DEZMEMBRARI / PIESE VW GOLF 3 *** PITESTI ***
Diferite motorizari: 1400, 1600, 1800, 2000 8v, 2000 16v, 2800 VR6, 2900VR6, 1900 D, TD, TDI
Yahoo Messenger: yawa_x99
E-mail:
yawa_x99@yahoo.com
PROGRAM: LUNI-DUMINICA INTRE ORELE 7:00 -22:00
TEL:
0745.37.99.15 /
0760.59.59.26 /
0729.37.55.70 - Ionut
Livrare in 24ore in toata tara prin FAN CURIER preturi de la 18ron/colet (plata ramburs la livrarea coletului)
***LA TOATE PIESELE ASIGURAM GARANTIA FUNCTIONARII***
1. Motor 2ooo GTI 8v 116CP – 500 ron
2. Motor 1,4cmc – 600 ron
3. Motor 1,6cmc ABU,AEA –600 ron
4. Motor 1,6 cmc 101cp – 600 ron
5. Motor 1,8cmc 90cp si 75cp – 500 ron
6. Motor 1.9D – 1000ron
7. Motor 1.9 TD – 1000ron
8. Motor 1.9 TDI – 1000ron
9. Motor 2000 GTI 16v 150cp – 1000ron
10. Motor VR6 2800cmc 174cp – 1500ron
11. Motor VR6 2900cmc 190cp – 1700ron
12. Cutie 5+1 GTI – 500 ron
13. Cutie 5+1 …1800cmc – 500 ron
14. Cutie 5+1 …1600cmc 75cp – 500 ron
15. Cutie 5+1 …1600cmc 101CP - 600ron
16. Cutie 5+1 …1900D, TD – 600ron
17. Cutie 5+1…1600cmc ABU (electromotor in spate) – 700ron
18. Cutie 5+1 TDi – 800ron
19. Cutie GTI 2000 16v 150cp – 800 ron
20. Cutie 5+1 syncro (4x4) pt GTi 8v, 16v , TDi si VR6 – 1400 ron
21. Cardan GOLF SYNCRO – 500 ron
22. Debimetru aer BOSCH sau HITACHI – 160 ron
23. Bobina inductie – 150 ron
24. Delcou + sensor hall – 150 ron
25. Pompa frana ABS – 150 ron
26. ABS pompa + senzori + electrica (totul complet) – 150 euro
27. Volan airbag + airbag pasager+ centralina– 300 ron
28. Diverse piese motor (sensor hall, delcou, senzori, injectoare)
29. Corp injector 1.4, 1.6, 1.8 complet – 350 ron
30. Electromotor pt motor 1,4; 1,6; 1,8; 2,0 – 150 - 200 ron
31. Roti rezerva subtiri vw 4 sau 5 prezoane- 50 ron/buc cauciuc inclus
32. Trager (suport faruri, radiator, din fibra) – 150 - 200 RON
33. Parbriz – 180 ron
34. Luneta originala VW - 150 ron
35. Eleron luneta – 100 ron
36. Mecanism trapa functional – 300 ron
37. Trapa functionala completa - 500 ron
38. Motoras trapa – 100 ron
39. Geam trapa – 100ron
40. Carlig remorcare Golf 3 + instalatie electrica – 300 ron
41. Radiator apa original VW (diferite motorizari) – 150-200 ron
42. Electro-ventilatoare - 100 ron
43. Aripi originale fara rugina - 100 ron
44. Haion + luneta– 250 ron
45. Capota originala VW – 150 - 250 ron
46. Praguri plastic complete – 250 ron
47. Faruri GTI (faza scurta si separat lunga) – 250ron setul
48. Faruri Golf normale – 200 ron /setul
49. proiectoare GTI HELLA clare/lupa – 200 ron/setul
50. Grila fata completa - 80 ron
51. Spoiler bara fata normal original VW (nu este casant) – 50 ron
52. Spoiler bara fata Golf VR6, GTI, GTD (nu este casant) – 100 ron
53. Intaritura bara fata – 60 ron
54. Bara fata flexibila originala – 160 ron
55. Bara spate flexibila originala – 80 ron
56. Instalatie AC completa (aeroterma, radiator, tubulatura, instalatie electrica, buton, rezervor si compresor) pt motor 1,8; 1,9; 2000; vr6 - 250 euro
57. Instalatie AC completa (aeroterma, radiator, tubulatura, instalatie electrica, buton, rezervor si compresor) pt motor 1400, 1600cmc – 1000 ron
58. Compresor Aer Conditionat – 400 ron
59. Conducte Aer Conditionat- 300 ron
60. Lampi spate GTI Hella fumurii – 150 ron setul
61. Lampi spate normale Hella - 100 ron setul
62. Usi originale fara rugina – 50-150lei/buc
63. Maner usa - 20lei
64. Fete usi interior - 50 lei buc
65. Fete usi golf in 2 usi – 50 ron
66. Catalizaror 1,4; 1,6; 1,8 sau 2,0 - 150lei
