Go Back   Forum 4Tuning > Hobby & Pasiuni Comune > PC Games - HARDWARE - Console > Hardware
Hardware Configuratii, componente, cerinte, preturi, sfaturi, modificari
Old 26-08-11, 13:55   #1
low.
low.'s Avatar
Default vand foarte ieftin placa de baza/ram/placa video pci-e.
vand urmataorele componente pc:
>a fost un sistem,pe care l-am vandut pe bucati,fiind pc-ul surorii mele,acum plecata la facultate,si-a luat laptop,deci nu a fost overclock-ed sau alte chestii de genul,ruland mai mult pe facebook sau hi5 ))
Placa de baza Gigabyte 945gcm-s2l:
Support for an Intel® Core™ 2 Extreme processor/ Intel® Core™2 Duo processor/Intel® Pentium® D processor/ Intel® Pentium® 4 processor/ Intel® Celeron® processor in the LGA 775 package (Go to GIGABYTE's website for the latest CPU support list.)
Support for Intel® Hyper-Threading Technology
L2 cache varies with CPU
Front Side Bus (1333)/1066/800/533 MHz FSB
Chipset North Bridge: Intel® 945GC Express Chipset
South Bridge: Intel® ICH7
Memory 2 x 1.8V DDR2 DIMM sockets supporting up to 4 GB of system memory
Dual channel memory architecture
Support for DDR2 667/533/400 MHz memory modules
(Go to GIGABYTE's website for the latest memory support list.)
* Due to standard PC architecture, a certain amount of memory is reserved for system usage and therefore the actual memory size is less than the stated amount.
Onboard Graphics Integrated in the North Bridge
Audio Realtek ALC662 codec
High Definition Audio
2/4/5.1-channel
Support for S/PDIF Out
Support for CD In
LAN RTL 8111C chip (10/100/1000 Mbit)
Expansion Slots 1 x PCI Express x16 slot
1 x PCI Express x1 slot
2 x PCI slots
Storage Interface South Bridge:
1 x IDE connector supporting ATA-100/66/33 and up to 2 IDE devices
4 x SATA 3Gb/s connectors supporting up to 4 SATA 3Gb/s devices
iTE IT8718 chip:
1 x floppy disk drive connector supporting up to 1 floppy disk drive
USB Integrated in the South Bridge
Up to 8 USB 2.0/1.1 ports (4 on the back panel, 4 via the USB brackets connected to the internal USB headers)
Internal I/O Connectors 1 x 24-pin ATX main power connector
1 x 4-pin ATX 12V power connector
1 x IDE connector
1 x CPU fan header
1 x system fan header
1 x front panel header
1 x front panel audio header
1 x CD In connector
1 x S/PDIF Out header
2 x USB 2.0/1.1 headers
1 x chassis intrusion header
1 x power LED header
Back Panel Connectors 1 x PS/2 keyboard port
1 x PS/2 mouse port
1 x parallel port
1 x serial port
1 x D-Sub port
4 x USB 2.0/1.1 ports
1 x RJ-45 port
3 x audio jacks (Line In/Line Out/Microphone)
I/O Controller iTE IT8718 chip
H/W Monitoring System voltage detection
CPU temperature detection
CPU/System fan speed detection
CPU overheating warning
CPU/System fan fail warning
CPU fan speed control
BIOS 1 x 4 Mbit flash
Use of licensed AWARD BIOS
PnP 1.0a, DMI 2.0, SM BIOS 2.3, ACPI 1.0b
Unique Features Support for @BIOS
Support for Download Center
Support for Q-Flash
Support for EasyTune
Support for Xpress Install
Support for Xpress Recovery2
Support for Virtual Dual BIOS
Bundle Software Norton Internet Security (OEM version)
Operating System Support for Microsoft® Windows Vista/XP/2000
(Go to GIGABYTE's website for operating system support information.)
