26-02-08, 17:45
#31
Member of: [Old School Cars]
Re: Bujii NGK,Discuri Brembo,Filtre K&N,Hengst, UFI, si alte piese de marca
Originally Posted by bogmotorsport
salut pt golf 3 1,8 abs an fabr 1994 discuri placute si filtru sport in cutia originala
Salut
Ptr modelul tau este filtrul
http://www.knfilters.com/search/prod...x?Prod=33-2069
Pret 298 ron
Disc frina Fata Brembo
Diametru [mm] 239 mm
Īnaltime [mm] 35 mm
Tip disc frāna plin
Grosime disc frāna [mm] 12 mm
Grosime minima [mm] 10 mm
Numar gauri 4
Diametru de centrare [mm] 65 mm
Articol extins/Info extins 2 cu suruburi
Pāna īn an fabricatie 1995.07
Partea de montare punte fata
Pret 54 ron / buc
Din Gama BREMBO MAX
Gama Brembo MAX se adreseaza entuziastilor si celor care doresc performante superioare.
Discurile sunt vopsite si au caneluri,ptr o frinare mai eficienta in orice conditii , in special pe ploaie.
Pret 84 ron / buc
Set placute frina fata Road House
Pret 60 ron / set
Cu stima
Andrei
www.autozr1.net
#32
Member of: [VW] [BMW]
an fabricatie 92
motor vr6
2.9 l
192 CP
26-02-08, 21:52
#33
Originally Posted by corrado_ro
an fabricatie 92
motor vr6
2.9 l
192 CP
Salut.
Furtun frina nu avem decit ptr spate
Furtun frina SBS
Lungime [mm] 185 mm
Partea de montare la etrier
Partea de montare puntea spate
Pret 27 ron / buc
Tot pe spate imi mai arata disponibil un furtun, fara sa specifice unde vine dar am urm specificatii:
Lungime [mm] 160 mm
Pret 29 ron / buc
Disc fata BREMBO MAX
Diametru [mm] 280 mm
Tip disc frāna ventilat interior
Grosime disc frāna [mm] 22 mm
Grosime minima [mm] 20 mm
Numar gauri 5
Moment strangere [Nm] 11 Nm
Diametru asezare gauri [mm] 65 mm
Sistem frānare High Carbon
Pret 267 ron / buc
Disc frina spate BREMBO
Diametru [mm] 226 mm
Īnaltime [mm] 71,2 mm
Tip disc frāna plin
Grosime disc frāna [mm] 10 mm
Grosime minima [mm] 8 mm
Numar gauri 5
Diametru de centrare [mm] 39,8 mm
Pret 142 ron / buc
Cu stima
andrei
26-02-08, 22:17
#34
an fabricatie 92
motor vr6
2.9 l
192 CP
Placute frina Fata Road House
Īnaltime [mm] 69,6 mm
Latime [mm] 119,3 mm
Grosime [mm] 16 mm
Contact indicator uzura inclusiv contact avertizare uzura
Numar senzori uzura 2 pe osie
Pret 120 ron / set
Placute frina spate RoadHouse
Īnaltime [mm] 52,9 mm
Latime [mm] 87 mm
Grosime [mm] 15 mm
Aprobare E1 90R - 01023/056
Sistem frānare Lucas-Girling
Pāna īn an fabricatie 1993.03
Pret 74 ron / set
Andrei
www.autozr1.net
29-02-08, 11:41
#35
salutare ma intereseaza 6 bujii ngk discuri fata si spate dublu ventilate pt bmw 325 coupe 192 de cai din 1994.
29-02-08, 12:24
#36
Salut ptr modelul tau iti ofer:
Bujii NGK 20 ron / buc
Disc frina Fata Brembo 191 ron / buc
Diametru [mm] 286 mm
Īnaltime [mm] 51,6 mm
Grosime minima [mm] 20,4 mm
Numar gauri 5
Diametru de centrare [mm] 79 mm
Disc frina fata BREMBO max
Pret 271 ron / buc
Disc spate BREMBO
Īnaltime [mm] 60,1 mm
Tip disc frāna plin
Grosime minima [mm] 8,4 mm
Numar gauri 5
Diametru de centrare [mm] 75 mm
Pret 137 ron / buc
Cu stima
andrei
www.autozr1.net
03-03-08, 09:08
#37
Ford taunus 1976, 1.6L motor LCJ..ceva kit de upgrade la frane gasesti?..k sa pot pune discuri mai mari ventilate??
03-03-08, 22:03
#38
salut
pre modelul tau iti pot oferi Disc fata BREMBO
Diametru [mm] 247,5 mm
Īnaltime [mm] 26,8 mm
Tip disc frāna plin
Grosime disc frāna [mm] 12,7 mm
Grosime minima [mm] 11,4 mm
Numar gauri 4
Diametru de centrare [mm] 68,4 mm
Pret 115 ron tva inclus
Cu stima
andrei
www.autozr1.net
06-03-08, 08:31
#39
Filtru conic K&N universal
Informatii despre produs AICI
Filtrul are urm dimensiuni:
-diametru la baza conului 147 mm
-diametru la virful conului 89 mm
-diametru interior flansa prindere 80 mm
-inaltime 115 mm
PRET 209 RON
08-03-08, 22:11
#40
Va putem livra si filtre sport pentru motociclete
Filtru aer K&N Suzuki
Informatii despre filtru clik AICI
Lista cu Motociclete compatibile AICI
Pret 215 RON
Cu stima
andrei
www.autozr1.net
08-03-08, 22:23
#41
pt daewoo lanos discuri fata ce ai ?
dar placute de frana pt lanos sau matiz ?
clasic si sport !
08-03-08, 22:51
#42
clasic si sport !
salut
da-mi te rog motorizarile la ambele masini si anii de fabricatie.
Merci
09-03-08, 01:31
#43
Honda Driver
Member of: [PARTICIPANT CURSE] [Nissan] [Honda]
ngk pfr5b11b sau pfr6b11b??? 6 buc?
09-03-08, 07:03
#44
OK, deci e fapt este un cielo cu discuri de cielo(236mm) 4x100 din 1996 cu etrieri de lanos sau matiz sunt aceeasi, motorizare cielo sau lanos 1498cmc si matiz 798cmc din 2000-2008.
deci discuri si placute ?
SECRETUL REUSITEI NU ESTE SA TII MINTE CI SA STII UNDE SA CAUTI !!
(Fara erori, ballastri slim, orice tip de bec, ieftin si cu garantie)
https://forum.4tuning.ro/460-faruri-s...n/page-19.html/www.xenonieftin.ro
0724186590 / 0766900342;ID mess : serban_pc ; Bucuresti - Titan
09-03-08, 08:44
#45
salut.
ambele sunt stoc zero momentan si la dep central....
daca nu gasesti altundeva mai aminteste-mi peste 1-2 sapt.
Cu stima
Andrei