67. Toba completa GTI – 150 ron (detenta+finala)
68. Punte + tamburi completa - 200lei
69. Punte spate + discuri (fara etrieri) – 250 ron
70. Punte spate discuri 4 prezoane completa - 400 ron
71. Scaune + bancheta GTI – 300 lei
72. Scaune RECARO + banchete – 400ron
73. Scaune + bancheta spate normale - 100lei
74. Sistem ventilare (aeroterma-radiator, motoras si carcasa completa) - 100lei
75. Bord fara ceasuri cu tuburi ventilatie - 80lei
76. Torbedou pt modelul cu airbag – 100 ron
77. Volan normal in 4 spite de vw – 50 ron
78. Volan VR6 – 100 ron
79. Volan cu Airbag – 150ron
80. Rezervor - 50lei
81. Pompa benzina GTI - 180lei
82. Pompa benzina de 1400, 1600 si 1800cmc – 160 ron
83. Pompa benzina VR6; 2000 16v – 250 ron
84. Caseta directie-servo – 200 ron
85. Pompa servo-directie 1400, 1600, 1800, 1900 si 2000 – 180 ron
86. Fuzetele in 5 prezoane - 200 lei ambele (completa cu etrieri, disc, placute, rulment)
87. Fuzete in 4 prezoane – 150 ron ambele (completa cu etrieri, disc, placute, rulment)
88. Fuzete spate – 60 ron
89. Alternatoare 1,4; 1,6; 1,8; 1,9; 2.0 cmc - 150 lei
90. Instalatia electrica - 20euro
91. Contact - 50 ron
92. Vas lichid anti-gel – 20 ron
93. Vas spalare parbriz – 20 ron
94. Vas ulei servo – 20 ron
95. radiator aeroterma incalzire – 100 ron
96. Tamburi frana spate completi – 50 ron
97. Planetare motor 1,6 si 1,8 – 120ron/buc
98. Planetare GTI – 150ron/buc
99. Planetare VR6 – 200ron/buc
100. Suspensie fata sau spate (telescop + arc) - 130 ron
101. Arcuri sport fata/spate rosii (merg pe telescop normal) – 50 ron/buc
102. Acumulatori (baterii auto) – 60 ron
103. Arcuri de fata sau spate – 70 ron buc
104. Telescoape fata – 130ron (2buc)
105. Telescoape spate - 130ron (2buc)
106. Pompa frana (cu servo) – 100 ron
107. Toba evacuare detenta originala vw pt motor 1,6 - 50RON
108. Toba evacuare completa GTI - 150 ron (detenta+finala)
109. Mocheta fata + spate – 50 ron
110. Compresor aer pt inchidere centralizata – 80 ron
111. Trapez stanga/dreapta (brat) – 70 ron/buc
112. Cabluri: frana de mana, acceleratie, ambreaj, capota, - 30 ron
113. Torpedou : 100 ron complet functional ambele modele cu /fara airbag
114. Ansamblu volan G3/Vento, compus din dispozitiv reglaj, ax volan : - 60 ron
115. Set complet plastice interior: praguri, stalpi fata, central si spate(pt vento), restul merg si pe G3: - 25 lei oricare
116. Etrieri fata – 50 ron/buc
117. Etrieri spate – 220 ron/set
118. Disc fata/spate – 40 ron buc
119. Cadru motor fara brate (H) - 100 lei
120. Chedere usi – 100 ron/set 5 buc (ireprosabile) sau 30 ron/buc
121. Chedere geamuri – 60 ron/set 4 buc
122. Suport motor original – 40 ron
123. Electroventilator – 100 ron
124. Ceasuri bord GTI, VR6 220km/h, 240km/h(albe sport), 260km/h (vr6) – 200RON
125. Ceasuri bord 200 km/h cu turometru – 150 lei (pt bordurile care au ceas in loc de turometru merg fara nici o improvizatie dar se baga mufa si functioneaza turometrul)
126. Geamuri – 50 ron/buc si 20 ron cele mici de pe spate
127. Elemente caroserie (lonjeroane, praguri, plafon etc)
128. + alte multe piese TEL 0745.379.915/0760.59.59.26
Achizitonez / Cumpar VW GOLF 3, 4 / Vento avariata sau stare buna, cu sau fara acte, INMATRICULABILA SAU NEINMATRICULABILA an fabr dupa 1992
TEL: 0745.379.915 / 0760.59.59.26
OPTIONAL PIESELE SE POT TRIMITE SI PRIN CURIER RAPID (cu plata la destinatie de la 18 ron pt 1 colet)