Form Factor Micro ATX form factor; 24.4cm x 19.3cm
Placa video His hd 2400 pro:
Product Code H240PRF256-R
Cooler Fan
GPU 2400Pro
Core Clock 525 MHz
Memory Clock 800 MHz
Memory Size 256 MB
Memory Type DDR2
Memory Interface 64 bit
Interface PCI-Express x16
Box Dimension 23.2 x 16.2 x 6 cm (HxWxD)
Availability Discontinued
Procesor Intel pentium E2160:
Essentials
Status Launched
Launch Date Q3'06
Processor Number E2160
# of Cores 2
# of Threads 2
Clock Speed 1.8 GHz
L2 Cache 1 MB
Bus/Core Ratio 9
FSB Speed 800 MHz
FSB Parity No
Instruction Set 64-bit
Embedded Options Available Yes
Supplemental SKU No
Lithography 65 nm
Max TDP 65 W
VID Voltage Range 0.8500V-1.5V
Recommended Channel Price $63.00
Graphics Specifications
Integrated Graphics No
Package Specifications
TCASE 73.3°C
Package Size 37.5mm x 37.5mm
Processing Die Size 77 mm2
# of Processing Die Transistors 105 million
Sockets Supported LGA775
Low Halogen Options Available No
Advanced Technologies
Intel® Turbo Boost Technology No
Intel® Hyper-Threading Technology No
Intel® Virtualization Technology (VT-x) No
Intel® Virtualization Technology for Directed I/O (VT-d) No
Intel® Trusted Execution Technology No
AES New Instructions No
Intel® 64 Yes
Idle States Yes
Enhanced Intel SpeedStep® Technology Yes
Intel® Demand Based Switching No
Thermal Monitoring Technologies Yes
Execute Disable Bit Yes
Placuta ram 2gb ddr2 kingstone 800mhz
Pretul pachetul este de 400 ron,tiind sa amintesc cu o placa putin mai potenta nu veti avea probleme in jocuri.
Predare personala buzau/rm-sarat.
Trimit si prin curier,dar cu avans pentru transport.
Merci pentru intelegere.
Ym: bz_05_hyu
Buzau,rm-sarat
ID:	2131396   Click image for larger version
ID:	2131397   Click image for larger version
Move bitch, get out the way! Get out the way bitch, get out the way!!
low. is offline   Reply With Quote
Old 30-08-11, 16:16   #2
low.
low.'s Avatar
Default Re: vand foarte ieftin placa de baza/ram/placa video pci-e.
Se mai adauga :
Placa de baza plus procesor:
>amd athlon(tm) 3200+ ~2.2ghz soccket am2
>K8M890-8237A
Perfecta stare,pret 130 ron!! pomana,urgent!
se mai adauga si un ram 2gb kingstone(pret pachet)= 230 ron!! pomana!
Placa video SAPPHIRE HD 3450 512MB DDR2 PCI-E:
64-bit memory interface
Core/Memory Clock – 600 / 500
Passive thermal solution
PCI Express® 2.0 x16 bus support
DirectX® 10.1 / Shader Model 4.1 support
ATI CrossFireX™ multi-GPU support
Unified Video Decoder (UVD) for Blu-ray™ and HD DVD at full HD 1080p
HDMI with 5.1 surround sound audio
(Important Information for Windows XP & Windows Vista users)
Card with DUAL DVI
Pret 80 ron.
Name:	AMD Athlon 3200+ (ADA3200CNBOX).jpg
ID:	2135285   Click image for larger version
Old 08-09-11, 18:29   #3
SpeedClass
Dacia Driver
SpeedClass's Avatar
Salut.Cat costa Placa de baza Gigabyte 945gcm-s2l????
SpeedClass is offline   Reply With Quote
Old 02-08-12, 23:46   #4
Cola01
Salut, sunt interesat de aceasta placa, best_gemanay Id-ul meu de messenger, ne auzim acolo!
Cola01 is offline   Reply With Quote
Old 05-12-12, 21:20   #5
marius_eugen
marius_eugen's Avatar
[INSANE RACERS]
Exclamation Re: vand foarte ieftin placa de baza/ram/placa video pci-e.
LOW e TEPAR ! Si aici si pe alte forumuri da tepe cu electronice ! MI-a vandut o placa video defecta si nu vrea sa si-o ia inapoi !
Nu mai raspunde la telefon !
NU aveti incredere , nu trimiteti prin posta si nu platiti nimic inainte ! Numarul lui de mobil este : 0769.960.521 !
Un om de nimic , care da tepe pentru 180 ron ! Pe alte site-uri foloseste ID-ul "draky90" !
http://forum.computergames.ro/223-co...50/page-2.html
marius_eugen is offline   Reply With Quote
