Jaguar XK vs. Mercedes Cl 500
Jaguar:
-One supercharger compressor -4,196 cc 4.2 liters V 8 front engine with 86 mm bore, 90.3 mm stroke, 9 compression ratio, double overhead cam and four valves per cylinder AJ-V8 -Premium unleaded fuel 91 -Fuel economy EPA highway (mpg): 23 and EPA city (mpg): 16 -Multi-point injection fuel system -19.9 gallon main premium unleaded fuel tank -Power: 291 kW , 390 HP SAE @ 6,000 rpm; 399 ft lb , 541 Nm @ 3,500 rpm Mercedes: -4,966 cc 5 liters V 8 front engine with 97 mm bore, 84 mm stroke, 10 compression ratio, overhead cam and three valves per cylinder -Premium unleaded fuel 91 -Fuel economy EPA highway (mpg): 24 and EPA city (mpg): 16 -Multi-point injection fuel system -23.2 gallon main premium unleaded fuel tank -Power: 225 kW , 302 HP SAE @ 5,600 rpm; 339 ft lb , 460 Nm @ 2,700 rpm |
In primul rand,datele postate de tine sunt pentru XKR si CL500.
In al doilea rand,concurentul de la Mercedes pentru XK e CLK,nu CL. Daca totusi e de ales intre cele doua,Mercedes-ul e mai mare,mai greu,mai putin puternic si mai scump...toate motive pentru a prefera Jaguar-ul. |
:arrow: http://www.internetautoguide.com/car...ass/index.html
:arrow: http://www.internetautoguide.com/car...ies/index.html ps: am mai editat putin topicul :) |
Intradevar o comparatie cu CLk'ul ar fi fost mai potrivita dar de ce nu s-a ales V8'ul de pe 55 AMG ?!? ,. sa vedem atunci ;\"))
v8-ul d p 55 amg avea in jur de 620 de cai.... :roll: .
Parerea mea e ca nu ai cum sa compari 390 hp cu 620.... Si eu nu stiu daca clk il concureaza pe xk :? |
V8 de pe CL55AMG are 500 CP.
V8 de pe CLK55AMG are 367 CP. Iar despre cum se concureaza,doar uita-te la dimensiuni si pret... |
Da....la pret.....Xk e in jur de 70k,iar cl 500 tot in jurul la 70k se invarte..
o putere mare trebuie si stapanita - Active Body Control face diferentza intre ele, daca era si AMG jucaria capata o noua conotazie, anyway BENZ all the way
Preturi pentru Romania,EURO CIP:
XKR - 74.900 CLK55AMG - 68.595 CL500 - 88.063 CL55AMG - 116.963 CL500 e mai scump semnificativ decat XKR.In plus,se compara pretul pentru motorizari echivalente.Altfel,Seria 3 si Seria 5 se concureaza intre ele,ca modelul cu motor de top pentru 3 costa doar cu cateva sute de EURO mai putin decat cel de baza pentru 5.. |
Da,dar seria3 vs. seria 5.....seria3 este mai mic,nu?
Acelasi lucru este si la Clk vs. Xk |
Tu esti chiar culmea.Daca esti asa destept,de ce ai mai facut thread pentru asta ?
CL - 4,99 metri XK - 4,76 metri CLK - 4,64 metri Dupa parerea ta,XK e mai lung cu 12 cm decat CLK,deci nu sunt in aceeasi clasa.CL e mai lung cu 23 cm decat XK,si totusi sunt in aceeasi clasa...logica de fier,ce sa zic... |
yeah...whatever....cum spui tu....eu nu am spus niciodata ca as fi destept ( chiar daca sunt un geniu :lol: ).
Ideea mea e ca....daca ar vrea cineva sa aleaga dintre un xkr si un cl500 ce ar alege....doar aceste masini. |
Nu se poate asa ceva!!!
Omule, de ce nu vrei sa intelegi ca te-ai facut de ras, de ce nu ai comparat doua masini din aceeasi clasa, mai degraba Jaguarul cu un BMW seria 6, pt ca Mercedes CL din cate stiu eu nu prea are concurent pt un coupe!!!
Lol...auzi la el..m-am facut de ras....
Eu am vrut sa compar aceste doua masini....nu am vrut sa compar altceva.... Tu poti compara orice masini vrei tu...daca vrei poti pune masini care sunt exact la fel..nu-mi pasa... :wink: |
Re: Jaguar XK vs. Mercedes Cl 500
Nu sunt un fan mergedes, dar cred ca e cazul sa pui langa un XK un AMG cu kompresor. In fine daca vreti sa comparati mere cu pere... De ce nu alegeti un versus echilibrat si just? |
| All times are GMT +2. The time now is 02:14. |
