1997 Mitsubishi 3000 GT Performance & Efficiency Standard Features
-2,972 cc 3 liters 6 V front transverse engine with 91.1 mm bore, 76 mm stroke, 8.9 compression ratio, cast iron block, light alloy head, overhead cam, automatic valve adjustment and two valves per cylinder
-Premium unleaded fuel
-Fuel economy EPA highway (l/100km): 9.8
-Multi-point injection fuel system
-Main 75 liter fuel tank
-Power: 120 kW , 161 HP @ 5,500 rpm; 185 ft lb @ 4,000 rpm
1997 Toyota Supra Performance & Efficiency Standard Features
-2,997 cc 3 liters 6 in-line front longitudinal engine with 86 mm bore, 86 mm stroke, 10 compression ratio, light alloy block, light alloy head, double overhead cam and four valves per cylinder
-Unleaded fuel
-Main 70 liter fuel tank
-Power: 164 kW , 220 HP @ 5,800 rpm; 210 ft lb @ 4,800 rpm
