and three valves per cylinder
-Fuel economy EPA highway (mpg): 24 and EPA city (mpg): 16
-23.2 gallon main premium unleaded fuel tank
-Power: 225 kW , 302 HP SAE @ 5,600 rpm; 339 ft lb , 460 Nm @ 2,700 rpm
SHOGUN-A8 is offline
Old 03-02-06, 18:44   #2
Race
In primul rand,datele postate de tine sunt pentru XKR si CL500.
In al doilea rand,concurentul de la Mercedes pentru XK e CLK,nu CL.
Daca totusi e de ales intre cele doua,Mercedes-ul e mai mare,mai greu,mai putin puternic si mai scump...toate motive pentru a prefera Jaguar-ul.
Race is offline
Old 03-02-06, 19:01   #3
SHOGUN-A8
SHOGUN-A8's Avatar
http://www.internetautoguide.com/car...ass/index.html
http://www.internetautoguide.com/car...ies/index.html
ps: am mai editat putin topicul
Old 03-02-06, 23:13   #4
slater
slater's Avatar
[Crazy Drivers]
Intradevar o comparatie cu CLk'ul ar fi fost mai potrivita dar de ce nu s-a ales V8'ul de pe 55 AMG ?!? ,. sa vedem atunci ;\"))
slater is offline
Old 03-02-06, 23:21   #5
SHOGUN-A8
SHOGUN-A8's Avatar
v8-ul d p 55 amg avea in jur de 620 de cai.... .
Parerea mea e ca nu ai cum sa compari 390 hp cu 620....
Si eu nu stiu daca clk il concureaza pe xk
Old 03-02-06, 23:36   #6
Race
V8 de pe CL55AMG are 500 CP.
V8 de pe CLK55AMG are 367 CP.
Iar despre cum se concureaza,doar uita-te la dimensiuni si pret...
Race is offline
Old 03-02-06, 23:45   #7
SHOGUN-A8
SHOGUN-A8's Avatar
Da....la pret.....Xk e in jur de 70k,iar cl 500 tot in jurul la 70k se invarte..
Old 03-02-06, 23:51   #8
NWZeu
NWZeu's Avatar
[AfterDark Racing]
o putere mare trebuie si stapanita - Active Body Control face diferentza intre ele, daca era si AMG jucaria capata o noua conotazie, anyway BENZ all the way
NWZeu is offline
Old 04-02-06, 00:14   #9
Race
Preturi pentru Romania,EURO CIP:
XKR - 74.900
CLK55AMG - 68.595
CL500 - 88.063
CL55AMG - 116.963
CL500 e mai scump semnificativ decat XKR.In plus,se compara pretul pentru motorizari echivalente.Altfel,Seria 3 si Seria 5 se concureaza intre ele,ca modelul cu motor de top pentru 3 costa doar cu cateva sute de EURO mai putin decat cel de baza pentru 5..
Race is offline
Old 04-02-06, 11:26   #10
SHOGUN-A8
SHOGUN-A8's Avatar
Da,dar seria3 vs. seria 5.....seria3 este mai mic,nu?
Acelasi lucru este si la Clk vs. Xk
Old 04-02-06, 15:44   #11
Race
Tu esti chiar culmea.Daca esti asa destept,de ce ai mai facut thread pentru asta ?
CL - 4,99 metri
XK - 4,76 metri
CLK - 4,64 metri
Dupa parerea ta,XK e mai lung cu 12 cm decat CLK,deci nu sunt in aceeasi clasa.CL e mai lung cu 23 cm decat XK,si totusi sunt in aceeasi clasa...logica de fier,ce sa zic...
Race is offline
Old 04-02-06, 15:54   #12
SHOGUN-A8
SHOGUN-A8's Avatar
yeah...whatever....cum spui tu....eu nu am spus niciodata ca as fi destept ( chiar daca sunt un geniu ).
Ideea mea e ca....daca ar vrea cineva sa aleaga dintre un xkr si un cl500 ce ar alege....doar aceste masini.
Old 15-02-06, 19:29   #13
emy_brabus
Default Nu se poate asa ceva!!!
Omule, de ce nu vrei sa intelegi ca te-ai facut de ras, de ce nu ai comparat doua masini din aceeasi clasa, mai degraba Jaguarul cu un BMW seria 6, pt ca Mercedes CL din cate stiu eu nu prea are concurent pt un coupe!!!
emy_brabus is offline
Old 15-02-06, 20:08   #14
SHOGUN-A8
SHOGUN-A8's Avatar
Lol...auzi la el..m-am facut de ras....
Eu am vrut sa compar aceste doua masini....nu am vrut sa compar altceva....
Tu poti compara orice masini vrei tu...daca vrei poti pune masini care sunt exact la fel..nu-mi pasa...
Old 15-02-06, 20:30   #15
SEBASTIAN
SEBASTIAN's Avatar
[Mitsubishi]
[SUBARU]
Default Re: Jaguar XK vs. Mercedes Cl 500
Originally Posted by \"SHOGUN-A8\"
Jaguar:
Mercedes:
Nu e o comparatie corecta!
Nu sunt un fan mergedes, dar cred ca e cazul sa pui langa un XK un AMG cu
kompresor
In fine daca vreti sa comparati mere cu pere...
De ce nu alegeti un versus echilibrat si just?
Professional DynoTuning
[email protected]
0723691731
SEBASTIAN is offline
